Question about Akai CF2791 27" TV
Blank menu frame overlays TV picture & keeps returning
This problems occurs on a CFT2726 (this category matched best). At certain times, the center part of the TV screen is covered by a black rectangle that exactly matches the size & position of the setup menu. The remote "exit" key makes it go away, but only momentarily before it reappears.
  • Glenn Buskirk Feb 12, 2007
    Learned this is due to closed captioning. The TV offers Text Mode and Closed Caption mode. In text mode, apparently, the CC text is displayed in this box on the screen. I believe some stations, sometimes, transmit an empty or blank Closed Caption signal. This appears as an empty black box on the screen. The fix has been to disable Closed Caption, or set it to the Closed Caption mode where it appears as a scrolling sub-title.
  • hboy407 Nov 19, 2008
    i have the same problem with my tv also. i have the big black box that covers almost half the screen and the menu does not give me a option of turning cc0ff. all it gives me is something to do with txt and captio. ie cc1 cc2 . how do i remove this black box
    Genius:
  • 1,694 Answers
Activate CC/Text function.If CC1 is on,CC2 may be off position.The key to this scenario is understanding both on and off of text box as well as cc on and off.
Posted on Oct 05, 2007
SOURCE:
How do you get it out of 3d what do I adjust, its not a 3d tv
This is an color projector alignment issue. Many projection TVs have a menu item in the video or picture setup that will produce a grid overlay on a black screen of Red, Green and Blue. You use the <, >, up & down buttons on the remote or the TV to move each color (one at a time) directly on top of each other and maintain straight up and down / left and right lines. Once you do this, the picture will be in focus and there will be no more colored "3D-like" ghosting. If you are unable to move the colors far enough, there may be an issue with certain integrated circuits inside the TV that can be challenging to remove and replace. More make and model number for your TV would be required however.
May 21, 2014 | Televison & Video
Vizio E371VL screen won't come on
most certainly bad capacitors in the power supply unit,inside the tv.look for buldged capacitors and replace with same kind.cheap fix if you can do it.requires removing the faulty cap and replacing with new one.most cost very cheap
Mar 12, 2013 | Vizio L32 32 in. LCD HDTV
How do i erase individual pictures from my camera?
You need to hit the 'menu' button.
Then hit the 'forward arrow' button
Then the 'backward' arrow (center big button).
(this will return you to the saved pictures)
From there you will see the 'erase' icon.
Choose frame (individual pictures) or all
frames (all pictures).
Your owners manual could help.
Nov 18, 2009 | Olympus FE-370 Digital Camera
Samsung 40 inch LCD LNS4092D No Picture
You need to check the back light is still on when the screen is blank (check through the back).
If the back light is on, need to change the Powwer Board.
but,
no back light, need to change the inverter.
Feb 06, 2009 | Samsung LN-S4092D 40 in. LCD HDTV
Leaves blank TV screen when Return button operated
It sounds as though the unit is actually recording a DVD, but is getting no incoming signal to record. What is your recording source? Satellite and receiver? Antenna? Cable box? In the set-up menu, be sure you have chosen the proper input source; i.e., recording from where? You may be able to access that menu through the Function button on the remote, AFter setting that menu, be sure to press Return to restore the recorder to the ready mode. If you are using the RF input for recording, be sure that is selected as well, as opposed to L1 or L2. The input channel must match the output channel on your receiver, usually channel 3 or four. What is the model number?
Dec 02, 2008 | Sony RDR-GX300 DVD Recorder
Picture setting regularly changes to dynamic from standard
You need to change the option throgh the service mode.
You can not access that mode without permission from Samsung.
better to contact Samsung call center.
Nov 18, 2008 | Samsung LN-T4661F 46 in. LCD HDTV
Samsung HP-T5043 blank/black square in center of display
turn off the closed captioning. it is set to a text mode which only certain stations use with their closed captioning. use the tv remote menu key and find closed captions and turn it off
Apr 13, 2008 | Samsung HP-T5044 50 in. Plasma TV
AKAI CFT2726 picture sides cut off.
If it is a picture tube type TV not a plasma or lcd try degausing the picture tube. I think Radio Shack carries degausers or find the plans for one on the net.
Feb 22, 2008 | Televison & Video
Convergence and audio problems
1)replace convergence IC's w/best quality. re-align as needed. 2)recheck audio,source and selections in menu. PVAT!
Sep 29, 2007 | Toshiba TN55X81 55" Rear Projection...
Akai CF2791 27" TV Logo
82 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
