Question about Seiko Hc500 Protape 16' Electronic Tape Measure
CANNOT LOCATE 9 volt battery replacement access panel for
Seiko Hc500 Protape 16'.  how to access battery for replacement ?
Need battery number for Seiko vivace ladies watch no 440180
  • Remove back
  • Locate battery and note installation details.
  • Identify type (number)
  • Obtain replacement battery
  • Install new battery
  • Check operation
  • Reinstall back
  • Set time, etc.
OR,
Pay a jeweler a few bucks to replace it
Oct 25, 2016 | Seiko Watches
How can find a electrical wire in closed wall that not connected
If you have access to one end of power cord then its possible to
trace the wire.
You will need Circut alert tester ( this can be found in your local hardware store or electricien) and small 6 or 9 volt batterie.
Plug the batterie to the end of the wire you have access.
(Make sure its not connect to anything.)
Take your tester pass it over the wall or ceiling.
You will here biping sound when it find the 6 volt current.
Then follow the sound up to the end.
(Sughgestion: Used a certified electricien their have all the tools
Sep 11, 2014 | Ovens
Battery replace
small door on back side (opposite meter), located at the rear of the tape - press down with thumbs (toward center of case) and back - door pops open - 9v battery underneath
May 06, 2014 | Seiko Hc500 Protape 16' Electronic Tape...
2010 flhx battery fully charged but starter drags bad then clicks. Jumped power from car, still does the same thing.
Hi Anonymous, perform the following tests:
1. Fill acid type batteries to proper levels.
2. Charge battery overnight at 1-2 amps you need 12 volts or better after charging.
3. Make sure all connections are clean and tight especially the negative cable at both ends.
4. Hook up volt meter to battery and start engine, if meter falls below 9.5 v replace battery.
5. With engine running at 3600 RPM battery should read 14.3-14.7 volts if not continue tests.
6. Unplug voltage regulator from alternator at crankcase by front of primary cover.
7. To test voltage regulator go to: https://www.youtube.com/watch?v=F8EjV0IjW9Q
8. With ohm meter, one lead grounded, touch alternator pin meter should read infinity, if not replace stator.
9. With ohm meter, both leads touching alternator pins meter should read 0.1 to 0.2 ohms on 1989 and later models. 0.2 to 0.4 ohms 1988 and earlier models, if not replace stator.
10. With volt meter set on AC scale, both leads touching alternator pins meter should read
16 to 20 volts AC for every 1000 RPM'S 1989 and later and 19 to 26 volts AC for every 1000 RPMS. If not replace rotor. Good luck
Jan 01, 2014 | 2010 Harley Davidson FLHX Street Glide
Ampage for 9-volt alesis sr-16 drum machine adapter
Here is a link to a discussion about this that will help:http://www.soundonsound.com/forum/showflat.php?Cat=&Number=679914&Main=679565 A 9 volt A.C. 3.2 amp power supply should work for you. Just remember A.C. not D.C. is required.
Dec 10, 2010 | Alesis Sr 16 Stereo Drum Machine
MY TALKING TAPE KEEPS SAYING "ERROR. TAPE IS NOT IN". WHERE CAN I HAVE IT REPAIRED ?
Hi...problem with your Mesuring logic IC anonciator... take off your battery for reset...also check if your battery are low ...unit will fail to read correctly due to low battery....
Oct 14, 2010 | Seiko Hc500 Protape 16' Electronic Tape...
Need to replace the 9 volt battery in my kenmore freezer chest.
The manual does not tell you where its at but the 9-volt battery holder is located on the lower left side of the freezer. There is a small panel about 9" off the floor and towards the front of the freezer (left side facing). cd6fa25d-9930-4b53-8883-c0ebcde8413d1.03.01
Aug 18, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Ilo tv quit - will not turn on
The Problem is with the Capasiters in the power supply bord a total of 9 caps have to be replaced the power supply bord is the one on the right side of the tv in the back where the power cable enters the caps values are 35 volt 1000uf x2 35 volt 470uf x3 16 volt 1000uf x3 and 16 volt 470uf x1 after replaceing thses caps the tv will work like new... i hope this helps.
Apr 09, 2009 | Televison & Video
Seiko Hc500 Protape 16' Electronic Tape Measure Logo
42 people viewed this question
Top Seiko Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Seiko Measuring Tool and Sensor Expert? Answer questions, earn points and help others
