Question about Canon FAX-L800 Plain Paper Laser
L800 manual have a few problems with a second hand Canon L800 that I bought recently. Fax worked fine until paper jam. Received fax went into memory, and now cant clear paper jam or print received in memory. If someone can direct me to an online manual, I may be able to do this myself. Any advice appreciated. Have turned off and on several times.
  • Canon Master
  • 6,487 Answers
You can download the user manual for this, just go to this link http://download.canon.it/manuali_operatore/files/L800ugen.pdf
Posted on Dec 02, 2008
Have a Canon FAX-L800 that we want to use on a Telstra Duet line, is this possible? Can't see any mention in the manual.
I'm not sure what you mean but if you are referring to a dual line then no. You cannot have two lines coming into the L800.
Jul 04, 2009 | Canon FAX-L800 Plain Paper Laser
Erased files
the problem is the fax that are stored in memory you will lose anyway.
you will need to do the following to get rid of your error:
DATA REGISTRATION button,
and # button, on the operation panel
go down to number 8
then scroll round to ALL
and then restart the machine and the fault should go.
Hope this helps
Oct 23, 2008 | Canon FAX-L800 Plain Paper Laser
Canon i-sensys fax-L100
The machine keeps in memory only reports of faxes sent or received until the page is full.When the report page is full, the earliest fax is removed to make way for the most recent. Therefore if you sent enough faxes after 4 Apr 08 to fill a page, there will be no record.
Aug 18, 2008 | Canon FAX-L1000 Plain Paper Laser
BARRIE@NORTONBARRIE.CO.UK
RECEIVED IN MEMORY
If the machine receives a fax under one of the following conditions, the machine will not be able to print the received fax and will store it in its memory.
When the problem is resolved as described, the fax stored in memory is printed automatically.
bullet_s.gif Ink is low or has run out while receiving a fax: replace the FINE Cartridge.
bullet_s.gif Paper size/type setting is incorrect: correct the paper size/type setting.
bullet_s.gif Paper has run out while receiving a fax: load the paper and press the OK button.
bullet_s.gif Output Tray is closed: open it.
bullet_s.gif OFF is selected for AUTO PRINT RX: select ON.
bullet_s.gif You pressed the Stop/Reset button to cancel printing of a fax: press the FAX button.
Jul 18, 2008 | Canon PIXMA MX310 All-In-One Printer
Clearing memory on fax
Hi guys
Solutiuon at hand
Open one touch covers, press "Data Registration" press "Set" arrow to "TX Settings" Press "Set" arrow to "Erase Failed Tx" Press "Set" arrow to "On" Press "Set"
Good Luck
The Great Gordini
May 09, 2008 | Canon FAX-L800 Plain Paper Laser
Alarm setting
The alarm sounds for only 5 seconds.When you receive a fax and the paper jams, the fax will be received into memory. When it has finished receiving the fax, the alarm will sound momentarily. When you remove the jammed paper, the fax will print automatically.
Feb 26, 2008 | Canon LaserClass 2060P Plain Paper Fax
Canon fax l800
Unplug the power cord for 10 seconds.
Jan 25, 2008 | Canon FAX-L800 Plain Paper Laser
Saving fax numbers
yes, you may.
If the Fax machine has a Memory function press it.
then type the number then enter.
or read the manual..
or visit www.canon.com
Dec 11, 2007 | Canon FAX-L800 Plain Paper Laser
How to set ringtone when receiving fax Canon Fax L800
RINGER IS SET TO SILENT MODE,PLEASE CHANGE IT HAPPY FAXING OMNIPRESENT
Sep 19, 2007 | Canon FAX-L800 Plain Paper Laser
Received in Memory
check the paper sensor at the bottom of where the paper comes out! this has a tendency to pop out of its little holder. Use a flashlight to see it! the sensor is blocking the beam.
Dec 07, 2006 | Canon CFX-L4000 Plain Paper Laser Fax
Canon FAX-L800 Plain Paper Laser Logo
730 people viewed this question
old marine
old marine
