Question about Magic Koritech Plus 2005 Microphone
Koritech HandyStar - 2004 - Cannot keep turned on - switches off
When connected to the tv and power source, the mic has a difficult time turning on. And if it does get turned on, if the mic or wire is moved, it turns off automatically. Maybe a short?????
Hi my name is thelma i own a kirotech magic microphone i have a problem the power it wont on my email address thelma_baquiller@yahoo.com
Posted on Apr 11, 2009
My 32inch LCD TV keeps losing tuning when turn off when turn back on have to program like new every time I turn it off
K.A.M. is kept by constant power if you are just turning off with remote not unplugging from power and SURE that power source has not been removed (like having it on a on/off wall switch) problem is internal.
Oct 03, 2014 | Televison & Video
Keeps turning off
Everytime I worked on this set I have found bad connections in the power supply or on one of the inverter transformers
Dec 31, 2013 | Philips 42PFL5603D 42 in. LCD HDTV
I have a Yamaha IM8. I had a condenser mic hooked into channel one with phantom power on. I had to leave the room for a while and when I came back, I noticed some rather severe popping in the audio. I turn...
There is really no way for a condenser mic to damage the board UNLESS you break the ground and get a static discharge into the input. That can happen with any microphone and has NOTHING to do with the phantom being on or off. As phantom power goes on and off slight bias at the input preamps can make amps non-linear causing the raspy sound you heard. The Phantom LED means NOTHING as it shows the state of the phantom switch by connecting a 12 volt source through a resistor to the LED... It shows NOTHING regarding the state of the 48 volt supply. Each input circuit has two 6.8Kohm resistors to the swinger of the phantom switch 2nd pole that either grounds those or connects them to a filtered 48 volt source. As long as you don't have a static buildup there is NO need to turn phantom power on or off while connecting a condenser microphone. At each input when using the XLR jacks are two per side 470pf capacitors for RF bypass. For the XLR's there is a 10Kohm between the signal lines and two series 10mfd/50 volt caps in series of each input to block the DC, when using phantom power, from reaching the preamp stage. These caps have to charge and discharge when changing the state of phantom power so you should AVOID having the main amps being driven while changing the state of any phantom power. Always have the fader(s) down and any monitors down to avoid a thump and also the non-linear raspy transition as the input caps charge/discharge. So fix the microphone... don't know what type you have, but DO check the cable (first) as ALL three conductors MUST be good for a condenser mic to work on phantom power. A ground leakage or noisy connection will cause your symptoms. Use a SHORT known good cable right at the board to test the mic. The 48 volts is applied through the two 6.8K resistors between both the signal lines to the shield of your XLR cable. The microphone picks off the 48 volts with a similar circuit.
Now let's cover a very important thing regarding system safety: ALL, and I do mean ALL interconnected equipment MUST be powered from the same source. Professionals run a power cord back to their mixer right alongside the snake. This is to avoid ground bounce damage due to bad building grounds or ground faults.
Mar 22, 2011 | Yamaha IM824 24 Channel Mixing Console IM8...
SET THE TIME ON THE CLOCK. WHEN STARTING THE CAR AT A LATER, THE TIME HAS CHANGED. 2004 FORD EXPLORER.
is an after market radio installed in the vehicle? if so, it sounds like you have the yellow wire (constant power) connected to a switched power source. you need to connect it to a source that is still hot with the key turned off.
Jan 28, 2011 | Car Audio & Video
Sony Trinitron KD-28DL10U switched off suddenly to standby mid programme and won't come back on.When trying the remote on I can hear it click on and immedietly off again.Switched off at set and socket and...
Hello
In time as the Sony Trinitron ages it begins to have power issues. While this can be true of most tube televisions it's the rate and severity at which this happens to Trinitrons that makes it particularly of note. Many Trinitron owners have complained of the Trinitron set turning itself off randomly and frequently. Some sets have failed to stay on for longer than a few minutes at a time. Eventually some sets will not turn on at all. These problems grow more severe with age.
Check the power cable running from the Sony Trinitron 32. Make sure the cable is completely inserted into the power connection on the rear of the TV as well as the local power outlet.
Disconnect the power cable from the electrical outlet, then plug it into a different connection. It is possible to electrical outlet has died, forcing you to obtain a power current from a different source.
Check the cable connection running from the cable/satellite receiver or VCR. If the TV is on but no picture is on the screen, the problem is most likely due to a connection issue.
Power off the cable/satellite receiver, then press the "Video" button on the remote control to switch the Trinitron 32 to the video input signal. Turn on the cable/satellite receiver and the programming now loads onto the television screen.
Nov 21, 2010 | Sony FD Trinitron WEGA KV-34HS510 34" TV
I have a 19" phillips lcd tv and when i turn the tv on the phillips screen comes up but when it is going the show the channel it shut off by itself how can i fix this problem?
Hello. I may be able to assist you. If you are using a direct cable connection from the wall outlet;
  • Check the incoming cable or antenna signal connection to ensure that it is properly secured to the TV's antenna input.
  • If the connection is good, perform the automatic installation again to search for all available channels.
If you are using a coaxial connection from the Cable or Satellite box to the TV;
  • Set the TV to the channel specified by the service provider.
  • Change the channels at the Cable or Satellite box to view the program.
If you are using a video connection (CVBS, S-Video, YPbPr, HDMI) from the source (DVD, Cable or Satellite box) to the TV;
  • You do not need to perform automatic installation to search for the channels.
  • Press the 'SOURCE' 071218044349_22024.gif button on the remote control repeatedly to select the correct input source.
If you are using an HDMI connection from the source (DVD, Cable or Satellite box) to the TV;
  1. Reset the TV and source by unplugging it from the power outlet for 30 seconds.
  2. Turn on the TV and press the play button on your source device. If the source is HDMI CEC compliant, the TV will automatically switch to the HDMI input.
  3. If your source is not HDMI CEC compliant, turn on the TV and switch to the HDMI input.
  4. Turn on your source.
If you are sure you have selected the correct input or channel but still have no picture or sound;
  • Try resetting the TV by unplugging it from the power outlet for 30 seconds.
  • Press the 'SOURCE' 071218044349_22024.gif button to select the correct input source.
  • Check the connection cables.
  • Try the connected source with another TV.
  • Connect a different source on the same connection of your TV.
Dec 14, 2009 | Televison & Video
I did not use my mic for about 6 months. It was
If it is an adapter type power supply, you may need a new adapter. If this type of supply is left plugged into the wall over time it can burn out from overheating or transients in the power etc. Also it appears that these have rechargeable batteries in them. Have you tried putting double A batteries in the battery compartment if there is one? The website is :http://www.magicsing.com.ph/faq.html#5
Aug 11, 2009 | Magic Sing Along Consumer Microphone
Rca Big screen shut down and now no power
NO audio and no picture .... no power to on - off button. Checked outlet and it is good .... cable connection good - checked with another tv....
Jan 25, 2008 | RCA HD56W58 56" TV
325 people viewed this question
Top Magic Audio Players & Recorders Experts
Michial Gueffroy
conquer111
Level 1 Expert
Are you a Magic Audio Player and Recorder Expert? Answer questions, earn points and help others
