Question about Tomtom GPS
The map I was using can no longer be used the screen says "Problem with map" "You cannot use this manp on this device: Australia-14"
  • jeisman Dec 02, 2008
    TomTom 920 GPS
  • Anthony Perez
    Anthony Perez May 11, 2010
    Make and model please...
  • 67 Answers
There is a firmware issue that can be taken care of by following the following instructions:
Download this Navcore 8 http://rapidshare.com/files/11112518...m_x20_Nav8.rar
Extract Rar file, Copy the contents of the folder"navcore_8.002.9117.gox30" to the flash drive on your TomTom x20, Letit replace files etc..
Disconnect your TomTom x20 let it start up, Then reconnect to pcreplace the "ttsystem" file with the "ttsystem" file extracted from theRar file. Any problems try resetting device..!!!.
Posted on Dec 02, 2008
Tomtom 710 western europe map
Posting with them is a good thing, they know their system better than anyone else...good luck.
Oct 13, 2012 | Tomtom GO 700 GPS Receiver
Problems with map
The map file is corrupt. Download and re install. (Update again.)
Jun 04, 2012 | Tomtom GO 720 GPS Receiver
Trying to set up TomTom 340 XL TM. downloaded new map, etc but when i want operate it, i get a 'no maps found!' message. At my TomTom Home screen, it doesn't appear that maps are not on my device but the...
It happens when the device doesn't recognize the maps. That's why - in such a case - you have to downgrade the version of the maps.
What Navcore Version do you have on your device? Here's a cart to help you.
[DON'T FORGET TO RATE MY SOLUTION IF HELPFUL! THANK YOU!]
Mar 06, 2011 | Tomtom GPS
I PURCHASED A 335TM XL TOMTOM GPS AND AFTER FOLLOWING INSTRUCTIONS ON THE VOUCHER, MY TOMTOM SCREEN, DISPLAYS " NO MAPS FOUND.
You have to first load maps on the gps before you can use it. You go to tom tom website, then you update your tom tom with maps, then register your device. After doing that, I assure you will be able to use the gps.
Dec 26, 2010 | GPS
My gps says "no
Question: What should I do if my Garmin nuvi or zumo displays the message "No Detailed Maps Found That Support Routing" or "No Map Data Available?"
--> Answer: The "No Detailed Maps Found That Support Routing" or "No Map Data Available" message may appear on your device for the following reasons:
  • The GPS device is missing it's unlock code
  • The maps on the GPS device have been disabled
To determine the cause of the message, touch the screen until the message "No Detailed Maps Found That Support Routing" disappears.
  • If you see a "Can't Unlock Maps" message following this error, remove any microSD / SD cards in the device and follow the instructions below for Retrieving your unlock codes followed by the instructions for Creating an unlock file
  • If you do not get the Can't Unlock Maps message then skip to the instructions for Enabling maps on the GPS device
Retrieving your unlock codes:
  1. Log into your myGarmin account
  2. Select Manage Maps
  3. Select Details
  4. The unlock code is located under the Installed Maps.
Nov 16, 2010 | Garmin Nuvi 360 Bilingual GPS Navigator...
When trying to program in an address the Nuvi prompts you to spell a state. When you put the first letter of the state in it immediatly says "no matches found."..So it is imposible to use the...
I would make sure that your Ciy Navigator map is selected
go to Tools...Settings....Map....on bottom of screen press Map Info....make sure a check mark is in the City Navigator North American NT
Nov 09, 2010 | Garmin Nuvi 350 Car GPS Receiver
When I turn on my nuvi 200 I get the message "no
If you got the unit from somebody they could of used a SD card and its looking for it and the ynever switched back to the regular map... to check try this..
Settings ... Map.... on he bottom of screen you will see Map Info .. press it.... it should now say what map is loaded on the gps...
It should have a checkmark in the City Navigator North American NT, if not put one there
Nov 04, 2010 | Garmin nuvi 200W GPS Receiver
Looking to update Maps for old Philips Carin 520 navigation
This model is discontinued and no maps are available any longer for this. It has become a dinosauer. Time to move forward into the micro electronic age of the newer types of GPS with wider screens. 3.5" are obsolete and map makers no longer want to cater for them.
Beware of bargains in 3.5" GPS no updates will be forthcoming
Please rate my help++++Thanks for using FIXYA
Mar 21, 2010 | GPS
Tomtom go730t, switch on and get start up screen then displays "no maps found".
Make sure that you have the map installed first of all, or you have the SD card inserted correctly (if using one).
If that is OK, try resetting the device. To reset your TomTom device, do the following:
  1. Charge your TomTom
    Charge your device for at least 2 hours before trying to turn it on again. Make sure the charging light on your device is on.
  2. Remove the SD card
    If your device uses an SD card, remove it.
  3. Reset your device
    Use a straightened paper clip, or something similar, to push the reset button for 15 seconds. The reset button is located on the underside of the device.
  4. Turn your device on
    Press the On/off button for at least 5 seconds.
  5. Insert the SD card
    If your device uses an SD card, insert the SD card.
Should that still not help, try to download and install the map from TomTom website. Instructions HERE
Hope that helps! Should you have any further questions,please feel free to post them here.
P.S. – I would greatly appreciate a FixYa!rating if the solution I provided fixed or helped you resolve your problem.
Thank you for using FIXYA!
Cheers!
IrishDruid
Oct 25, 2008 | Tomtom GPS
No Maps Found
Everyone with software issues needs to use the tomtom website & enter your problem there someone will be able to talk you through wipeing it & starting over.
http://www.tomtom.com/support/support.php?ID=2
Dec 10, 2007 | Tomtom ONE GPS Receiver
GPS Logo
212 people viewed this question
Top Tomtom GPS Experts
LP
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
