Question about Plumbing
Loss of Hydrauils
Allis Charmers 7060 Tractor
I lent my tractor to a frend ,and when he had it he burst an oil line , I replaced it and it had no lift . I canged the oil ,fillters and dismantled the main piston pump and could not find the problem . It will lift very slow and jumpy at low revs but on higher revs there is nothing , it also has the same affect on the steering and brakes . I put on a second hand pump and that was the same . It is like there is a lack of oil getting to the pump . I know the Allis Charmers have a very complicated system with three pumps . But can you please help .
Thanks Brian Lucas
  • 15,935 Answers
Did you bleed the lines going to the cylinders? Unlike oil, air is compressable, and needs to be bled out like brakes on your car. After priming the pump, loosen the fittings at the cylinders and try actuating a few times. Once unaerated fluid comes out, tighten the fittings and actuate the cylinders a few times.
Posted on Dec 22, 2008
I am looking for a right side knuckle and key for my 1983 Allis charmers 6140 tractor and that is what my service manual calls the part, but I cannot find the part number anywhere to tell part guys
try these folks .i actually use them for parts for old h.d/farmall parts fit her/but old tractors are their thing
even without a part number maybe they can find you the right part or number/what fits what substitution
http://antique-tractor-parts.steinertractor.com/tractor/Steering-Knuckle
Mar 28, 2017 | Garden
How to change oil seal in allis chalmers 175 hydrolic lift arm and how to get cylinder off of tractor
First, a cyl. repair rebuilt kit. The cyl. shoud have pins on each end. Remove cotter pin hen remove pins.
Jun 13, 2016 | Garden
How to install belt on allis charmers AC 130 riding mower
how to install pulley belts on an ac130 46" cut
Jun 18, 2012 | Garden
How to replace rear oil seal. Allis D-17 series III. Constant oil leak. Not tried yet do not have info
Separate the engine and the transmission, then extract the seal and press in a new one. I hope this helps. Joe
Feb 11, 2011 | Dmm Allis Chalmers Tractor D17 Series 4...
The hydraulic pump does not shut off and the lift arms will not go down on my d19 allis chalmers tractor.
Sounds like you have a hydraulic flow valve problem. Check the lift arms when the pump is running to see if you have any hydraulic fluid leaking there.
Nov 18, 2010 | Dmm Allis Chalmers Tractor D19,d21,210,220...
Alis charmers 190 xt serisi 3 rear poser take off shaft Transmission fuild or oil going into the hydrolic side and overfilling
The seal between rear housing and the middle housing for the pto shaft needs to be replaced, if you continue to use it you will cause damage to the rear end due to lack of lubrication.
Nov 10, 2009 | Diesel Allis Chalmers 190xt Tractor...
Transmission oil pressure above 1800 rpm is on
I had the same problem I replaced 2 switches, the first failed because of leaking, the second switch just stayed triggered, with a gauge installed I got 35psi @ 1500 rpm, I really think there is a problem with the new replacement switches, I ran the tractor for about 10 hrs with the gauge installed and it maintained 35-40 psi only dropping with the PTO ingauged or the P/S shifted.
Allis 7000.
Nov 07, 2009 | RTO Allis Chalmers 7000 Tractor Water Pump...
Allis chalmers AC 5040 is leaking water/fluid
looking for in the oil cooler inside the radiator maybe is broken.
Jul 11, 2009 | B&C Allis Chalmers Tractor B,c,ca Flywheel...
Plumbing Logo
83 people viewed this question
Top Plumbing Experts
Tom Chichester
Paul Carew
Are you a Plumbing Expert? Answer questions, earn points and help others
