Question about Lexmark E332n Laser Printer
Lexmark E332n printer only prints half way but test page prints fully
  • Lexmark Master
  • 32,281 Answers
Click on Printers & Faxes, right clisk on your printer then Properties, then Device Settings. Check the paper sizes in Form to Tray Assignment (I use A4, think USA uses letter, you Yanks do strange things)
Also check Installed Options - Printer memory (make sure it matched the installed RAM).
Make sure you have installed the correct printer driver for the version of Windows operating system.
Posted on Dec 02, 2008
My Lexmark e332n shows error code 43 ,what does it mean?
G'Day Mate,
Are you running the Lexmark driver for Windows 7 64 bit.
Try down loading the driver and installing it on your p.c.
Suspect USB driver for printer is missing - Windows can't detect it as it doesn't recognise it. By installing the Lexmark driver it updates windows to recognise the lexmark printer usb interface.
you will find driver here
http://support.lexmark.com/index?locale=en&page=product&productCode=LEXMARK_E332N&segment=SUPPORT&userlocale=EN_US&frompage=null#1
Aug 14, 2015 | Lexmark E332n Laser Printer
My Lexmark E332n (b/w laser) has worked perfectly for 3 or 4 months, then started jamming, creating a concertina effect on paper stuck between the output rollers. The upper of these is the heated roller...
Hi there maximum time we found it is a the head problem. The print head is what the cartridges sit in inside of the printer. For resolve the problem please follow these.
Open the printer and wait for the carriage to slide over. Some how if its not come then Unplug the printer & Manually slide the carriage. Now Remove the ink cartridges from the print head & Use wet warm cotton swab or use alcohol to thoroughly clean the print head. Repeat this until there is no ink residue coming off on the cotton swab. After finished it make the head dry then fix it back. Now Try to print something now
If that does not work then follow the next step.
Remove the printer data cable & restart the PC & printer. Then fit back the data cable & turn on the printer. Hope that's start working , if no luck then Uninstall the printer driver & restart the PC & Printer both again. Now install the driver of the printer and connect it with PC ,Turn on printer & go for a test print from the printer preference. Thanks & waiting for your reply.
Dec 22, 2010 | Lexmark E332n Laser Printer
How to reset PC kit e332n
To reset the PC page count, while the printer is on, open front cover then press the cancel button.
NOTE: The photoconductor page count should be reset only when a brand-new photoconductor kit is installed. Resetting the page count without replacing the photoconductor kit could cause the photoconductor to operate beyond its intended life and thus create print quality issues.
Oct 01, 2010 | Lexmark E332n Laser Printer
Resetting the PhotoConductor Count
Following are the steps that you have to follow:
1. Press and hold Start
2. turn on the printer
- this is service mode -
- by pressing the Start you can print Printer Settings Configuration sheet -
3. press and release Cancel 4 time
4. Press and hold Start while all lights start cycle
5. press and hold Cancel untill all the light cycle
6. turn the printer off to exit the menus
Thanks
May 06, 2010 | Lexmark E332n Laser Printer
Lexmark E332n won't pick up paper from tray
There are rollers inside which you can replace and they NEED to be replaced after a certain time. Part number looks like 56P1820 but i would contact the Lexmark technical support to be sure of the part number and how to order them. It's easy to install, usually it's just clips to pull it out, and you put the new one there.
Jun 10, 2009 | Lexmark E332n Laser Printer
My lexmark 232 shows the light "toner low/replace pc kit". how do i do that?
The Photoconductor Kit designed for use with Lexmark E230, E232, E232T, E238, E330, E332, E332N/TN, E240, E340 and E342. Yields 30,000 pages.
Have you printed 30,000 pages on this unit? If not perform the following reset:
Procedure for E-232 is:
1. press and hold Start
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Dec 20, 2008 | Lexmark E232 Laser Printer
Allignment
One possible cause could be -
The Form Size setting in the
printer driver is different than the
size paper that is loaded in the
tray. For example, you inserted A4
size paper into the selected tray
but did not set the Form Size to
A4.
Sep 01, 2008 | Lexmark E332n Laser Printer
Lexmark E332n Laser Printer Logo
190 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
