Question about Frigidaire FGF316 Gas Kitchen Range
My oven is not getting gas to heat it up - Frigidaire FGF316 Gas Kitchen Range
    Scholar:
  • 65 Answers
Depending on how long you have had it but I would take the hoses and make sure that they are not clogged, Or make sure that every thing is hooked up the way it should. With gas stoves you have a nob that tarns off and on I would check that as well. As well make sure that you take your time and be careful. where I come from the shops are very helpful when you call with questions, If it came to it and all else fails I would call and say what the problem is and see what they think, let them know that you are needing to get an idea of the cost for fixing.
Posted on Dec 02, 2008
GAS OVEN WILL NOT GET HOT
see this instructions and fix it. God bless you
  1. eHow
  2. Home & Garden
  3. Home Appliances
  4. Other Home Appliances
  5. How to Troubleshoot a Gas Range Oven That Won't Heat
By Kefa Olang, eHow Contributor
Although gas range oven may prove useful for cooking and baking, they may fail to ignite if they aren't properly maintained and set up. Lighting a gas range often involves simply turning a knob; however, blockages from food particles and debris caught in the burners, improper burner cap installation and gas supply are common problems that interfere with your gas range oven's performance. A few troubleshooting guidelines may solve these problems safely.
Other People Are Reading
Things You'll Need
  • Toothpick
  • Paperclip
Instructions
    • 1
      Check you have gas in your tank if your gas range oven won't heat. Contact your gas supplier if you've run out of gas.
    • 2
      Clean the burners if you have gas but your burners still won't ignite. To clean the burners, lift the burner caps 9b4f010f-be4f-4db6-8a88-4c3fd17e3339.gif
    • 3
      Inspect the small vertical holes on the side of your burners for dirt, food and debris. The gas won't ignite if they are clogged. Scrape dirt, debris and food from the vertical holes using a pointy object such as a toothpick or paperclip.
    • 4
      Reinstall the burner caps properly. If they are tilted or wobbly, the gas may not ignite. Install the caps on the right burners. Some burners are smaller than others, so match the caps to the appropriate burners.
    • 5
      Move the burner knob to the "Lite" position and wait for the gas to ignite. If it ignites, rotate the knob to your desired setting. If it doesn't ignite, contact a qualified appliance technician.
Jul 18, 2013 | Ovens
It won't heat up... even though there is a flame
Check The Power Source
If the gas oven won't turn on, the first thing to do is check the power source. Most modern gas ovens are electrically powered. Check to make sure the oven is plugged in and the breaker isn't tripped.
Check the Heat Source
When a gas oven won't heat, the pilot light can also be set too low; if the pilot is lit but the oven isn't catching, adjust the flame.
Newer gas ovens use electric ignitors that produce sparks. If the oven doesn't heat, the ignitor could be broken.
Feb 05, 2010 | Ovens
Oven works sporadically
IF YOU CAN SMELL GAS, TURN THE STOVE TAP OFF. Get it checked out immediatly.
Aug 03, 2009 | Whirlpool GS460 Gas Kitchen Range
Frigidaire gas oven not heating
replace the bake ignitor its getting weak
Jul 01, 2009 | Frigidaire FGB24T3A Gas Single Oven
GE SPECTRA JGBP35 Gas oven
Solved a similar issue. Sounds like your glowbar igniter is shot and needs to be replaced. While the glowbar is glowing, it is not heating up sufficiently to release gas into the oven. The heat you feel in the oven is actually from the glowbar and not from ignited gas. Replace the glowbard. Here is what I recommended to someone else:
"Would be helpful to know brand and model. However, most gas ovens use a glowbar mechanism that regulates the amount of gas released into the oven. The glowbar also ignites the gas (and usually stays on all the time the oven is on). Often, the glowbar fails to heat up sufficiently and, as a result, doesn't allow the oven to release sufficient gas. If this happens, you may also smell small amounts of gas in the kitchen. The glowbar is hot enough to ignite the limited amount of gas being released into the oven. This is probably why the oven heats up but heats up very slowly. It's also possible that the heat being experienced in the oven is being generated from the glowbar itself without any gas being ignited. If this is the case however, it is unlikely that your oven to get very hot at all.
The way to test to see if they glowbar is failing is to test the amperage traveling to the glowbar when the oven is on. You can do this using a "clamp on meter" (purchased at any Home Depot or Lowes). Depending on the particular kind of glowbar you have, it should read above a certain amperage (in my case the reading was 2.7 amps and it should have been between 3.2 and 3.7 amps). I ordered a new glowbar from www.appliancepartspro.com and installed it myself (very easy). It fixed the problem. Here is a link that explains it pretty well (http://www.appliance411.com/faq/gas_range_ignition_systems.shtml#glow). Hope this helps."
Jun 24, 2009 | GE Spectra JGBP35 Gas Kitchen Range
Kenmore gas oven won't heat up
If your ignitor is coming on that means the oven control is supplying the power to the ignitor and gas valve. So the gas valve is ok because it is allowing for a complete circuit so what the heck is wrong? The ignitor MUST draw 3.5 amps in order to open the gas safety and allow the gas to come out. The ignitor must be very bright, if it is dim then it is bad. (MORE)
Jan 18, 2009 | Whirlpool SB160PEE Gas Single Oven
Hotpoint gas oven
This is an indication of low gas pressure to the oven. This condition may improve when other gas equipment is turned off and worsen when demands increase such as during cold periods where heating plants are running. Contact your local gas company to check pressures at the burners and adjust the incoming pressure to the oven accordingly.
If you found this helpful, please Vote!
Mar 03, 2008 | Hotpoint RGB745 Gas Kitchen Range
Pilot heats up but gas will not come into bar with little holes in oven
Check the voltage at the oven gas valve, if you are getting 120v, then you have a bad gas valve.
Aug 08, 2007 | GE JGRP20 Gas Single Oven
Frigidaire FGF316 Gas Kitchen Range Logo
69 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
