I HAVE HP DV2000, LIGHTS ARE COMING ON THE KEYBORAD, HARD DISHK IS SPINNING BUT ONLY GETTING A FAINT IMAGE ON THE SCREEN
  • sumit640 Dec 02, 2008
    can i check it manually, if so how...or i need to go to a technician
  • Anonymous Dec 02, 2008
    it is a laptop
  • 849 Answers
Check the monitor cable, it must be loose from the back.
Posted on Dec 02, 2008
  • Muhammad Saeed
    Muhammad Saeed Dec 02, 2008
    no u can check it urself at the back of cpu, els no way except go to technician
The backlight for my pavilion dv2000 is not lighting up. the laptop boot ugh i can see faintly, am able to move the mouse and open any program the screen remains so faint ie partially black
Well looks like your cfl tube is dead or the card powering it is dead. the easiest thing to do is to
find a Laptop repair center, the can change either the backlight tube (like a neon tube really) or the inverter or the whole screen.
You might want to try it yourself if you find a working screen for your HP.
Is is fastidious but not that dificult.
Here you can see a step by step tutorial on how to remove the screen for another Hp model.
May 17, 2011 | Computers & Internet
Hi, my hp dv2000 screen is blank when I turn it on. It hums and lights up like it's supposed to, but the screen is completely blank! What do I do?
Look at the LCD screen very closely and check if you can see a faint image on the screen. It's possible that the LCD lid close switch stuck in the "closed" position and the back-light stays off even when you open the LCD screen or turn on the laptop. The switch turns off the back-light when you close the LCD display to save the laptop battery power.
If that didn't fix it then there are 3 things that could have gone wrong:
1. Video cable connection from inverter to LCD got loose. To check this, follow instructions from step 3 on how to open the LCD and check if cable is fitted properly.
2. The video inverter is faulty
The screen inverter failure is very similar to the back-light lamp failure. In both cases the screen gets very dark and the image on the screen becomes very faint, barely visible under a bright light. If it's still under warranty, take it for a replacement. You can replace this otherwise - you can find the inverter under the screen, follow the procedure described at point 3 to open up the screen.
3. The LCD monitor is faulty
If it works on an external monitor most likely the LCD is faulty and needs replacement. If it's still under warranty, take it for a replacement. If not, you can do it yourself, it's pretty easy. Remove the rubber covers on the side of the screen, unscrew the screws take the plastic cover off, disconnect the video inverter and put in the new LCD after you connect the video inverter to it.
Nov 30, 2010 | HP Pavilion dv2000t Notebook
I have a HP pavilion DV2000 and i changed the
Reset your memory if not in properly it will not show video. if that doesn't work then plug a external monitor in the side port. if you get video then your LCD is bad if you dont then *********** board is bad
Feb 03, 2010 | HP Pavilion dv2000t Notebook
HP Pavilion dv2000 black screen.
yep ...it seams that you mess with the grafic card ( vga driver ) ..probably on color register ..or some driver update ..and now it wont display image ...
either reinstall the pc ...and its probably the best ...or restore using cd .. cause if it was something wrong with your display ..it should work on the other monitor... it also might be a video card fail ...if after re-installation its the same ...its the video card..
if you are worried for the data on il ...just install windows without formating ...choose to install a new os in the old folder...
Aug 01, 2009 | Computers & Internet
My hp dv2000 will not start or boot
What happens when you just boot the computer without the hard drive installed?
Jun 15, 2009 | Computers & Internet
NO DISPLAY
it seems to me that ur lcd having some problem,so take it to nearest service center////
Dec 02, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Hp pavilion dv2000 notebook will not boot up
hi,
i m in Hong Kong. The stupid HP repair center charged US 90 just for inspection!!!!! They they said the whole motherboard had to be replaced, thts additional US 630 dollars, the thing is just 1.5 yr old. They also said i don get to keep the broken mother board after replacement. This is simply irresponsible, unethical, sleazy and UNJUST!!
Thanks. right now the computer is fixed for US70. when i hv time, i'll open it up and see if i can figure it out how it was fixed. The shop suggested tht the computer wont last too long. This is such bad quality for HP... Sorry, i hv to do the following for other victims to find this easily:
(can some creative netizen bring this to the public light to pressure HP to do the ethical things??)
bad quality HP. hong kong HP pavilion dv2000 series manufacture problem. HP unethical.
Sep 21, 2008 | Computers & Internet
HP Pavilion DV2000
first replace the inverter to correct the lighting problem ok. then move to the other problem both can be recovered from
so ebay dv2000 lcd inverter buy it get a screw driver link me bakerandre2000@yahoo.com
Apr 14, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
