Question about Acer Aspire 3000 Notebook
I keep the message General Protection fault with a black screen when I turn my acer aspire 3000 on and it won't go past that screen/What can I do to fix it?
  • Acer Master
  • 32,281 Answers
To repair corrupted system file/s, boot up with the Windows installation CD then -
Press R to repair when instructed.
Press 1 or Enter to repair the C:\Windows folder.
Then type chkdsk /r and then press Enter.
The repair process will take quite a long time.
Posted on Jun 17, 2012
SOURCE:
  • 8 Answers
SOURCE: Aspire One PC Notebook: My acer one aspire turns on but screen stays black...
Try this for the black screen of death problem...
Here’s what you need:
  1. USB Memory stick (as low as 128mb)
  2. Another PC with a net connection
  3. WinZip, WinRAR, or some other program that can extract zip files.
  4. A quick visit towww.acer.com
  5. Your Acer Aspire One, that will power up/turn on, but the screen does not come on.
And here’s what you do:
  1. Go to www.acer.com and go through the DRIVER support pages until you get the Aspire One driver page for your relevant Aspire One model (110/150/751)
  2. Click on the tab on the download area that reads ‘BIOS’ even if it looks like you can’t click on it (their site design grays it out but it’s there) and download the BIOS file numbered 3310 (it might have changed version recently but do it) and don’t worry, you can trust this file, as it’s from Acer directly.
  3. Extract the zip once downloaded and find in the DOS folder the files ‘flashit.exe’ and 3310.fd
  4. When you’s ve found them, rename 3310.fd to ZG5IA32.fd and put this renamed file and ‘flashit.exe’ onto the USB memory stick
  5. Put the USB in the Aspire One and hold the keys ‘FN’ (function) and ‘Esc’ (escape) and keep them held when you turn the laptop on
  6. Watch the power button and when it starts flashing, press it once (DO NOT DO ANYTHING ELSE)
  7. You should notice the USB (if it has a light) blinking as well… The netbook has started ‘flashing’ the BIOS and after about 7 minutes, the netbook should shutdown and reboot itself and VOILA! The screen should turn on just fine.
It took my three times but this IS the proper solution! I am now very happy with my Aspire One that still works!
Posted on May 21, 2010
hakimmadina_
  • 155 Answers
SOURCE: acer aspire 9300 black screen (display adapter)
I have been fixing computers that has long beeps and short ones. It is usually attributed to memory problem connection. Open the memory compartment at the back of the PC then detach the memory card. Clean with cloth softly enough not to destroy the circuit board or a pencil eraser to clean-up dust that caused the connection blockade. Reconnect after cleaning.
Posted on Jun 21, 2009
birky09
  • 104 Answers
SOURCE: Acer Aspire 5720 Laptop problem. When turned on
Upon loading press F2 or del to enter bios setup and change the settings to display the acer welcome screen and the one you said about Microsoft logo and white box with green lines, you cant by pass it because it's windows loading screen
Posted on Dec 01, 2009
Testimonial: "Thanks for the quick reply. Your advice worked brilliantly and now fully functioning laptop is back. "
  • 32 Answers
SOURCE: 'When i turn the acer aspire one on i get a black error 17
you should reinstall windows. sounds like a virus
Posted on Dec 28, 2009
will-raven
  • 83 Answers
SOURCE: Screen problems on Acer Aspire 5740
I don't know that it is a common fault with this specific model, but laptops in general have this issue mostly due to a dying LCD power inverter. It is typicaly located at the bottom of the LCD screen and costs between $30 - $75 dollars for the part, and usually $75-$150 for someone to replace. If you like the laptop it is usually worth it to have replaced. You can also hook up a monitor to the VGA port on the laptop and then go into your display control panel and enable 2nd monitor to use it instead of your laptop lcd.
Posted on Apr 30, 2010
I have an acer aspire 5551. When I power on I get a message that says windows was not shut down successfully. I tried rebooting in safe mode and normal mode but it keeps going to a black screen with a...
IF YOU TRY TO GET A NEW OPERATING SYSTEM INSTALLED LET IT FINISH COZ U MOVED THE CD OUT OF THE DVD CD ROM AND THE PC FAILED SO U NEED TO FRESH INSTALL UR OPERATING SYSTEM BUDDY
Sep 20, 2013 | Acer Aspire 3000 Notebook
Why won't my notebook display any picture on the screen or anything
I assume your screen is completely black and maybe doesn't show the flashing cursor? It could ether be the graphics/video chip at fault, or a hard drive or motherboard fault. It could even be the screen itself.
Does it sound as if your laptop is actually booting up, even though you can see nothing on the screen?
If you can, connect your laptop to a computer monitor (a cable will be required). If your display works on the computer monitor it's probably your video/graphic chip at fault.
If the screen is still black after connecting to an external monitor the chances are that it is a hard drive or motherboard fault.
Don't rush off and buy a replacement hard drive and motherboard. It makes more sense to take your laptop to a shop, pay for an inspection and they will tell you exactly what the fault is.
Jun 09, 2013 | Acer Aspire 3000 Notebook
I have an acer aspire 3000 I logged off last night and today went to turn it on it powers up but it won't display anything just a black screen
I think your OS might have gone..... So try installing an OS CD in it and see if it displays something or not. If not then your display is gone. You have to repair it in a repairing shop.
Jun 09, 2013 | Computers & Internet
Why won't my laptop boot?
sounds like an unhappy computer try this
turn off computer
press F8 and turn power on at same time
should open to SAFE Mode
run that for a bit then restart
let me know how that works for you
May 22, 2012 | Apevia Lithium Ion Battery Pack 4400 mAh...
Acer aspire 5349 won't boot
I had the same problem. I clicked on F2. in Bios screen I press f10 (save and exit), and windows started.
Apr 02, 2012 | Acer Aspire 9300-5349 Notebook
My dvd-rom on my Acer Aspire 3000 notebook won't
Navigate to the following location:
1. Start> all programs> acer>acer erecovery management. 2. Click on "restore". 3. Click on "Reinstall Drivers or applications". 4. Click on "contents". 5. Select the driver from the list and install.
Sep 15, 2011 | Acer Aspire 3000 Notebook
I have an acer aspire 3000 series and when I turn it on the acer logo shows up on the screen, but after that the screen just goes black.
Hi
If this problem is a recent one and the notebook was working fine
You could try to start up in safe mode then do a system restore back to when you reckon it was ok
Nov 13, 2010 | Acer Aspire 3000 Notebook
Acer Aspire 3000 Notebook Logo
156 people viewed this question
Ekse
Alun Cox
