No cold air
My aircon just got regased , blow cold for 3 days and that was all
  • 306 Answers
You have a leak in the system sounds like a big leak should be easy to find. But in this case better get a Licensed Heating and Air person. They can find the leak and silver braze it and recharge the unit. let me know how it turns out. ken
Posted on Dec 02, 2008
99 s40 volvo air con fully replaced but still not blowing cold air
Your compressor may not be engaging, could be activation switch, a relay or the compressor itself if you do not hear it engage when activating A/C.
Dec 22, 2013 | Cars & Trucks
The a/c on my 2003 honda accord will all of a sudden stop blowing cold air. I already had the filter changed thinking that was the problem. The mechanic is having a hard time figuring out what is wrong...
have you tried refilling the aircon gas ?
It goes empty after a while.
The reason for cold then not cold is because it is a system that works in reverse of your radiator.
The gas cycle through the system. goes through the radiator of the the aircon system (not the same as the one for the engine). there is extracts the heat out of the air. the air is now cold and pushed into the car.
the warm aircon gas the made cold further along the system but the dont have enough in the system.
imagine athletic ruynning around a track. all 20 are bunched up together. there is w spot light in the centre of the infield shining on you.
the track is your aircon system.
the spot light the air coming into your car.
You are the car
The athletes are the aircon gas.
When they run between you and the light the air is cooled off and you are getting cold air.
now of goes the air (athletes) around the system and till they come along again you get hot air.
Now fill up the aircon system (put more runner on the track and voila, less light reached you cos there is more gas in the system.
However if you refill it and after a day or even just a week it the same again you have a leak in your system and will need to have it looked at by someone specializing in car aircon repairs.
Oct 11, 2010 | 2003 Honda Accord
Heater warms up in morning but over the day only gives cold air despite being set at 22degrees. VW dealership says when set at 22degrees it will warm up to 30degrees and then introduce cold air to bring...
vw fit 3 types of aircon,
1.full climate control (you set temp is stays there)
2.climatronic (as your dealer said.....)
3.aircon std (cold draft)
you cannot change whats fitted to another type.
Apr 08, 2010 | 2004 Volkswagen Eurovan
Air Conditioner will not blow cold air (only slightly cool air) but air compressor is working. What can be wrong? Fan speed works fine.
chances are it needs regasing/presureising,unless you use a/c for about 15 mins a day(on average) a/c gas needs re charging every 4/5 years.
Mar 31, 2010 | 2001 Lincoln Town Car
Aircon regasing
There is a specification plate on the base of the unit. It will have the refrigerant type and quantity listed. The leak should be found and repaired before re-charging with refrigerant.
1993 model could be r-12,r-22 or r-134a.
Oct 13, 2009 | Coleman Heating & Cooling
Aircon works but blows hot air
I had the same problem (during Summer!!) - If you take the Fan/A.C/Temp Control panel off, you'll probably find the plastic bracket that the control cable mounts to, is broken. I just used 3 zip-ties to hold everything in place. 30 minutes work, & 50c parts!! No problems since.
Nov 12, 2008 | 2001 Daewoo Nubira
My 2004 Chevy Tahoe LT (40,000 miles)aircon blows geart cold air out of the drivers side and rear blows geart cold air, but the passenger side only blow hot air. I have cycled the air on and off, tried it...
Temp. actuator stuck on heat , probably . Manual or automatic climate control . Electrically controlled temp actuator , or the door is stuck in heat side.
Sep 16, 2017 | Chevrolet Tahoe Cars & Trucks
Heating & Cooling Logo
70 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
