Question about Sakar Black Wireless Optical Mouse (021331700506)
Mouse left mouse button keeps hanging up.had to change over to right button, very inconvient.
0 characters
1 Points
I want to change mouse from right hand to left hand use?
It's very easy. Just follow the following steps!
If you are using windows 8, press the windows button on your keyboard(the one left of left 'alt') and type "change mouse click settings" , just click on settings tab on right and click on the first option that appears.
Just change the left or right orientation as per your choice now and click on apply and ok.
1. goto start->control panel
2. Click on mouse(or hardwares-> mouse if in category view)
3. click on buttons tab
4. select required orientation and click on apply and ok
Aug 06, 2013 | Logitech Cordless Mouse
Can a compaq mouse is converted from right hand to left hand?
get into the control panel, and click on the mouse and keyboard icon.
Then click on the hardware and sound icon. Right click on the mouse icon and you will be able to change the mouse settings.
Aug 08, 2012 | Compaq Keyboards & Mice
Mouse sensitivity is slow.i want more then more speed of mouse pointer,i already search but nothing...pleas SIR
These are the steps to change the mouse sensitivity
Click on the "Start" button in the lower left corner of your computer screen to open the Start menu so you can change the mouse sensitivity. Locate the control panel link on the right-hand column of the Start menu and click on the link.
Wait for the Control Panel manu to open and then locate the "Search Control Panel" bar at the top of the menu on the the right-hand side. Type in "mouse" (no quote marks) in the window and locate the mouse menu at the top, left side of the menu.
Locate the link that says "Change Button Settings" at the bottom of the mouse menu and click on the link. When the mouse properties window appears, locate the tabs at the top of the window and find the one that says "Pointer Options."
Click on the "Pointer Options" window tab and locate the heading that says "Motion." In the Motion section, find the slide ajustment bar that is labeled "Slow" on the left side and "Fast" on the right side of the bar.
Move the bar according to your desired speed and preferences, and click on the "Apply" button on the lower right-hand side of the window.
Click the "OK" button on the lower left-hand side of the window, which will take you back to the default window. Verify that the mouse sensitivity is according to your needs and readjust if necessary by repeating these steps.
Good luck
do rate the solution if got help
Dec 07, 2010 | HP P2360AA Keyboard/Mouse
I've got a optical mouse 3000, and a bunch of batteries in the junk drawer, I'm sure at least one of them has good life in them, but the mouse keeps flashing red....also it seems to work when I right...
The red light is connectivity to the dongle on the PC.
Check your mouse settings in Windows for the left mouse button settings.
Does the mouse move on the screen?
You can try reversing the mouse buttons to see if the button is defective. If you swap the buttons and now right mouse clicks do not work, the button is defective.
Nov 29, 2009 | Microsoft Wireless Notebook Optical Mouse...
Change mouse clicks
Please click on control panel and click on mouse settings. The first tab would help you to swap the right and the left buttons of a mouse.
May 27, 2009 | Keyboards & Mice
I can't figure out how to change the batteries in the mouse.
right behind the right and left buttons apply slight pressure and move to either side to access the batteries
May 26, 2009 | Logitech Wireless Freedom Keyboard and...
Mouse freezes when holding down the LEFT and RIGHT buttons
check out your mouse setting in control panel/mouse
May 10, 2009 | Laser LM8000WR Mouse
Want a left handed mouse
To change mouse settings in XP for left-handed users:
Click Start and click Control Panel.
Double click the Mouse applet.
Verify that the Buttons tab is selected.
Select the Switch primary and secondary buttons option is selected.
Click OK.
May 07, 2009 | HP Wireless Optical Mouse
I accidentally turned on the wireless 5000 mouse magnifier and can't get rid of the magnifier. How do I turn it off?
Normal 0 The button on the left side of the mouse when pressed turns the Magnifier on/off. Just press it again and it should turn off.
I kept turning it on accidentally so I went in the control panel and switched the Magnifier to the right side. I added that below so you can set your mouse buttons.
Go to Control Panel and click on the Mouse icon. Then the mouse properties will appear showing the mouse buttons. In the Left column is the button settings. The bottom one is the Right Button, which is set for Magnify. Whenever you hit the Right Side button the magnifier will turn on. To turn it off, hit the Right Side Button and off it goes. You can change any of the button settings by clicking on the drop down.
Hope this helps. Bud
Feb 17, 2009 | Microsoft Wireless Laser Desktop 4000...
Ibm wireless mice model ro07uo
Go to control panel and click on the Mouse icon. then when you get the Mouse Properties window, go to Buttons and go to the Left Button and using the drop down change the key to function as you desire. You will also have to reset the right button to use to double click to open programs. Hope this helps. Bud
Sakar Black Wireless Optical Mouse (021331700506) Logo
16 people viewed this question
Top Sakar Keyboards & Mice Experts
micky dee
Brian Sullivan
Brian Sullivan
Are you a Sakar Keyboard and Mice Expert? Answer questions, earn points and help others
