Question about Sony HT-DDW740 System
Tuner Hum on Sony HT-DDW740
I inherited a Sony HT-DDW740 that gives me a very bad audio hum when I select the AM or FM inputs. The CD input and others sound clean. I am wondering what the power supply situation is that feeds the tuner(s) and if there are any known problems with capacitors, voltage regulators on this model.
  • groucho99200 Dec 08, 2008
    Your diagnosis was right on the money. It took a bit of time to get to it, but when I did within 30 minutes it was working as it should without the constant tuner hum. My thanks and compliments..
    Scholar:
  • 107 Answers
Check electrolytic capacitor C899 100uF 35V in STBY PCB
Cheers
Posted on Dec 02, 2008
Str-de985 humming noise only when using FM tuner. Everything else works fine with no humming noise
Have you got a FM Antena hook up to it for the FM ,Sations, If not that could be causeing it to hum.
Dec 06, 2012 | Sony STR-DE985 Receiver
Nad 7140 fm low frequency hum
This is probably a 60 cycle hum and the problem is more likely confined to the am/fm board, there is a bad ground due to poor solder joints, broken ground wire, an open capacitor, this may not be easy to find, but it is a start.
Apr 22, 2012 | NAD 7140 Stereo Receiver With Phono Input
I have Sony FM Stereo, FM-AM REceiver HT-DDW740. I have connected them per the diagram but I cannot get any sound. I get a message SPK OFF on the screen. Is there someting that protects and trips all...
Please make sure that the connections are secure and proper.
Make sure that the sound is not muted.
Make sure that you've selected the proper input by INPUT MODE button.
Remove and reconnect the source.
connect a different device and check
check whether you're getting sound when listening to radio.
Jan 22, 2011 | Audio Players & Recorders
Subwoofer hum from STR-DH800
That points pretty much to a bad shield on the cable. Have you tried another one? Another thing to try is to rotate the AC power cord on the sub (if it has one). Sorry, too lazy to look it up.
Dec 29, 2009 | Sony STR-DH800
Can't change FM input mode! Stuck at analog...
Tuner is only analog. As for the Video 1 input you need to go into the menu and change it to the digital port you want to use (optical, coaxial or HDMI) you can set only one input to each digital input port.
Nov 30, 2009 | Sony STR-DE597 Receiver
Pioneer vsx 3000 plays fine, but the radio function hums
If memory serves correct, the VSX-3000 is from the late 80's. They are good receivers from that era. From your description, it appears the tuner module could have issues, since only the AM/FM has a hum. If all other inputs sound well, it points the the tuner module. These modules are not easy to repair (PCB with SMD highly tuned parts), and are easiest and cheapest to replace. Many VSX models of that vintage use the same part. Not sure how easy it would be to find one. They are a small PCB enclosed mostly in a silver shielding, with one or two connectors from the inside and screwed to the back of the receiver, where the antena connection is.
Good luck
Jul 29, 2009 | Audio Players & Recorders
Electronic hum
Hey there,
What I think is the problem here is that your A/V receiver may have a blown preamp for the turntable input. Or, although less likely, assuming that both channels sound normal when the receiver is set to a different input such as an FM tuner, there could be an impedance mis-match between the turntable's output and the reciever's input. But, the goal is to try simpler (and much more inexpensive), methods first. Try replacing the cable that connects your turntable to the receiver. If no difference is heard, then we should take another diagnoses.
Regards,
Hortona
Mar 25, 2009 | Pioneer Audio Players & Recorders
I have a hum or buzz on AM and FM bands only.
I had the same problem, but it is not the tuner module! An exchange of capacitor C899(100μF/35V) on the standby board has resolved the problem. Under a dollar from an electrical store and you are all sorted. 10 minute fix for those with a soldering iron.
Feb 18, 2009 | Sony STR-DE685 Receiver
How to connect new HD cable box to receiver
HI:
You are using a new HD Cable box, that are using componet video cables for HD, Unfortunetly this receiver does not have componet inputs, so you will just have to run the audio from the televison directly to the receiver by connecting the video out and audio out from the television to the receiver's video Input one. This will require a normal RCA composite cables yellow,red,white. Connect one end of each of the cables to televisions output terminals, and the other to the input one on the receiver. Note: Your TV might have a seperate term called Monitor out, Connect the yellow here, and the red and white to audio out. You can do the same for the DVD but you have to use the same cables,Also the television will not display HD picture this way as this is not a HDTV Receiver. If you just want TV sound to the receiver then do not use the video(Yellow) cable just use the audio out terminals from the tv and connect to Input one on the receiver. you can do this with the cable box also but you have to use RCA type cables . If you want the full HD experience then a new up todate receiver is necessary.
Dec 06, 2008 | Sony HT-DDW740 System
Sony HT-DDW740 Tuner Hum
Hi:
On the stanby power supply replace or have replaced C899 with a 100uf 35V capacitor, this capacitor goes bad and produces hum in the supply voltage to the AM FM circuits.
Dec 02, 2008 | Sony HT-DDW740 System
Sony HT-DDW740 System Logo
171 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
