Question about Ovens
Coil in oven
I have a JBP24BOB5WH oven while cooking thanksgiving dinner, the coil in my oven sparked a few times then the coil snapped into. I need to know where to go to buy the coil and how to put it in the oven.
  • 76 Answers
Your closets appliance store should have part....most ovens if u look at back where burner goes thru wall....there is screw(s) undo them then slowly pull then wires will show with 2 more screws...undo them then go to appliance store they give you replacement then do reverse of above to install...should not cost more then $20 to buy
Posted on Dec 02, 2008
Can I oven bake oxtail from frozen
issue i see is will take longer to cook
ox tail normally thawed before cooking
oven baking dish or pot or slow cooker is another option with lots of water and vegies etc
into a frying pan browned all over to seal in flavor and juices
Use tongs to remove oxtails to a plate, setting aside.
2 Saut? onions, carrots, celery: Add the chopped onion, carrot, and celery to the pan.
Cook for a few minutes until onions are translucent. 3 Add oxtails, garlic, bay leaf, thyme, salt, stock, wine, then simmer: Add the oxtails back to the pan.
let me know when dinner is ready
Jan 14, 2017 | Ovens
LG double oven shows f9 code in both ovens
F9 is a problem with the oven door lock circuit. If the door is locked, it's probably a bad switch that tells the oven it's locked. If the door isn't locked, it's probably a problem with the lock mechanism.
A common problem on many built-in GE ovens (you don't say if yours is built-in or free standing...) is air circulation in the control panel. The fan that keeps the panel cool either stops working or gets clogged with dirt/dust and can't move any air. This causes the panel to overheat and can cause all kinds of odd problems and error codes. If you have a built-in, check to make sure the fan is working and the mesh screen behind it is clean.
Nov 19, 2013 | LG LWD3081ST Electric Double Oven
MICROWAVE OVEN HOW TO USE POWER LEVEL AND COOKING TIME. For example a want to cook pizza what will i use?
We probably need a little more info on your particular oven before suggesting what power levels and times. Do you know the wattage of it i.e 900w?
Does it have presets on it? Your manufacturer may have put auto programs on it to reheat, cook from frozen etc.
Final hint: If you are buying things such as frozen pizza, microwave dinners, the microwave instructions are usually on the box with a recommend time for a particular wattage oven.
May 04, 2011 | Ovens
Convection oven quit working half way through cooking thanksgiving stuffing
Call us right away with your brand and model number and we'll get the correct part out to you right away in time for Thanksgiving turkey!! We look forward to
working with you.
Oct 18, 2009 | Ovens
Dual wall ovens shut off
Would need the codes to be sure,but sounds like the control is out the part will run you around $200.00 And don't wait till two weeks before Thanksgiving  cause you won't find one till after New Years by then.lol Hope this helped you ou.t
Aug 31, 2009 | Whirlpool RBS245PDS Electric Single Oven
Oven door staying open about 1 inch
your going to have to replace both the door hinges, since they have been over extended past ninety degrees they are not able to close to ninety degrees. that is the only repair, i would also look closely at the inner door panel and make sure that is not "crowned" or bent from the force that might also need replacing
Nov 19, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Oven error
What is the make of your stove? I will also need to know if is like a whirlpool elite,pro,sport,ect...... you may be able to take the lower drawer out and see the model number on a white sticker. if you can i will need that as well.
Aug 18, 2008 | Ovens
Maytag MER5755Q2Q OVEN GREMLINS
Hi TbearFTW,
Try the Sabbath mode feature. It may realease the oven to cook for longer. Press the Clock button for more than 5 seconds. I think that is what you do to get the Sabbath mode canceled or set.
Nov 14, 2007 | Maytag MEW5530D Electric Single Oven
Ovens Logo
75 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
