Question about Radio Shack Cinego D-1000 Multimedia Projector
My cinego shuts down
When i turn my cinego on it powers on, then searches for tv. After going to tv channel, the light on the top in front starts flashing , then it shuts down, and flashes red........ It sounds like the fan on the rt. side is not spinning. We just replaced the bulb about two months ago.
  • CHEMETRA Dec 15, 2008
    i have a problem with my cinego d-1000 when i turn it on it plays for 10-15 sec. then button on top starts to flash red then system shuts down i have sent it to be fixed they sent me another replacement and it is still doing the same thing please help not under warranty anymore.
    Problem Solver:
  • 11 Answers
There are two fans on the right side. If one stops working, the Cinego will have the symptoms you have described. You need to send it in for repair. A local Radio Shack will tell you where to send it.
Posted on Jul 20, 2009
SOURCE:
RCA LCD TV gets stuck on one channel
sounds like you have an intermittent defective main board. ebay rca model for replacement board.
Jan 11, 2015 | RCA Televison & Video
MWe have one of these tvs and this morning it wont turn on although the light in front is red and it still wont turn on
I had the exact problem and couldn't do the factory reset or another reset that a Westinghouse tech told me to do over the phone - BUT I FIXED IT! This is what I did. With the TV facing me and power on and connected to my cable antenna (like normal - ready to watch TV) I took my right hand and started pressing all different buttons on the side of the TV in different order at random. All of a sudden the big W came on the screen so I called back Westinghouse technical assistance and she told me go to menu - then TV - then scroll down to channel search. Since all my cable channels are on channel 3 on the TV - the search found that channel and the picture and sound came on and works fine!
Sep 05, 2011 | Westinghouse TX-42F430S Television
Can't get it to auto tune
Hello
To set the TV to autotune do the following.
1 Press "Power Button" to turn on the TV. The Initial Setup screen appears
2 Press CH UP button on the remote control or on the TV front panel to start Auto Program, or press CH DOWN button to Exit.
When you start autoprogramme, wait until it is finished; otherwise it will skip over channels that are available. If it happens so, perform autoprogram again by turning on the power button.
The initial set up screen appears each time you turn on TV until you perform auto program.
To perform Auto Program again
1 Press "Menu" button.
2 Press"=>"to highlight Channel Menu.
3 Press "Down arrow button" to highlight Cable. Press "+" button to select.
4 Press "Up Arrow button" or 'Down arrow button"to highlight On or Off according to how you connected your TV. Press "+" to select.
5 Press "Down arrow button" to highlight Auto Program. Press [+] to search for channels
6 After Auto Program finishes press "Menu button" to exit.
To reset the TV to factory settings
1 Turn the TV on.
2 Hold down [Reset key] on the remote control.
3 Press and release the POWER button on the TV front panel. The TV will turn itself off,
then back on.
4 Release [Reset] key.
Ok.
Jan 20, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Antsig AP593 universal remote
Not sure if you've decided to throw your remote control away already or not. But try using the manual search code. Basically press "TV" (light blinks once), then press the "Up" channel button and the "up" volume button at the same time (light comes on permanently), then hold down "Power" whilst putting the remote RIGHT IN FRONT of the place where your tv receives signal (usually where you can see a light), and I mean right in front! Hold it down until your tv powers off. Then it should be configured and working. It took me about 1 minute or more for the TV to react and turn off. Then you can check if it turns on again and if the channels are working.
Jul 17, 2010 | Televison & Video
I lost the booklet with all the codes for my remote and i need the code to work my tv my tv is a symphonic
I suggest you try these steps..
1.Turn the television set on by pressing the "Power" button on the set.
2. Find the "Code Search" button on the Philips Magnavox remote. This button will be labeled or will be a different color than the other buttons on the remote (depending on which Philips Magnavox remote you own)
3. Hold the "Code Search" button down for about ten straight seconds. The light on the Philips Magnavox remote should then stay on.
4. Starting pressing either the "Up" or "Down" channel button on the Philips Magnavox remote. Continue pressing the same button until the television responds to the remote. It could take a few minutes for the channel to change so you'll need to have patience when searching for the remote code in this manner.
5. Press the power button on the Philips Magnavox remote once the channel has changes. If the device shuts off, press the power button again to turn the TV back on. If the TV turns on, the remote has been programmed correctly. Repeat the entire process if your remote is not programmed.
I hope this helps...
Jun 10, 2010 | Philips Magnavox Learning Universal Remote
My cinego is stuck on search mode. From the moment it turns on it starts searching as if I was holding the searching button down . The modes all run but search will not stop.
Try unchecking the "auto source select" box. Push the setup button on your remote (bottom row, second from the right), use the arrows (7, 0 , 9, or 5) to move across to "management" and down to "auto source select." Make sure it is unchecked (by higlighting it and pressing Enter, which is the 8 key).
Jul 19, 2009 | Radio Shack Cinego D-1000 Multimedia...
Cinego d-1000 starts with picture and then shuts down
the warning doesn't come on all projectors. Replace the bulb anyway!
Jan 26, 2008 | Radio Shack Cinego D-1000 Multimedia...
CINEGO
Mine does the same thing and I just replaced the bulb after waiting almost 6 months and I purchased one directly from Radio Slack. It will turn on for about 10 seconds and then goes into shut down.....At three hundred dollars I can't see putting another bulb in, when this one has less than 50 hours on it.
What do you think
Oct 29, 2007 | Radio Shack Cinego D-1000 Multimedia...
253 people viewed this question
Top Radio Shack Office Equipment & Supplies Experts
jasbo
jasbo
xxxxxx xxx
Pie-man
Pie-man
Are you a Radio Shack Office Equipment and Supply Expert? Answer questions, earn points and help others
