Question about Toshiba 32AF42 32" TV
Power button flashing red, cannot turn on or off...
I'm a consumer (non-technician) and have had this Toshiba TV for a little over 4 years with absolutely no problems with it up until now. Yesterday (while watching the TV), the screen suddenly went blank and the power button on the front of the TV start flashing on and off. Pushing the button does nothing, and I tried unplugging it and then plugging it back in, but the flashing power button simply returns. I'm just trying to get an idea of what might be the source of the problem here and to get a rough estimate of what it might cost to repair it. If the cost will likely be more than $200, then I may just want to look into buying a new TV. Thanks in advance to anyone who can assist here...
  • 1 more comment
  • Tony Lewis Feb 14, 2007
    Thanks so much for the help!
  • Anonymous Oct 01, 2008
    Before my TV went out, it had white flashes about 7 - 8 seconds apart - horizontal lines too.
    I'm looking for a solution as well.
  • Anonymous Mar 14, 2014
    When I push the power button on the tv, it flashes to turn on but nothing comes up and the red power button light flashes over and over.
    Scholar:
  • 168 Answers
This symptom is usually caused by a breakdown in the power-supply circuit. in most modern receivers (transistorised and/or ic), it may also be caused by a breakdown in the horizontal deflection circuits (horizontal oscillator, pre-drive or drive circuits.). this is because the supply volatages for the tuner, video intermidiate frequency(VIF), video amplifier, sound intermediate frequency(SIF) and vertical output circuit are usually supplied by the horizontal output circuit. since you are not inclined with this kind of job, better bring it to a qualified tv technician. with regards to the cost of repair, i cannot tell you the price since my location is different from yours. but to give you and idea, here in philippines $100 is enough for this kind of trouble!
Posted on Feb 13, 2007
Hi Toshiba Team, I have a Toshiba MD20FL1 and need a new remote control. Tried 2 different remotes and none of them worked so far. I know that this Toshiba model is a little old for a TV but I don't...
Hello
You just buy one Philips Universal Remote Control model number [CL 034]. Your Toshiba set is listed in its codes and are given here.
......... 0517 0419 0512 0613
........................... 0719 0112 0506 0111
........................... 0618 0627 0437 0041
................. 0094 0802 0111 0313 0715
Direct Code Entry
1. Press and hold the CODE SEARCH
button until the red indicator stays
on, then release the CODE SEARCH
button.
2. Press and release the desired Mode
button (TV, VCR, etc.). The red
indicator blinks, then stays lit.
3. Enter the 4 digit code from the code
tables. Note: after a valid code entry,
the red indicator turns off. For an
invalid code, the red indicator
flashes.
4. With your device on, press
CHANNEL UP. If the device
responds, no further programming is
required. Note: If some buttons do
not operate your device, try one of
the other codes for your brand
Code Search (by Brand)
Lets you search for a code for a specific
Brand within the Code Library for a
particular manufacturer.
1. Turn on the device (TV, VCR, etc.) to
be controlled.
2. Press and hold the CODE SEARCH
button until the red indicator remains
button.
3. Press and release the desired Mode
indicator blinks off once.
4. Press and release the numeric button
(0-9) corresponding to desired
Manufacturer (see table below).
Note, pressing "0" performs a full
library search same as Device Library
Code Search Method.
5. Press the CHANNEL UP button ((or
POWER or PLAY (VCR only))
repeatedly until the device to be
controlled changes channel.
6. Press and release MUTE to install
the code.
Note, when all codes under a Brand
have been searched the red indicator
flashes rapidly for 3 seconds
Dec 08, 2010 | Toshiba MD20FL1 20 in. TV/DVD Combo
My Toshiba 62HM95 62 in. HDTV DLP TV won't turn on...the green and red lights under the power button remain on and the red light flashes. How do I fix this?
Most likely, you need to replace your DLP bulb. The one that comes with your TV will last a few years max. The replacements seem to only last about a year. D:
Dec 08, 2010 | Toshiba 62HM95 62" DLP HDTV
Tv won't turn on
what remote do you have? if you have a little button called "tv" or "tv2" press one of them and then try tu turn on your TV.
Apr 07, 2010 | Toshiba 32AF43 32" TV
My toshiba TP50H15 color tv comes on then off and the light blink
The flashing power light on those Toshibas is usually caused by capacitors on the power board having failed solder connections. I have fixed them before by removing the power board and resoldering the capacitors. If you have experience with soldering and electronics it is an easy repair. Most shops will recommend replacing the entire board since their labor to repair it would probably cost more. Toshiba put out a service bulletin on this issue which a good technician should be aware of. (If memory serves the capacitors are C109 and C110.  Since your TV still turns on you probably haven't blown fuse F860 which often blows when these capacitors act up.)
If you would like further help with this please post a comment back here.
Dec 05, 2009 | Toshiba TP50H50 50" Rear Projection...
Cannot find code to program sky remote control
please follow the steps below:
TV
RED + SELECT (flashes twice)
TV
0156
try the volume if this works then press SELECT to save the code. If not then press TV again then the volume. repeat this step until the volume works then press the SELECT button to save the code.
cheers
Little Dish Fitter
Mar 12, 2009 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
SKY REMOTE
Press TV
Press and hold Select & Red until the LED blinks twice
Press TV
Type in code 0 0 6 0
press the Power button on the remote, if the TV turns off press the select button and everything should work, if the TV stays on press the TV button on the remote then the Power button again, keep doing this until the tv turns off, when it does press the Select button and all should be ok.
Feb 01, 2009 | Toshiba MR120 Remote Control
Tv won't turn on or respond
the power supply is faulty, check the following for lekages
power transistor
rectifier diodes
fusable resistors
also griver transistors
Nov 25, 2008 | Toshiba 35A44 35" TV
Red light flashing while green light stays on
I have the same TV, your projection bulb has quit/failed.
A loud pop was heard and the picture has gone followed by a red led fault light clicking on and off.
if your tv is less than 1 year old, and you registered it with Toshiba, you could qualify for a free replacement.
otherwise expect to pay 200.00 for a new bulb from Toshiba.
only good thing is you can replace it yourself, only tool needed is a phillips screwdriver.
you can check EbaY for prices less than 175.00 to 150.00
i am on my 3rd bulb within 4 years....
good luck!
Aug 19, 2008 | Toshiba TheaterWide 52HM84 52" Rear...
TV is not powering up and red light keeps flashing
I had the same red blinking led problem on my Toshiba Theaterview tv. I resolved by:
- Unplugging the tv.
- Press several times (3 or 4 times) the tv Power button.
- Plug the tv back in and press the Power button once to turn the tv on....tv worked!!!
I've had the problem before and tried unplugging the tv for a couple of days and that had also worked, but I this recent solution seems to be faster.
Erick
Jul 29, 2006 | Toshiba 55H70 55" Rear Projection...
Toshiba 32AF42 32" TV Logo
94 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
