Question about Brother MFC-465CN InkJet Printer
MFC 465N - Cannot load the MFC Suite
When trying to instal this printer and scanner the disk stalls after connecting the USB cable to the computer. It won't let me go any further. I managed to connect the printer from control panel but cannot load the scanner or the MFC Suite. I am using Windows XP. Can you please help.
  • Anonymous Dec 06, 2008
    I have a similar problem. I get to the "connect cable" screen and can't get to the next. If you hear of a solution, please drop me a line at : . Thank-you and good luck!
  • yinxingsheng Feb 15, 2009
    mine is vista doesn't work either !
  • 320 Answers
If you follow the directions closely you should be able to install the mfc suites w/paper port brother tech
Posted on Jan 19, 2009
I downloaded printer driver for brother mfc240c, but even after install, I get a message that says the driver isn't installed.
Open the printer and scanners folder an delete all the devices (Brother Printer, Brother Fax, Brother PC-Fax if installed). Point to device an right click the mouse button.
Restart the computer.
Download the software from Brother Solutions Center. Download the whole suite not just the drivers. Make sure you select the software that is compatible with your version of the OS :Windows 7 32 bits, Windows 7 64 bits, Windows 8 32 bits, etc.
Install the software. If you are going to use a USB cable to connect the MFC to the computer, install a local USB printer. If you are going to use Ethernet network cable, install a wired network printer, and if wireless connection then install a wireless printer.
If you have problems finding or attributing an IP address to your printer (for Non-USB connections) there is Brother program that helps you attribute an IP address. You will find it on the same page as the software suite on Brother's site.
Nov 07, 2013 | Brother Multi-Function Center MFC-240C...
Need to hook up a brother MFC-210c so it can fax
Install the software (Brother MFLPro0 relevant to the printer. If you do not have the original CD download the appropriate suite from Brother Solution Center.
When you install the software you will be asked to choose USB, or Local Network. You can always install the USB and connect the printer to the calculator through USB. Different installations for different connection types (USB, LAN)
After you configure the software, you can open the Control Center 3 software and use the fax.
To be able to fax, you need to connect a telephone cable to the port marked line. After you do try pressing the unhook button. If connection to the phone line is correct you will hear the tone.
The MFC can fax without being connect to a computer, just the phone line.
Jul 30, 2012 | Brother MFC-210C All-In-One Printer
I lost my disk and need info to put in new computer
Visit the Brother Solution Center for your country/area of residence and download the Brother software suite relevant to your machine: Model number, Operating system (Windows, or linux, 32 or 63 bits) and install it on your computer. You must choose the type of connection (USB or LAN). Install the USB or NEtwork software. After installation, connect the printer (through a USB cable if you chose USB installation, or ethernet cable if you chose Network. then connect the MFC.
For the scanning software (ScanSoft) you will have to install it from the original CD. If you no longer have it you can buy some scanning software or install free software from the web. Several applications (Word, Acrobat) can scan by themselves. You also have some free OCR software; FreeOCR, PaperScan Free, etc.
Jul 30, 2012 | Brother MFC-5890CN All-In-One InkJet...
I want to add orconect a MFC-7440N Brother Laser Copier ,fax, scanner to my Dell Computer I dont have the disk to install please help me
Before you start, ensure you have a USB cable to connect the printer to the pc.
Use the above link to download the necessary software drivers to run the printer, scanner and fax. Select your operating system.
May 28, 2011 | Brother MFC-7440N Laser Printer
How to connect my brother mfc-8460N scanner can't
You will need to use a cable to use the scanner.
Either a USB cable to connect directly to computer or an ethernet cable directly to router, then you will need to install the driver software.
Nov 12, 2009 | Brother MFC-8460N All-In-One Printer
Scanner - MFC 7420
Get the manual, and you may need the install disk too. Look carefully at the usb port on the copier so you get the correct usb cord.
Mar 31, 2009 | Brother MFC 7420 All-In-One Laser Printer
Brother MFC-240C
lift the scanner cover until locks into the open position.
you will see the usb socket. plug it
route the cables through the trench out the back of the printer
Dec 19, 2008 | Brother MFC 240C All-In-One InkJet Printer
I cant find the machine DCP-7020 but I think this machine is the same with model MFC-7420 if you have the installer CD follow these steps:
For USB Interface Cable Users
For Mac OS® 9.1 to 9.2
& Software
1 Turn off and unplug the MFC from the AC outlet and disconnect it from your Macintosh, if you already connected an interface cable.
2 Turn on your Macintosh.
3 Insert the supplied CD-ROM for Macintosh into your CD-ROM drive.
4 Double-click the Start Here OS 9.1-9.2 icon to install the printer and scanner drivers. If
the language screen appears, select your language.
5 Click MFL-Pro Suite to install.
6 Follow the on-screen instructions, and restart your Macintosh.
7 Connect the USB interface cable to your Macintosh, and then connect it to the MFC.
DO NOT connect the MFC to a USB
port on a keyboard or a nonpowered
USB hub.
8 Plug in the power cord and turn on the MFC.
9 From the Apple menu, open the Chooser.
10 Click the Brother Laser icon.
On the right side of the Chooser, select the
MFC to which you want to print.
Close the Chooser.
The MFL-Pro Suite, Printer driver and Scanner driver have been installed.
To install Presto! PageManager, click the
11 Presto! PageManager icon and follow the on-screen instructions.
Presto! PageManager has been installed and the installation is now complete.
You can easily scan, share and organize photos and documents using Presto!PageManager.
Dec 11, 2008 | Brother DCP 7010 Multifunction Laser...
Wont work
The issue you have posted does require little more information in order to isolate the issue to fix it. Information like have you installed the printer driver and connected the printer cable to the system in your system for the printer to communicate, are you getting any error messages when you are trying to scan or print, weather you have used the printer earlier and it was working fine till the recent past or it was just being used for sending faxes only and printing and scanning was not tried earlier, However let me provide you few steps that you cold try to fix the issue.
  1. Click on start point Control Panel and click on it.
  2. In the control panel window click on the icon labeled “System”
  3. Click on the Hardware option at the top and then click on Device manager.
  4. On the device manage page check if you have any devices under “Other Devices option with a YELLOW ! mark, if so right click on the device and left click on uninstall.
  5. Close all the windows and then insert the Driver disk for the Printer in the CD/DVD Disk Drive to install the drivers for the printer.
Note: At this point of Disconnect the printer cable if it is connected to the system tower, and do not connect the cable until the installation wizard prompts you to do so.
If you do not have the Printer driver disk handy then you can download and install the printer driver form the link below:
Brother MFC-3340CN Printer & Scanner Driver USB (Free Download)
Brother MFC 3240C Printer & Scanner Driver USB (Free Download)
  1. During the installation the wizard will prompt you to connect the printer USB cable to the system tower, so go ahead and connect it.
  2. Once the installation is finished restart the computer.
Should you require any further assistance regarding the
printer or even require assistance regarding any other
computer related issue in future please feel free to
contact me I will be more than glad to assist you.
Malik Khan
Jan 30, 2008 | Office Equipment & Supplies
Installation problems
How do you connect the mfc to your computer/laptop? In case you use usb make sure that the cable isnt longer than 3m and it is connected directly to your comp/lap usb. Do NOT connect to a hub. This causes a prob with the scanner.
In case you have it installed within a network (RJ45) there is a guide which can be download from brother homepage of your country. It explains the settings and installing for the scanner and printer.
Oct 31, 2007 | Brother MFC-5840CN All-In-One InkJet...
Brother MFC-465CN InkJet Printer Logo
182 people viewed this question
James Cagle
James Cagle
Jim Keysor
