I have windows 2003 server if i make repaire for the windows i will lost my ip adress and setting or not i just want to know
  • 67 Answers
Go to Start - Run,. then type in the box CMD.
At the command prompt type ipconfig /all
Write down your settings. Type EXIT to close the prompt window.
IF you're on DHCP, there is no need for this, as you will be allocated an automatic IP when your network card is initialized.
Posted on Dec 02, 2008
How to change the server aol to my google chrome on start up
Dynamic host configuration protocol (DHCP) is a way to configure IP addresses and TCP/IP settings throughout your network.
The DHCP service is run on a machine with a static IP address so that the computers on the network can find it for automated configurations.
Setting the IP address on a Windows 2003 server is accomplished through the network configuration settings in Control Panel.
Click the Windows "Start" button and select "Control Panel." Double-click "Network Connections." In this section, double-click "LAN Connection."
This opens the configuration tool to set the IP address of the server.
Select "TCP/IP" from the list of configured network applications and click the "Properties" button. This opens a new configuration window.
Select "Use the following IP address" to set a static IP for the server.
Enter the IP address chosen for the server in the first textbox that is activated.
Enter the subnet mask and default gateway for the server.
The default gateway is usually the router on the local network or the DSL or cable modem on a small, home network.
Enter the DNS server address.
The DNS servers are separate servers on the network.
For small, home networks, the DNS server is provided by your service provider.
Click the "Ok" button to save the settings. Click "Ok" again at the general LAN properties window.
Renew settings on local computers. Computers that use the DHCP server for configuration need to be rebooted.
You can also use the DOS command prompt to renew settings.
The "ipconfig -renew" command refreshes the settings on client computers on the network.
or for home page browser
Create the menu tab on your homepage right click in the top toolbar you should see a number of toolbar options select the menu tab which will add File Edit View Favorites Tools and Help
Click on the tools at the bottom of the drop down list will be internet options or
Click start control panel internet options you will see a home page box To Create Page Tabs type
each adress on its own line (type in google.com) or your preferred home page and browser
below that will be change search defaults click on settings you will see all search Providers
Toolbar extensions and Accelerators you have
have if dont need any of them you can disable or remove them
Click start type cmd press enter you will be in DOS mode
type in ipconfig press enter
you will see all of your internet connection details
Hope this helps
Dec 29, 2012 | Google Chrome
Tip
All GPRS manual settings (All network)Exlusive
AIRTEL MANUAL GPRS SETTINGS
AIRTEL LIVE
Proxy and Server Adress - 100.1.200.99
Accespoint Name - airtelfun.com
MOBILE OFFICE
Proxy - disabled/no
Accespoint Name - airtelgprs.com
Idea Manual Gprs Settings
IDEA GPRS
Proxy and Server Port - 8080
Proxy and Server adress - 10.4.42.45
Databearer - GPRS / Packetdata
Acces Point Name - imis
idea internet:
Proxy - disabled/no
Accespoint Name -internet
Vodafone Gprs Settings
VODAFONE GPRS
Proxy Address: 10.10.1.100
Proxy Port: 9401 or 9201
Data Bearer: Packet Data
Packet Data Access Point: portalnmms
vodafone internet
Proxy - disabled/no
Accespoint Name -www
TATA DOCOMO MANUAL GPRS SETTINGS
TATA DOCOMO DIVE IN
Proxy and Server adress - 10.124.94.7
Acces Point Name - tata.docomo.dive.in
DOCOMO INTERNet
Proxy - Disabled / No
Acces Point Name - tata.docomo.internet
Reliance GSM GPRS SETTINGS
Reliance GSM WAP Setting
Proxy Server Address : 010.239.221.005or 10.239.221.22
Port : 8080
APN: rcomwap or rcommms
Reliance GSM RCOMNET Setting
ACCOUNT NAME-RCOMNET
APN-rcomnet
BSNL GPRS SETTINGS
1] bsnllive
APN = bsnllive
IP = 10.220.67.131
PORT = 8080
2] bsnlmms
APN = bsnlmms
IP = 10.210.10.11
PORT = 8080
3] bsnlnet
APN = bsnlnet
IP = NONE
PORT = NONE
UNINOR Manual Gprs Settings
Proxy and Server adress -10.58.10.58
Acces Point Name - uninor
Videocon gprs settings
APN : vinternet.com
Videocon WAP
APN : vgprs.com
Proxy server : 10.202.5.145
Proxy port : 8799
on Jan 29, 2011 | Cell Phones
Bought a printer server called Networking USB LPR Print server. It`s softwear does not support OKI but the install wizzard asks for installation disk from OKI. When I start the OKI driver installation...
  1. log into router
  2. look at the leases issued by the dhcp server in the router
  3. note the ip address assigned to the printer
  4. change the lease to be permanently leased to the printer server
  5. the print server will have a device name . you should be able to figure out which ip address is assigned / leased to it .
  6. You never assign a print server , or server or printer with a temporary dhcp ip address ! hence why you should change the lease of it to permanent .
  7. Then it will be assigned the same ip address by the dhcp server .
Mar 18, 2017 | OKI Computers & Internet
Need ip address for syrens, not sure if i remember right: 192.168.1.1???
Hi Stephan,
the ip address of your router by default should be "192.168.1.1". to check if the ip adress of your router here's the solution :
  1. go to control panel > network and sharing/networking >change adapter settings
  2. then you'll see your local area connection
  3. right click on it>properties
  4. double click on (internet protocol tcp/ip) "tcp/ipv4 in windows vista/7
  5. the select "obtain ip address automatically" & "obtain dns server464142c.jpg automatically" click ok and click ok for the other window
  7. the dns server ip show should be your router ip adress
  8. open your web explorer and type in your router ip an press "enter" you'll get your router configuration where you'll be able to change the default ip.
I hope that it will help & don't forget to rate
Kind regards
Feb 14, 2010 | Sea and Sea Syrens OnBoard WiFi...
Airtel gprs setting for asusp320
Airtel Live
Profile Neme: Live
Homepage: http://live.airtelworld.com
Username: blank
Password: blank
APN: airtelfun.com
Proxy and Server Adress or IP: 100.1.200.99
Port: 8080
Data bearer - GPRS or Packet Data.
Authentication: normal
Airtel GPRS or Mobile Office
Profile Neme: mo
Homepage: http://google.com
Username: blank
Password: blank
APN: airtelgprs.com
Proxy and Server Adress or IP: 202.56.231.117
Port: 8080
Rate this solution.
Jan 06, 2010 | ASUS Mypal A730W Windows Mobile 2003
I DONT KNOW HW TO CONFIGURE THE IP ADDRESS IN DOS MODE SO PLZ .HELP ME...AND GRAND ME THE CODE OF CONFIGURING SYSTEMS .. THANKING U IN ADVANCE SINCERELY FASMIN
You can use the netsh command to configure Ip adresses.
1. IP via DHCP:
netsh set address name="MyLocalAreaConnection" source=dhcp
2. static IP:
netsh set address name="MyLocal AreaConnection" source=static addr=192.168.1.61 mask=255.255.255.0 gateway=192.168.1.1
- no line breaks in the commands
- change names and numbers to your needs
- check on mistyping and spaces between the commands
Feb 23, 2009 | Microsoft Windows Server Standard 2003 for...
System error
Your computer and another computer are sharing the same ip address. Unplug your modem for 5 minutes than plug it back in, this should change your ip adress and inturn fix your problem. If this fails than unplug your modem for 8 hours (overnight) and that should definetly change your ip address. If that fails than call your internet service provider and they can walk you through the steps to change it manually. I could explain the procedure but its better if they walk you through it step by step.
Let me know how it goes. Good luck.
Jan 09, 2009 | Microsoft Windows Server Standard 2003 for...
Windows 2003 server
after u make arepaier u have to make aback up for ur setting and u important file
you can make last good configuration and get it agen then make aback up
to get alast good configuration
restart ur computer and press (f 8) whaen u saw dos screen
after (f 8) step
choose
last know good configuration and choos atime for the day u want to get your system back
Dec 02, 2008 | Microsoft Windows Server Standard 2003 for...
Email Address Problems
You must enter a DNS server on the "Network Settings > TCP / IP" page. If you're unsure of it, try copying your default gateway.
Jan 31, 2008 | Samsung CLX 3160fn All-In-One Printer
Dns error 80710102
Hey peterk18,
First of all, how is your network configured? Are you behind a router? What's it's IP adress, does it act as a DHCP server?
If so try to set up a new network connection and put everything to automatic.. When the routers acts as a DHCP server it will give the PlayStation 3 an IP adress. DNS however is something else. DNS is a system that allows you to browse by a website or hosts name. For example: it allows you to type www.google.com in your browser instead of it's IP.
DNS is essential for Internet. Your router should be your DNS server and your router itself also needs to know a DNS server, this would be the server from your ISP. All these settings are automatically configured via DHCP.
Greetings,
DarkNeogen
Jan 12, 2008 | Sony Playstation 3 (PS3) Console
Computers & Internet Logo
David Payne
David Payne
