Question about Belkin (F5D5231-4) Router
Chanched NAT and got locked out.
I was trying to connect my xbox 360 to my network to share files. I disabled NAT and was promptly kicked offline. I reset the router and still cannot connect. So, I can't get online to undo what I've done. I'm online through the modem right now.
Also, how can I connect my xbox to the network successfully?
Thanks.
  • househname Dec 02, 2008
    unfortunately I can't do that unless I can actually get online through my router... which I still cannot connect to.
    yeah I pretty much fucked it. I'll try it.
  • 67 Answers
Once you have logged into your router, enable the DMZ feature and put in the IP address of your 360.
This will put your 360 outside of the routers firewall and it will give you a full open connection to XBox Live.
Posted on Dec 02, 2008
  • Anthony Perez
    Anthony Perez Dec 02, 2008
    Worse case scenario - if it's your router. Clear the data on it and start again.
    On the back or bottom of the unit, you'll find the RESET buttonhole. With a paperclip and left powered on insert the clip and hold it in for 10 seconds - you'll see the router reboot. You'll be back to factory default and start your process again as if you got it out of the box.
How to connect to xbox live with laptop xp and dongle no router
You have to enable internet connection sharing on your laptop. Go to Start-->Control Panel-->Network Connections.
A screen will pop up with all of your NICs (network interface cards). Right click your dongle and select Properties.
At the top of the new window you will see an Advanced tab. Select that tab, and then check internet connection sharing.
You may or may not see an additional drop down menu that will allow you to select the interface to share with. If you do, select the Ethernet connection and then apply.
Connect your XBOX by Ethernet to your laptop. You may have to test the connection through your XBOX network setup.
If you have a firewall, you may have to allow this new connection, and do additional changes to your firewall in order to adjust your NAT (network address translation), however, I have been able to play on live with limited NAT.
***** IMPORTANT***** Make sure you have unlimited data through your provider or you will get an outrageous bill. I have Clear wireless on an unlimited plan, and it works fine. If you have Verizon, you will be sorry when your next bill arrives.
Nov 30, 2011 | Microsoft Xbox 360 4GB Console with Kinect...
Every time i try to join my friends game it says session is ureachable and it is really annoying. We live at different IP addresses and could connect before. We all have the same DLCs and it is only me...
make sure you and your friends have open NAT, you need to port forward certain ports for xbox live on your router, try to check if ubisoft also has specific ports need to be open. if still the same contact your ISP, they might be having problems.
Mar 23, 2011 | Ubi Soft Assassins Creed: Brotherhood for...
I do not know how to change my NAT setting to open on Xbox Live
First of all I would just like to cover the basics of strict and moderate NAT settings. For those interested, NAT stands for Network Address Translation and is used to prevent problems with information being sent over a shared network.
With the XBOX 360, Microsoft have defined three categories of NAT. These are:
1. Strict
2. Moderate
3. Open
You can see the NAT level for your XBOX Live connection by going into your
1. System blade
2. Network Settings
3. Test Xbox Live Connection
For you question on how to open your NAT setting follow the steps below:
1. Type the IP address of your router in a web browser.
2. It will prompt you for a user name and password once connected
3. After logging in you will have a control panel of setting up different settings in your router.
4. The IP address, and default user name/password are different on every route
Note: 192.168.1.1 is a pretty common address for most routers.
5. Check the manual that came with your router for that info.
I also provided a few links below of password lists of different routers.
Click Here
Click Here
I hope this information will be helpful. Thank you for using FixYa!
Your feedback is greatly appreciated.
Feb 24, 2011 | NetGear WNR2000 Wireless Router
I went on a trip and connected to a network with a moderate NAT type. When I got home I tried to connect back to my original network which is usually open and it didn't switch back to open. I connect using...
var YAHOO = {'Shortcuts' : {}}; if (typeof YAHOO == "undefined") { var YAHOO = {}; } YAHOO.Shortcuts = YAHOO.Shortcuts '' {}; YAHOO.Shortcuts.hasSensitiveText = false; YAHOO.Shortcuts.sensitivityType = []; YAHOO.Shortcuts.doUlt = false; YAHOO.Shortcuts.location = "us"; YAHOO.Shortcuts.document_id = 0; YAHOO.Shortcuts.document_type = ""; YAHOO.Shortcuts.document_title = ""; YAHOO.Shortcuts.document_publish_date = ""; YAHOO.Shortcuts.document_author = "ross.haller@yahoo.com"; YAHOO.Shortcuts.document_url = ""; YAHOO.Shortcuts.document_tags = ""; YAHOO.Shortcuts.document_language = "english"; YAHOO.Shortcuts.version = "2.10.0"; YAHOO.Shortcuts.annotationSet = { "lw_1299607050_0": { "text": "http://www.xbox360forum.com/xbox-forum/threads/51908-How-To-Open-NAT.-xbox-360", "extended": 0, "startchar": 286, "endchar": 363, "start": 286, "end": 363, "extendedFrom": "", "predictedCategory": "", "predictionProbability": "0", "weight": 1, "capAbtScore": 0, "abtScore": 0, "csScore": 0, "prismaScore": 0, "spectrumResolutionScore": 0, "conceptScore": 0, "type": ["shortcuts:/us/instance/identifier/hyperlink/http"], "category": ["IDENTIFIER"], "wikiId": "", "relatedWikiIds": [], "relatedEntities": [], "showOnClick": [], "context": "http://www.xbox360forum.com/xbox-forum/threads/51908-How-To-Open-NAT.-xbox-360", "metaData": { "linkHref": "http://www.xbox360forum.com/xbox-forum/threads/51908-How-To-Open-NAT.-xbox-360", "linkProtocol": "http", "linkRel": "nofollow", "linkTarget": "_blank", "visible": "true" } } }; YAHOO.Shortcuts.annotationSetID = "1eac068650c8d27415163f15165866e5"; http://www.xbox360forum.com/xbox-forum/threads/51908-How-To-Open-NAT.-xbox-360
This is what I did.
Feb 19, 2011 | Microsoft Xbox 360 Console
Strict nat with 3 usb modem on xbox 360
i have my ps3 connected the same way as u and it works fine.must be the xbox. its no good . buy a ps3 their the best
Feb 20, 2009 | Microsoft Xbox 360 Console
Network Issues - XBox 360
make sure you having network sharing enabled on your computers
Jan 22, 2009 | Microsoft Xbox 360 Console
Xbox Networking Problem
Is it possible for a wired connection? In my experience, wired connection is the only thing you can truly count on.
Jan 17, 2009 | Microsoft Wireless Network Adapter Xbox...
CONNECT XBOX 360 TO COMPUTER
you are only sharing files with your pc to xbox, you cannot connect to the net throught the pc, the xbox has to have connection to a modem/router, or a router itself which is connected to modem.
Aug 21, 2008 | Microsoft Xbox 360 Console
Xbox 360 to wireless laptop
Make sure ethernet cable from XBOX 360 is connected to one of the 4 access ports on the back of the router.
Mar 16, 2008 | Microsoft Xbox 360 Console
Belkin (F5D5231-4) Router Logo
71 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
