Question about Kenwood Audio Players & Recorders
My kenwood kvt-719 shuts itself off when played at louder levels. Every speaker is on its own amp exept the two front tweaters. If I turn only the front tweaters on the head does not shut down.
  • 76 Answers
You are pulling too much power from your headset to your amps. you should only be using 1 amp front 1 amp back and 1 amp bass if you want to run all those amps which i do not believe it is needed you should be installing capacitors to help with the power. btw that many amps you better put a high power alternator in your car or your battery and/or alternator will burn out quikly
Posted on Dec 02, 2008
I loking for a brain for kenwood kvt-719 in dash only brain an wires
i have the brain and wires for the exact model i had it a month before someone ripped the screen out of the reciver.. it still plays cds and radio so i know the rest is fine i have all of the wires and harnesses.. 200$
jk2184.jk@gmail.com
Apr 13, 2010 | Kenwood KVT-719DVD 7 in. Car Monitor
I have the kvt 617 I have great audio when listening to radio nut anythig else I only have subs it started doing it when i first got it and then it quit and know it is doing it again any idea?
High end kenwoods have a setting, where you can turn off the internal amp in the head unit, if the sub is the only thing that has an external amp hooked to it, and it is playing, that may be your problem. Also, if one of the speakers hooked directly to the Kenwood has a short, bad voice coil, or contacts touching metal, that can cause the amp in the Kenwood to go into protect, and you will loose sound to all the speakers.
Aug 18, 2009 | Kenwood KVT-617DVD Car DVD Player
Kenwood kvt-719dvd A/V interface was lock
On the front of your unit you have a small pin hole (front right hand side) you will need something small to push this in & it will reset the unit . Once the unit is reset you will need to get into your audio settings and set them back up so that everything sounds correctly.
Apr 10, 2009 | Phase Linear UDV9010 Car DVD Player
"disconnected cable, please confirm connect"
do you getta dvd picture...i get sound only but no pic....????
Apr 24, 2008 | Kenwood KVT-719DVD 7 in. Car Monitor
I have a cd stuck in my kenwood kvt 719 head unit and the touch screen controls for the dvd are not appearing.
Have you tried hitting the "Reset" button on the head unit?
The procedure is on page 7 of the owner's manual under the heading "How to reset your unit"
Here's the URL for the Owner's Manual:
http://inform3.kenwoodusa.com/manuals/KVT-719DVD.pdf
Per the owner's manual, you're supposed to call Kenwood technical support if the display doesn't correctly reset or come back on and/or if the disc won't eject.
Apr 14, 2008 | Car Audio & Video
Kenwood KVT-617DVD sound issues
the wireing off the brain is connected wrong, ok look at the wires and now disconnect your remote wire from the amp remote now connect the second blue wire to the remote wire going to the amp, now your sound should be right
Jan 21, 2008 | Kenwood KVT-617DVD Car DVD Player
Kenwood KVT-617DVD
hi kenwood go's off when i put it on to dvd
Jan 16, 2008 | Kenwood KVT-617DVD Car DVD Player
80 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
