Question about Kenmore 24032\24036 Top Load Washer
Hot Water runs in fine but the cold only trickles into Washer,
It took an hour for the washer to fill a large load for the cold water rinse for 2 rinse cycle.
  • 78 Answers
The problem is your cold water screen filter is cluged up.
To fix it:
1. Shut off cold water to the washer.
2. Take off cold water fill hose from machine side and faucet side.
3. Inspect the screen filters on the hose and inside water valve.
4. If necessary to clean them remove from hose and valve with pick or small screwdriver.
5. You can clean them with old toothbrush under water stream.
Posted on Dec 02, 2008
    Scholar:
  • 65 Answers
There are 2 hoses. Hot and cold and if the nobs are not turned wide open then it will not give you the water like you want. Check to make sure that the hot water nob is turned to were the water should come out like the cold. If not that then check the water heater and see if it is set up the way it needs to be.
Nikki2913
Washer fills with water during spin cycle
Go to repairclinic.com and have model number ready. They have videos how to check it
Mar 02, 2015 | Samsung WA422PRHDWR 4.2 cu. ft Large...
Error code of NF (no fill) on samsung top load washer (WA422PRHDWR/AA) even after checking lines for restrictions and ensuring clean line filters (red and blue). Now, when it does work, it will only do a...
Put the temp select switch on HOT, start machine. If water comes out check the flow amount. If no water flow, replace inlet water valve. If there is water flow switch to COLD, start machine. If water comes out check the flow amount should be approximately equal or slightly more than flow on HOT. If no water flow, replace inlet water valve. Move selector to WARM, start machine. Now there should be twice the flow of water than there was with HOT and COLD temps. I suspect it is the HOT side of inlet water valve that has failed because machines usually rinse with COLD water.
Jan 20, 2013 | Samsung WA422PRHDWR 4.2 Cu. Ft. VRT Top...
The level of water in the rinse cycle is extremely low to the point that the clothes are not rinsed. Why is there such a large differential between the level of water in the wash and rinse cycle? How can...
Low water pressure or bad inlet valve, or clogged screens in fill hoses, check flow with hoses disconected these will be the causes! check hot and cold fills than check warm, any differnt all setting work?
Aug 23, 2011 | Estate ETW4400VQ Top Load Washer
Washer will barely fill with water for the rinse cycle it can take several hours.
hi..the reason to this problem is the pressure hose,
it might have got clogged.
check this out..
thank you..
kindly rate my response..
Jul 19, 2009 | Kenmore 22422 Top Load Washer
Long cycles on my whirlpool duet washer
it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Apr 01, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Cold water is slow when filling for rinse cycle
Turn off the cold water.
Remove the cold water hose from the machine.
Look inside the cold water inlet on the machine and clean the debris from the screen.
Problem solved.
Feb 22, 2009 | GE WJRR4170E Top Load Washer
Basin will not fill with water during rinse cycle but will agitate and spin.
most new washers have cold water only rinse and spray rinse ck cold water coming into machine during wash if no cold comes in suspect cold side of fill vale not opening ..could be wiring issue or a bad valve
Oct 24, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Kenmore 24032\24036 Top Load Washer Logo
122 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
