Question about Sony HT-DDW740 System
Sony HT-DDW740 Tuner Hum
I get a very noticeable hum when I select either the AM or FM input of this tuner. The CD input and other inputs sound clean, so I am wondering if there is any information about a power supply that feeds only the tuner module that could be causing this, ie a bad filter capacitor or voltage regulator. Any suggestions?
  • Anonymous Dec 03, 2008
    I have the same problem with my Marantz 125. However, blowing the thing out with CO2 and then spraying electronic contact cleaner through the circuit boards has at least got the tuner itself working again -- prior to this all it was do was hum.
    It sounds like the B supply may be going. Perhaps that is what's happening to your tuner as well.
    Best regards,
    Jimmyblues
    Genius:
  • 1,112 Answers
Hi:
On the stanby power supply replace or have replaced C899 with a 100uf 35V capacitor, this capacitor goes bad and produces hum in the supply voltage to the AM FM circuits.
Posted on Dec 21, 2009
2 Suggested Answers
quang123
  • 107 Answers
SOURCE: Tuner Hum on Sony HT-DDW740
Check electrolytic capacitor C899 100uF 35V in STBY PCB
Cheers
Posted on Dec 02, 2008
Str-de985 humming noise only when using FM tuner. Everything else works fine with no humming noise
Have you got a FM Antena hook up to it for the FM ,Sations, If not that could be causeing it to hum.
Dec 06, 2012 | Sony STR-DE985 Receiver
I have Sony FM Stereo, FM-AM REceiver HT-DDW740. I have connected them per the diagram but I cannot get any sound. I get a message SPK OFF on the screen. Is there someting that protects and trips all...
Please make sure that the connections are secure and proper.
Make sure that the sound is not muted.
Make sure that you've selected the proper input by INPUT MODE button.
Remove and reconnect the source.
connect a different device and check
check whether you're getting sound when listening to radio.
Jan 22, 2011 | Audio Players & Recorders
Subwoofer hum from STR-DH800
That points pretty much to a bad shield on the cable. Have you tried another one? Another thing to try is to rotate the AC power cord on the sub (if it has one). Sorry, too lazy to look it up.
Dec 29, 2009 | Sony STR-DH800
Can't change FM input mode! Stuck at analog...
Tuner is only analog. As for the Video 1 input you need to go into the menu and change it to the digital port you want to use (optical, coaxial or HDMI) you can set only one input to each digital input port.
Nov 30, 2009 | Sony STR-DE597 Receiver
Pioneer vsx 3000 plays fine, but the radio function hums
If memory serves correct, the VSX-3000 is from the late 80's. They are good receivers from that era. From your description, it appears the tuner module could have issues, since only the AM/FM has a hum. If all other inputs sound well, it points the the tuner module. These modules are not easy to repair (PCB with SMD highly tuned parts), and are easiest and cheapest to replace. Many VSX models of that vintage use the same part. Not sure how easy it would be to find one. They are a small PCB enclosed mostly in a silver shielding, with one or two connectors from the inside and screwed to the back of the receiver, where the antena connection is.
Good luck
Jul 29, 2009 | Audio Players & Recorders
Electronic hum
Hey there,
What I think is the problem here is that your A/V receiver may have a blown preamp for the turntable input. Or, although less likely, assuming that both channels sound normal when the receiver is set to a different input such as an FM tuner, there could be an impedance mis-match between the turntable's output and the reciever's input. But, the goal is to try simpler (and much more inexpensive), methods first. Try replacing the cable that connects your turntable to the receiver. If no difference is heard, then we should take another diagnoses.
Regards,
Hortona
Mar 25, 2009 | Pioneer Audio Players & Recorders
I have a hum or buzz on AM and FM bands only.
I had the same problem, but it is not the tuner module! An exchange of capacitor C899(100μF/35V) on the standby board has resolved the problem. Under a dollar from an electrical store and you are all sorted. 10 minute fix for those with a soldering iron.
Feb 18, 2009 | Sony STR-DE685 Receiver
I have a ViP 722. It has no rf output for TV1, just the hookup for TV2. The multi RCA hookup for HD. HD is not as important to me as is a clean picture and audio on my TV. No matter how I do it, I get a...
Okay I am not positive I have this right as far as the configuration of the system but I will give it a shot. If you run the 722 to the tv using rca's you get the hum. I assume this as there are no inputs on a dish 722 receiver. I can suggest one possible solution which is to buy an rf modulator. It will convert the signal from rca to coax so you can connect as you wish. There are several types out there so ensure you get the one that converts from rca to coax. I would suggest the following configuration: Remove all connections from tv and hook 722 up via rca's to rca input 1 on the tv, check for hum. If it is present now you need a new 722 as it is passing to much power thru the connection. If there is no hum connect your cable and tivo to the tv via whatever inputs you have remaining. Lastly connect the DVD player to another input that is free. You will have to system through your inputs to view the three sources but should not have the hum. I hope this solves your issue. Thanks for using Fix Ya and let me know if I can be of further assistance.
Dec 06, 2008 | DISH Network DVR-625 DTV Receiver /...
Cheers
Dec 02, 2008 | Sony HT-DDW740 System
Sony HT-DDW740 System Logo
124 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
