Question about HP iPAQ rx5935 Travel Companion Pocket PC
Hp pocket pc.Travel companion,turns on,but can't view anything
Turns on,on a blue screen,can't view ipaq,gps or anything.
  • 67 Answers
I don't know how long you've had that unit. So the question is have you done any updates on it since you've had it.
An update most likely will fix most problems.
Follow this link to get to your devices' support page. It would be a good idea to bookmark it and register so they can send you any needed update alerts for your iPaq.
Posted on Dec 02, 2008
I want to view pdf files on my hp rz 1715. Is that possible?
Yes it's possible, at the Companion CD from HP of your pocket PC is the installer for Acrobat Reader Application.
Feb 28, 2011 | HP iPAQ RZ1715 Pocket PC
I am considering buying a HP IPAQ aviation 5910 GPS glass cockpit. Are they a good product? Where can I get info on them?
i would not buy another ipaq if someone gave me the money..the last two i bought (600.00 ea) both took a **** right after the warranty ran out....
HP did nothing to help even though it was within a day (how lucky i am) of expiring.
Aug 17, 2010 | HP iPAQ RX5915 Travel Companion GPS...
Ipaq 1940 losing programmes during main battery changeover
  1. Plug the charger adapter into the charging port on the bottom of the HP iPAQ Pocket PC.
    Figure : Charging the battery
  2. When the power indicator on the top of the HP iPAQ Pocket PC turns solid amber, the unit is fully charged and can be disconnected from the AC adapter (approximate time to fully charge a unit is four hours).
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.In the event of a low backup battery warning, charge the unit immediately before removing the main battery to avoid data loss. To view the amount of charge left in the backup battery, tap Start, Settings, the System tab, and Power.
Charging with the universal desktop cradle and AC adapter Use the universal desktop cradle to charge the HP iPAQ Pocket PC, or synchronize the HP iPAQ Pocket PC with a computer.
Follow these steps to charge the HP iPAQ Pocket PC using the universal desktop cradle:
  1. Plug the AC adapter into an electrical outlet and connect the other end of the AC adapter to the AC connector on the universal desktop cradle.
  2. Connect the serial or USB cradle cable into the appropriate port on the desktop PC.Figure : Connecting with the cradle
  3. Slide the bottom of the HP iPAQ Pocket PC into the cradle and push firmly to seat it.
CAUTION: To avoid damaging the HP iPAQ Pocket PC or the cradle, make sure the pins are aligned before pushing the HP Pocket PC into the cradle.
    Figure : Charging with the universal desktop cradle
  1. AC adapter into electrical outlet
  2. AC adapter into universal desktop cradle
  3. HP iPAQ Pocket PC into cradle
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.There are stabilizers located in the universal desktop cradle that assist in aligning the unit when there is no expansion pack attached. When placing the HP iPAQ Pocket PC with an expansion pack attached into the universal desktop cradle, the stabilizers will be pushed down by the expansion pack. To release the stabilizers for use without an expansion pack, press the button on the back of the cradle.
Charging with the optional USB Autosync cable Charge the HP iPAQ Pocket PC using the optional USB Autosync cable by connecting the Autosync cable to the HP Pocket PC and the personal computer. The HP Pocket PC will be charged using power from the personal computer.
For more information on charging the HP Pocket PC using the optional USB autosync cable, from the Today screen, tap Start, Settings, the Systemtab, Power, the USB Charging tab, Settings, and Help.
Charging a low battery The HP iPAQ Pocket PC will not turn on if the battery has a low charge (less than 3.2 Volts). Fully charge the battery prior to using the HP Pocket PC.
If the charge on the battery goes below the 3.2 Volts as a result of not being connected to the universal desktop cradle or the AC adapter, no damage will occur to the battery. However, the HP iPAQ Pocket PC charge indicator light will not flash until the battery reaches the minimum charge of 3.2 Volts and a normal reset is performed.
Follow these steps to charge and reset the HP iPAQ Pocket PC:
  1. Connect the HP iPAQ Pocket PC to an A/C power supply.
  2. Charge the battery to the minimum level of 3.2 Volts (this will take 5 to 30 minutes depending on the current charge level).
  3. Perform a normal reset by using the stylus to lightly press the Reset button on the bottom of the HP iPAQ Pocket PC.
  4. Turn on the HP iPAQ Pocket PC.
Keep the HP iPAQ Pocket PC connected to the universal desktop cradle or AC adapter when it is not in use.
Aug 25, 2017 | HP iPAQ H1945 Pocket PC
Freezing at the "HP iPAQ Pocket PC start-up" and won't advance any further. (think that it pushed up against something in my bag, and perhaps maxed the memory?). Not at a point where ActiveSync can...
I had same problem. Finally got mine sorted!!
Try a full reset. Hold the quick launch button and the rotate screen button simultaneously (top and bottom of 4 buttons on left of device) and then use stylis to press in the reset button (on top edge just left of SD card slot). Keep depressed until it resets then release the 2 buttons and then release reset button.
It will appear to do the same but it tells you at the bottom it is doing a reboot or something. After 30 secs or so it then goes past and gets to the screen align screen.
You might loss settings but it worked for me
Jul 25, 2009 | HP iPAQ RX5915 Travel Companion GPS...
Won't get through blue HP startup screen.
try taking battery out for 6hours then reinstall and hard rest.
this works on mine. bob
Jul 07, 2009 | HP iPAQ rx5935 Travel Companion Pocket PC
Hp ipaq rx5935 hangs at the end of the HP booting sequence
remove battery for 6 hr and reinstal and then hard reset.
bob.
Jun 20, 2009 | HP iPAQ rx5935 Travel Companion Pocket PC
IPaq rx3715 locked up
try leaving battery out overnight.
Sep 07, 2005 | HP iPAQ RX3715 Pocket PC
HP iPAQ rx5935 Travel Companion Pocket PC Logo
634 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
