Electric fan wont spin. Sometimes it will spin briefly for like three minutes. then it will stop. later and be hot . is there a relay or is it pulling too many amps or what . its through a twenty amp fuse. compressor and heater work fine. just the fan stops . does the motor need replaced or can it be rebuilt. thnkx
SOURCE: Window Air conditioner pulls too many amps
Friend,
ngfam1 At your service!
If the appliance is 10 years old or more you may not be advisable to put good money into bad! New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
You need a hands on tech for this repair!
We sell appliances for 65 years in a family business!
My customers Tell me every week about the Whirlpool and or Maytag Air-conditioners that they bought for the cheapest price at Lowes,home,depot or a number of the big stores , knocked tapped did not work or had some problem form day one !
We can not shop price now a days cause people will sell ANYTHING IN A BOX! It is not made by that big manufacture!
But the rights to the name have been bought !And used on the box!
First, Next time buy GE PANASONIC OR FRIGIDAIRE!
THE ROLLS ROYCE IS FRIEDRICH which can run for 20 to 30 years!! YES IN YOUR WINDOW!
Below I referred you to a great service nation wide!
If none of these tasks remedy the heat problem then here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
You will be fine
Bless You ngafm1
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF
SOURCE: RV air conditioner. Compressor running, fan stops before cool
The fan motor is getting hot and going off on the internal overload in the motor.
This is caused by either a low voltage, a bad capacitor, or tight or dry bearings in the motor.
To check the bearings turn the power off to the unit, then spin the fan blade if it spins freely then the bearings are ok.
To check the capacitor you will need some kind of tester or you can buy a capacitor and replace it, that's what a lot of people do. They usually don't cost very much.
To check the voltage you will need a voltmeter and measure the volts at the unit.
SOURCE: can my duo-therm air conditioner on my rv be recharged?
These unit can be recharged. 134A. You NEED A SERVICE TECH THAT KNOWS HOW TO CHARGE UNIT.RUS
SOURCE: Duo Therm RV Air Condiioner-Compressor comes on before fan motor
I'd have someone who's familiar with capacitors, (for safety sake), to test your fan run capacitor, and power to it. If capacitor is shot, fan won't start. Have to remove cover on upper unit, then cover on side at front where wiring is, to access it.
