Question about Sub-Zero 642
Sub Zero 642 - Gasket on the Door is really HOT
Is it normal that the gasket along the opening side of the door, nearly the entire highth of the door is always hot? Seems wrong for the inside of a refrigerator to have a part that is producing HEAT.
  • Anonymous Mar 23, 2014
    magnetic door gaskets need replacing
  • Anonymous Mar 27, 2014
    Looking to determine if my side by side 642 sub zero has dual compressors
  • 237 Answers
That is normal and is designed that way to keep moisture from forming water drops on the door seals. The "old days" used electric heaters but most now use the heat from the compressor liquid. If it's really hot you may have dust all over the condensor coils and should be cleaned to reduce the compressors heat output. Other than that, it's normal operations!
Posted on Jan 31, 2007
Problem openning door
when you close the door a reverse cycle fan sucks all the waisted air the fridge has just been exposed to out of the unit so it creates a good seal around the door rubbers this is perfectly normal .
please rate ..
Jul 04, 2010 | Sub-Zero 642
My sub zero 642 just starting making a humming
It is your evaporator fan. When the door opens power is cut to the fan motor.
Apr 29, 2010 | Sub-Zero 642
I have ice forming on back wall above top drawer in refrigerator. Belive seal may need to be replaced. Any other suggestions?
The gasket would be the last thing I would suspect. Is the ice a ball to the left side or is it all the way across? Could be a sealed system issue or a bad thermistor. I would recomend calling a factory authorized servicer for proper diagnosis before putting the money into a gasket. Besides look at the gasket all the wat around for any damage and make sure the door is closeing properly. Isee units with torn gaskets all the time and it doesn't cause ice build up in th refrigerator side.
Jul 02, 2009 | Sub-Zero 642
Sub Zero 642 side by side stainless steel leaks water from right door. evaporator pan is dry, water/ice dispenser door catch basin is dry. Several times per day water collects right under the stainless...
remove the crisper drawers and you will see a drain trough and a drain line . One or both is most likely blocked. If you pull the drain line off the trough usually you can clear it with a turkey baster filled with hot water
Jul 01, 2009 | Sub-Zero 642
I have a 642/0 side by side sub zero. Although
Has the ambient temp around the unit been going up? Depending on what refrigerant you have here the pressure temp relationship will change in the system, also when you add foodstuff, and again when you open the door.
Jun 29, 2009 | Refrigerators
Cannot reopen Sub-Zero 642 freezer door for 50 seconds
Yes, this is normal.  My 642 does the same thing. It seals to be more efficient while trying to cool back down after it has lost heat while open.
Jun 21, 2009 | Sub-Zero 700TR
Door gasket gap
Hi, Try rolling up a piece of paper towel and place it behind the door gasket to stretch it. It might take a few days to stretch.
I hope this helps.
Please let me know if I can assist you further.
Vic
May 30, 2009 | Sub-Zero 700TC Bottom Freezer Refrigerator
Main door handle top section pulls out from bolt on sub zero 642
There is a tiny set screw that holds that in place. It is on the bottom of the stand off and just needs to be tightened.
Nov 26, 2008 | Sub-Zero 642
Refrig lights go on and off intermittently when opening and closing refrig door
check door light switch with ohmmeter. Check for melted insulation near light "terminator". Look for wiring diagram in ziplock behind compressor grille. Second switch at door turns compressor off when door opened. I had these problems with a 695 which I would assume is probably similar in design.
Dec 26, 2007 | Sub-Zero 680 / F
Refrigerators Logo
889 people viewed this question
Top Sub-Zero Refrigerators Experts
Sal De
John Tripp
John Tripp
Steve Allison
Steve Allison
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
