Question about Acomdata Computers & Internet
Hard drive doesnt turn on
When i plug it into windows vista it make a small vibrating noise and nothing happens. when i plug it in apple it says its drawing to much power and it seems to **** power for my other external hard drive
  • Acomdata Master
  • 32,281 Answers
It appears that your USB hard disk is drawing power that exceeds what the computer's USB port can deliver.
If your USB drive has a power adapter, connect it to your USB drive before you connect it to the computer's USB port.
If your USB drive does not have a power adapter/connector then you need to insert your USB drive into a USB hub that is powered from the mains adapter. Connect this hub to your computer's USB port first and then connect the USB drive into the powered hub.
If none of this works then it is possible that you have a faulty hard drive. If possible test this drive in a computer, use a old computer.
Posted on Dec 02, 2008
My SimpleTech SimpleDrive Pininfarina 500GB... stopped working
open the hard disk casing remove the drive check it on some other casing
May 06, 2014 | SimpleTech SimpleDrive Pininfarina 500GB...
It does not read when plugged in, I had problems with it when for no reason it went from MY BOOK to Drive after several hours of trying to fix it, I eventually got into my music then I went to safely...
Turn on your computer, plug in your My Book external hard drive (double check that the power is properly plugged into the wall and the hard drive), If nothing happens then right-click My Computer (or labeled just as Computer in Windows Vista or Windows 7), Choose Manage, Choose Storage, Choose Disc Management, towards the bottom of the window you will see Disc0, 1, 2, & so on. Are any of them colored with a Black bar across the top and labeled as Unallocated Space? If so, then right-click in that box and choose create simple volume and format in NTFS. If you don't see your hard drive listed in this window, or if you are unable to partition and format the drive, then most likely your hard drive isn't any good anymore. If it's under warranty, then return it for a new one.
Jun 15, 2010 | Western Digital My Book Essential 1TB...
Its not getting recognized it doesnt show up in the desktop
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hello,
Open the external hard drive cover, remove the hard disk inside, and fix it back. Try again and let's see what happens.
If it still does not work, insert the external drive into the computer, feel the hard drive if it spins/vibrate from inside or if it makes a cracking noise.
If it spins/vibrate, it means the hard disk is still working. In that case, you have to get another external drive case/cover.
But if it makes cracking noise, then it means the hard drive is damaged and you need to get another one.
Take care
Jan 08, 2010 | Computers & Internet
My mac says that it cannot detect a hard drive but it is powered up and plugged into usb port. help!
I wish you all the best.
My lacie rugged 500gb triple interface normally worked but now doesn't load anymore. It makes a strange soft sound for 2 seconds and then nothing. help!!!!
Jan 06, 2010 | LaCie Rugged All-Terrain (301175) 160 GB...
Freecom 400gb not being detected
you may need to format it via Computer Management->Disk Management if there is nothing in it.
Apr 17, 2009 | Freecom (24358) 160 GB Network Hard Drive
Replaced hard drive but unable to re-install version of windows
hi,
have you checked is the drive detected in the system bios, because if it is detected in system bios only then can vista install on it, start the system and at the blue dell logo tap F2 to enter setup and check if you see the newly installed hard drive on the system bios.
Further Queries are welcome
Feb 26, 2009 | Computers & Internet
Usb connection using an ipod doesnt work
Make sure you have loaded the latested software from apple. Check in disk management if the ipod is seen by the pc. Usualy the probleme occurges if you have multipile hard drives. Windows assagins the the first open drive letter to the Iipod but the ipod software needs it to be E: drive. Hope this will help
Jul 04, 2008 | LG LFD7150 Shelf System
SimpleTech hard drive not found by my computer
if you are running windows, then check the following:
go to control panel -> administrative tools -> computer management -> storage -> disk management.
you probably have a drive (located on the bottom right) that is listed with no drive letter, just assign it a drive letter and see if it comes back, if not, the drive is probably not initializing and you might have to either format it or replace it.
Jun 12, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
This is because your bios is only configured to recognise up to 250Gb. what you need to do is download the latest bios updates for you mboard, install them on windows. then you shoud have no further problems with the HDD.
May 19, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
Computers & Internet Logo
271 people viewed this question
Top Acomdata Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Joe Goldman
Joe Goldman
Are you an Acomdata Computer and Internet Expert? Answer questions, earn points and help others
