Question about AOpen AX4SPE-UN Motherboard
Odd boot AX4SPE-UN with 2G OCZ copperplated RAM, western digital 74G 10K RPM SATA1 hard drive. everything has always worked fine, up until right now (i'm on my girlfriends PC by the by). Gaming like usual, and the bugger locked up, I diagnosed it for a soft boot and after POST, while detecting the hard drive, it hangs. Puzzled, i waited to see what would happen. Nothing. Confused, i thought to check my BIOS to see if something was misconfigured. Hit 'Del'. Nothing. Restart button for soft boot. POST, detecting HDD...Nothing. Immediately freaking, i jumped on here to find a solution. Nothing. While i was web surfing for a solution and posting here, my comp (right next to this one) finally detected the HDD, configured PnP devices and then hung. Few minutes later, flicks to the loading windows screen. Normally takes less than 3 seconds to go into a working desktop, but it hung at the windows splash screen. After a 10 minute boot process, everything is up, working, and appears fine. It has recently been through a defrag, viral/trojan scans in the last week, and it has been working flawlessly with no hardware changes for the last 7 or 8 months. The game wasn't special, D2: LoD and it has always worked fine. Anyone have a Clue?
    Scholar:
  • 121 Answers
A "hung" system usually tells you that you have registry problems and/or buggy drivers and can include a virus (It can also include a corrupt boot sector). Well, there's a easy fix for this and a really difficult fix for this...And then there's the reinstallation of Windows. Ok, the easy fix is to goto: Start -> Programs -> System Tools -> System Restore Run the restore program back to the time where you were having no problems. Voila! If it is a virus, this will not get rid of it as some of the viruses make their way into the system restore. Then there's the difficult way to do it which is kinda like the installation of Windows but instead you hit "repair" (This is known as the Recovery Console and it's in DOS just to warn you...) Then you can type the following at the dos prompt: fixmbr - Fixes corrupt master boot record fixboot - Fixes corrupt boot sector bootcfg /rebuild - Fixes corrupt or missing boot.ini
Posted on Mar 24, 2007
I have a western digital essential 1 TB external hard drive.I have windows vista and it has usually worked fine until one day i tried to plug it into a different computer that has window's 7, but it...
HI, RULE #1 IS "ALWAYS" ATTACH/PLUGIN WHILE PC IS SHUT-DOWN. NEVER CONNECT/DISCONNECT WHILE RUNNING. GO TO CONTROL PANEL, DEVICE MANAGER, SCROLL TO BOTTOM, CLICK + WD DRIVE MANAGEMENT DEVICES, SEE IF WD SES DEVICES IS THERE IF IT IS, DOUBLE CLICK IT. A WINDOW SHOULD POP-UP SEE IF IT SAY'S THIS DEVICE IS WORKING PROPERLY. IF NO DRIVERS ARE INSTALLED, CLICK UPDATE DRIVER. IF THAT DOES NOT WORK, GO TO CONTROL PANEL, ADMINISTRATIVE TOOLS, COMPUTER MANAGEMENT, UNDER STORAGE, CLICK DISK MANAGEMENT, MAXIMIZE PAGE, SEE IF MY BOOK IS THERE. IF IT IS, RIGHT CLICK, THEN MARK PARTITION AS ACTIVE...........I HOPE THIS HELPS..........JEFFXC
Jan 25, 2011 | Western Digital My Book Essential 1TB...
Why wont my laptop start with My Book?
disable usb booting in bios, set hard drive and cd ahead of everything in boot order
Mar 15, 2010 | Western Digital My Book Essential 1TB...
Harddrive was working fine until eletric went off and on, then it keeps saying it needs formatted and I don't want to lose everything on it. PLEASE HELP!!!!
if you have an additional hard-drive, try to install an OS on it and use a recovery program, if not, you may ask a friend to recover the Master Boot Record. The hard-drive has lost the mapping of where were your files and the use of a recovery program will take a looong time. so be patient as it generally lasts 17 hours for smaller hard-drives, and it increases, depending on the hard-drive's capacity and used space percentage.
Feb 06, 2010 | Western Digital Computers & Internet
Asus P5KPL SE & Sata, Bios "Not Detected Problem"..
The Asus bios won't show SATA devices.
However if you are using Windows XP with Service Pack 2 (or newer operating system then the devices should be detected. If this is not happening then enter the bios -- Storage Configuration -- Configuration Enhanced and set the IDE devices to compatible. This allows all drives to be "seen" and you should then be able to load an OS.
Jan 22, 2010 | ASUS Computers & Internet
Accidently uninstalled Western Digital program
google western digital and dowload the drivers again, then reinstall from disc if you have one! (do this with the drive un-plugged) when you then re-boot and plug it in all should come right!
Sep 27, 2009 | Western Digital Passport 320GB External...
SATA Drive on MSI K8T Neo upgrade hard drive. More detail.
Sata drives are backwards compatable so should work no problem but some drives have a jumper that needs to be reset ,check the website for your drive.
Aug 10, 2009 | MSI K8T Neo-FSR Motherboard
WD Caviar SE16 WD3200AAKS 320GB 7200 not recognized at install
Windows XP does not have built in SATA drivers. You will need to download the XP drivers from Western Digital's website and install before the computer will allow you to format and use your new drive. Hope this helps.
Jul 18, 2009 | Western Digital (WD3200JS) 320 GB Hard...
Installed more ram and now can't find the hard drive
Pull out the new RAM chips and install the old one or ones and see if it boots ok. I had this same problem. This can also be caused by no using matched sets of RAM chips. In my case I added one and used the factory one as well, caused the same issue as you have.
May 19, 2017 | Western Digital Caviar SE 80 GB Hard Drive
AOpen AX4SPE-UN Motherboard Logo
133 people viewed this question
Top AOpen Computers & Internet Experts
Michael Galve
Michael Galve
David
David
Alun Cox
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
