Question about HP Pavilion dv2000t 14.1" Notebook Laptop PC (Intel Core 2 Duo T5500 1.66 GHz, 1GB RAM, 100GB HDD, D... PC Notebook
NO DISPLAY I HAVE HP DV2000, WHEN I SWITCH IT ON , ALL KEEPS LIGHT UP AND THE HARD DISK STARTS SPINNING AND I CAN SEE A FAINT HP IMAGE ON THE SCREEN WITH GREAT DIFFICULTY, I TRIED Fn + all the keys, but could not resolve it. Can you suggest what to do. I had the same problem a month back on the same laptop and after i switched it off three - Four times it worked fine.
    President:
  • 2,110 Answers
It seems to me that ur lcd having some problem,so take it to nearest service center////
Posted on Dec 02, 2008
Hp pavilion dv4 laptop display works with external display only
Switch the display to the laptops screen. Shine a flash light on the screen and look very carefully for a faint image of what should be displayed. If you see it then either the back light or inverter board is dead. Usually the inverter board. These are housed inside the lid usually runnung alone the bottom of the display. If there is no image then the display is bad. The easiest fix would be to remove the entire lid and replace the whole thing. This will effectively replace all three parts I mentioned, but will be more expensive.
Dec 15, 2012 | Computers & Internet
Hi, my hp dv2000 screen is blank when I turn it on. It hums and lights up like it's supposed to, but the screen is completely blank! What do I do?
Look at the LCD screen very closely and check if you can see a faint image on the screen. It's possible that the LCD lid close switch stuck in the "closed" position and the back-light stays off even when you open the LCD screen or turn on the laptop. The switch turns off the back-light when you close the LCD display to save the laptop battery power.
If that didn't fix it then there are 3 things that could have gone wrong:
1. Video cable connection from inverter to LCD got loose. To check this, follow instructions from step 3 on how to open the LCD and check if cable is fitted properly.
2. The video inverter is faulty
The screen inverter failure is very similar to the back-light lamp failure. In both cases the screen gets very dark and the image on the screen becomes very faint, barely visible under a bright light. If it's still under warranty, take it for a replacement. You can replace this otherwise - you can find the inverter under the screen, follow the procedure described at point 3 to open up the screen.
3. The LCD monitor is faulty
If it works on an external monitor most likely the LCD is faulty and needs replacement. If it's still under warranty, take it for a replacement. If not, you can do it yourself, it's pretty easy. Remove the rubber covers on the side of the screen, unscrew the screws take the plastic cover off, disconnect the video inverter and put in the new LCD after you connect the video inverter to it.
Nov 30, 2010 | HP Pavilion dv2000t Notebook
The monitor on my hp zv5000 will not light up... I see a faint image if I flash a flashlight or something on the display. how can I get the screen to light up again?
The high voltage inverter that drives the backlight cold-cathode flourescent lamps has likely failed. The inverter is located near the bottom of the display panel.
Jun 14, 2010 | HP Pavilion zv5000 Notebook
Hp pavilion dv2000 lights switch on but boot or
Hi
Thank you for your query
Please try the folowing
1) Remove ALL wires and then press and hold the power button in for approx 20 seconds
2) Plug everything back in and then rerty
This may sort the issue out however from what you are descrbing, if there is no boot or display it is highly likely the motherboard and/or the CPU is faulty
I would recommend that you book the PC into a reputable PC repair shop if the above does not work
If this has been useful please leave postive feedback/vote/testimonial - Thank You Again
Feb 15, 2010 | HP 417035-001 - HP Pavilion dv2000 Series...
HP Pavilion dv2000 black screen.
yep ...it seams that you mess with the grafic card ( vga driver ) ..probably on color register ..or some driver update ..and now it wont display image ...
either reinstall the pc ...and its probably the best ...or restore using cd .. cause if it was something wrong with your display ..it should work on the other monitor... it also might be a video card fail ...if after re-installation its the same ...its the video card..
if you are worried for the data on il ...just install windows without formating ...choose to install a new os in the old folder...
Aug 01, 2009 | Computers & Internet
Pavilion dv2125nr won't boot
it could be dead mobo, it's actually the most probable cause of your problem, but there is this thing i've encountered with HP several times already. i know it's a long shot, but i'd like you to try and boot the laptop up after you've removed the DVD-drive. if this works, it's the DVD-drive that's broken, if not, it'll be the mobo...
Jul 01, 2009 | HP 417035-001 - HP Pavilion dv2000 Series...
I have a dv2000. It turns on, but see no bios screen.
TRY TO GO THE BIOS SETTING THEN LOAD DEFUALT.. IF THE LOGO SCREEN NOT SHOW SOME PROBLEM FOR THE DISPLAY THE DEFAULT SETTING IS THE LOGO SCREEN WILL SHOW ON START UP THE SCREEN..
CHECK THE DISPLAY,,,, INVERTER, OR VGA CABLE,, VIDEO CARD..
Jun 25, 2009 | HP Pavilion dv6000z Notebook
Dead compaq laptop, no boot activity
Larnold..Sounding like you need to check the LCD Power Inverter Circuit board.. this is located inside the screen a long rectangular circuit board that sends power to the screen backlight & Display Panel.. Could also be a Bad Backlight.. Try Booting it.. Hold it up to a light and look closely at the screen.. If you see a faint image but no light, it is the Backlight, if Just Black No Activity then its most likely the Power Inverter, OR a Bad Video Card.. You can test the VIDEO by Connecting the laptop to a Computer Monitor or similar with the laptops VGA Serial port.. then Use your function Key and Switch to 2nd Display.....(one of your F keys.. ).. If it Shows up on another screen, Its a Display problem and not the video card... Hope This Helps alittle.. Cheers
Jun 02, 2008 | HP Compaq Presario V6000T Notebook
HP Pavilion dv2000t 14.1" Notebook Laptop PC (Intel Core 2 Duo T5500 1.66 GHz, 1GB RAM, 100GB HDD, D... PC Notebook Logo
29 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
