Question about Cycling
Avid Juicy 7 hydrolic disc brakes piston lock up
My front Juicy pads are pushed all the way closed. I can't fit the disc in between the pads because the pistons are pushed all the way out. I had my bike in the car for a day, with the front wheel off. I go to put the wheel back on and the pistons won't return to fully retracted. When I pull on the brake lever, the pads to slightly move together, but they don't return to the fully retracted position. Maybe the heat expanded the fluid and jammed the pistons? How do I go about fixing this?
  • 1 more comment
  • rowan670 Dec 14, 2008
    I have the same problem, happened the same way with out the heat though. The wheel was off for a few hours and when trying to but it back on the pads were too close together for the disc to fit.
    I don't see how to use the clamp. any further explanation on how to fix the problem.
  • shturner Dec 27, 2008
    I have same problem after removing the wheel to wash the bike. Any other advice? if i bleed the brakes at what stage should I push back the pistons?
  • singlefin Apr 26, 2009
    Me too. I have exactly the same issue as you and I couldn't have explained it better myself. What's the answer?
Do not bleed the brakes! If you don't have the plastic rectangular spacers that came with the brake when they were new, go to your local bike shop or get an "old" teflon kitchen spatula that's thin enough to fit but make sure its a bit thicker than your rotors and try to pry the pads apart then wiggle it until a good portion is in between the pads. Then squeeze the brake lever with the spatula is in between. This should reset the pads leaving enough clearance for your rotor to fit. NOTE: Avoid depressing the lever when the wheel is off. This will cause the pistons to travel further than usual causing both pads to come together. Hope this helps.
Posted on Mar 05, 2009
Well if you have the transportation plastic "tool" that usually comes with the brakes you can insert it in between the pads and it will retract them, otherwise use a wide screwdriver and insert it between the pads and then gently pry the pads apart. That will do it...If anything in the future just visit your LBS and ask them if they have any of those transportation pieces around so you can insert it in between the pads the next time your taking your bike somewhere.
Posted on Jan 27, 2009
If there is enough space to fit a flat headed screwdriver in the gap, use it to gently push the pistons back in to the housing.
Your not supposed to squeeze the lever while the wheel isn't fitted.
Posted on Jan 08, 2009
When you take the wheel off, put a piece of heavy cardboard, or plastic such as ice-cream container (or the like), or icy-pole stick... basically something slightly thicker than your disc, between the calipers to stop the pistons being able to close. If the levers are accidentally pushed, the pistons won't blow out.
Posted on Jan 24, 2009
  • 76 Answers
Use a c clamp and very slowly compress them back in
Posted on Dec 02, 2008
Avid Juicy 7 disc brakes:The front wheel was removed and the brake lever squeezed while the wheel was off. The front wheel goes on, but does not spin freely. It turns easily, but not freely like it...
It sounds like you have a piston that is not fully returned and is sticking.
Get a big flat bladed screw driver, take the wheel out and very carefully insert the screw driver into where the disc would sit and use the screw driver to try and push each brake pad back in without damaging your brake pads.
If this works go to a local bike shop and ask them for a avid brake insert for transporting your bike so this does not happen in future! :)
Jan 13, 2010 | Avid Juicy Ultimate Hydraulic Disc Brake ,...
Jammed Avid Juicy 5 brake piston
Sounds like you need to strip down the caliper and clean it out im afraid. How about trying a LBS?
(usually its caused by a dry seal and the piston has to be forced out by putting an air line onto the caliper bleed nipple and blasting air into it to force it out - *be careful if trying this!!**)
Jan 07, 2010 | Avid Juicy Ultimate Hydraulic Disc Brake ,...
Avid juicy ultimate, rear disc brake vibration and noise
It is a lose bolt somewhere, OR somebody has touched your rotor with their hands OR there is oil in the pads.
Check ALL your bolts for correct torque, buy new pads and Rubbing Alcohol and install them AFTER you clean off the rotor and your hands with the Rubbing Alcohol. TRY not to touch the rotor or the pads with your hands.
Dec 30, 2009 | Avid Juicy Ultimate Hydraulic Disc Brake ,...
Avid juicy sevens remain tight against disc
Juicy's are prone to sticky pistons.REMOVE pads,clean calliper ,pull lever lightly and add a drop of hydraulic fluid to the edges of the pistons to lube.Recess pistons,wipe off excess fluid and fit pads.If this doesn't work they might need bled.
Sep 25, 2009 | Avid Code Hydraulic Disc Brake
Brake pads dont retract
you will need to retract them with a small c clamp, thus slowly pressing the calipers back into cylinder.plz rate-bozcro
Sep 16, 2009 | Avid Juicy 7 Hydraulic Disc Brake 2008...
Brake pads tightening up
use a flat screw driver and push the pads back in on the calliper. Be gentile though.
Jul 30, 2009 | Avid Code Hydraulic Disc Brake
My Avid Juicy 3 front brake seems to pulsate when pressure is applied to the brake lever and the braking is very uneven...almost like a pulse of sharp braking at one point of revolution. Is there an air...
The brake disc may be warped from excessive heating. This may be caused by a dragging brake pad. the disc may have been bent from an impact.
This can also be caused by the pins holding the brake caliper being stuck. Try some WD40 on them and tap them (gently) to free them.
Jul 20, 2009 | Avid Juicy Ultimate Hydraulic Disc Brake ,...
Brake pads are shut fairly tight. Can't get disc
Your brakes adjust automatically (so when the pads wear down your levers don't get looser). What you did was pull the brake lever and it adjusted making the pads shut.
Anyway all you need to do is take a wide flat-head screw driver and wiggle it back and forth between the 2 pads.
Jul 10, 2009 | Avid Juicy Ultimate Hydraulic Disc Brake ,...
Bought a set of avid juicy seven ultimate brakes,i squeezed the brake lever and now the pads are shut tight how do i slacken them off again!
take the wheel out insert a very large flat bladed screw driver up into where the rotor would sit and lever the pads back in very gently with the screw driver.
if this does not shift them they will need re-built by a Sram bike shop.
Mar 23, 2009 | Avid Juicy Ultimate Hydraulic Disc Brake ,...
Brake adjustment :: too spongy
try these links:
http://forums.mtbr.com/showthread.php?t=464735
http://www.sram.com/en/service/avid/view.php?catID=1&subcatID=1
Dec 20, 2008 | Avid Juicy Ultimate Hydraulic Disc Brake ,...
Cycling Logo
4,935 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
