Question about Jl Audio 12W3 Car Subwoofer
Whats better i have and audiobahn a8000t amp or a rockford p6002 and also does any one know whare i can get 2 new dust covers for my jl audio w3v2 12
  • 109 Answers
I would go with rockford cause they under rate alot of there stuff so it is actually better than what they say it is and audiobahn over rates there stuff so its wors than thay say w3v2 12's can be purchased at pro car sterio in roseburg oregon you can get them online @ jl audio.com for about $125.00 for the 12's and $110.00 for for 10's
Posted on Dec 02, 2008
  • sintm_112 Dec 02, 2008
    i would go with rockford cause they under rate alot of there stuff so it is actually better than what they say it is and audiobahn over rates there stuff so its wors than thay say w3v2 12's can be purchased at pro car sterio in roseburg oregon you can get them online @ jl audio.com for about $125.00 for the 12's and $110.00 for for 10's
MY P6002 blows the fuses everytime I hook it up. Dont know why?
you probably have a shorted component(s) inside the amplifier.
Aug 10, 2010 | Rockford Fosgate Punch P6002 Car Audio...
My A8000t amps red protection light is on checked
When ever the amp stays in RED protection mode with out any speakers hooked up to it, YOUR amp has internal damage some where. Can't tell you how much to fix, Could be cheap or not worth it. Talk to your local electronic repair, would be a good start.
May 14, 2010 | AudioBahn A8000T Car Audio Amplifier
Hi i have 2 12 inch jlw3v3 subwoofers and one randomly stopped working i took it out of the box and it still looks brand new i even hooked it straight up to my rockford prime 500.1 amp out of the box and...
measure across the 2 terminals on the back.it should read the impedance value.
move the speaker back and forth and if it cuts in,the voice coil has a broken wire where it is joined under the dust cap, where the jl audio logo is.
Jan 12, 2010 | Jl Audio 12W3 Car Subwoofer
AMP.... question
12vDC
CFM is negotiable - as the higher RPMs the more air it moves. (also louder).
Audiobahn is out of business - and unless someone is willing to tear theirs apart for your info - get whatever they have in stock :)
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Dec 29, 2009 | AudioBahn A8000T Car Audio Amplifier
Where can I find a cooling fan for a Audiobahn a8000t amp?
Hello fornda,
The fan looks very similar to a 3" muffin fan. The fans from most computer cases would probably fit. You may have to modify how it mounts, and perhaps the connector, but the voltage is the same.
Here's an online retailer. I'd look for the highest CFM at the lowest fan speed to keep the noise down.
Hope this helps.
Aug 07, 2009 | AudioBahn A8000T Car Audio Amplifier
Amp keeps cutting off
Do you have heavy enough gauge wire supplying B+ to amp.Big amps draw a lot of current and require very heavy gauge wire. The longer the run the heavier the gauge needed.
Apr 20, 2009 | AudioBahn A8000T Car Audio Amplifier
Audiobahn A8000T has power but is not hitting
Check your cap, it prob went bad. That could be restricting the power flow now. Try it with out the cap. that just might be the prob.
Jan 15, 2009 | AudioBahn A8000T Car Audio Amplifier
Audiobahn a8000t problem
If the protect LED is lit, the amp probably has shortedoutput transistors. To eliminate other possible causes, read throughthe following page:
Amp in Protect Mode - Troubleshooting
Let me know if you have any other questions.
Nov 23, 2008 | AudioBahn A8000T Car Audio Amplifier
My amp is blown!! Dont know what part to replace.
those are likely "chips" or "integrated circuits". can you read any words, letters, numbers off it? if it's a common off-the-shelf chip you can buy from mouser.com or digitek.com, AND if you know how to de-solder and solder delicate electronic components using a hot soldering iron WITHOUT destroying them or the adjacent components. if no identifying codes on the chip, maybe google up a schematic of the board (unlikely) and figure out what it is. if it's a proprietary chip made Rockford Fosgate, it will be harder to find. Also, there could be damage to OTHER components that may not be visible, so if you go to all this trouble it might still not work and then you'd have wasted money. hopefully you are under warranty and RF can repair it. otherwise, chunk it in the nearest trash can.
Mar 06, 2007 | Rockford Fosgate P10002 Car Audio...
Jl Audio 12W3 Car Subwoofer Logo
76 people viewed this question
Top Jl Audio Car Audio & Video Experts
Mark Skinner
Tygh Duval
Tygh Duval
hoyzee1
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
