Question about Belling 644 Electric Kitchen Range
Oven not working properly
I have recently taken ownership of a Belling 644 electric oven. When I wired it up it all worked but tripped the fuse box. Now, only the front, right hob and the grill work! I've checked that it was wired correctly and checked at the bottom to the rear of the cooker behind a metal plate to make sure that all of the wires are firmly connected. Any suggestions would be much appreciated.
  • noelie Feb 15, 2008
    Belling oven 644 main oven not heating up any longer but the fan is still
    working anybody know what the problem might be
It may be the oven thermostat needs replacing.
Posted on Sep 22, 2007
MAIN HOUSE FUSES TRIPPED, RESET, OVEN AND GRILL WILL NOT HEAT UP
It would appear that the tripping of the switch has caused some kind of short within the cooker. I would look for the continuity of the heating element.
Most likely the wires leading to the heating element have burnt and will need replacement. If you are comfortable with attempting a DIY, well and good. You will have to open the back panel to access the said wires. It should be easy enough to identify..it will be the wire leadingto the heating coil.
If , however, you are not familiar with these kind of things, I would recommend getting a repair guy to do it for you.
Cheers and good luck with the repair!
IrishDruid.
May 26, 2008 | Belling XOU252 Electric Single Oven
Oven wont work but clock still works
First make sure you didn't trip a breaker. You could have power for the electronics on one side of the 220V and that is why the clock still works. Turn off the breaker and then back on even if it looks on. If it does this again you have a sever problem that will require a service call. If the breaker is tripping it could be other than the oven and if so a new one will work ok unless itsin your wiring.
If this helps you please ratre me accordingly Good luck.
Mar 12, 2009 | Belling XOU252 Electric Single Oven
Recently wired a double oven with isolator switch
Hi, there's definitely a electrical problem.
First, use the bottom oven only for about 15 minutes and check if it doesn't trip.
Second, use just the grill (top oven) for about 15 minutes and check if it doesn't trip.
The reason is sometimes grill elements are corroded and only trip after a few minutes.
Also, if both ovens work ok on their own, then it could be your fuse box not strong enough, or the isolator switch fuse be only 13amp. If your oven is more than 3Kw (check the label on the door for info) then you need a 30amp fuse to hold when both ovens are on.
Cheers
Feb 19, 2009 | Zanussi ZDF490 Electric Double Oven
Belling XOU252 Single Oven Trips Fuses Repeatedly
Hi.
Probably a faulty element, if you feel competent enough, disconnect the feed to the elements in turn, this should eliminate the problem.
Good luck.
Nov 20, 2008 | Belling XOU252 Electric Single Oven
Belling fan assisted ovens
no you can't connect a double oven to a 13a socket!!
needs a proper cooker outlet wired back to the consumer unit
Sep 29, 2008 | Belling XOU592 / XOU593 Electric Double...
Trips out electric
check the wireing on the oven supply line check the breaker it may bu too small or week check ehere the cord is attached to the range most of the time this is where the promblem is
Feb 18, 2008 | Belling 644 Electric Kitchen Range
Oven not working! Belling 614 format
the control modual is bad the oven want work without it
Jan 09, 2008 | Belling 644 Electric Kitchen Range
Broken cooking appliance :( please help
if the fan is spinning then it sounds as though the element has gone. has your fuse box recently tripped? it may have been the blowing element.
Jun 10, 2007 | Belling XOU252 Electric Single Oven
Belling 644 Electric Kitchen Range Logo
405 people viewed this question
Top Belling Kitchen Ranges Experts
Paul Carew
Hjalmer Lamminen
Hjalmer Lamminen
John Tripp
John Tripp
Are you a Belling Kitchen Range Expert? Answer questions, earn points and help others
