My Compaq Preario 2100 displays a 'media test failure - check cable' error message when it boots up. How can I fix this?
  • mooney956 Dec 02, 2008
    Thank you so much for your help. It's been a blessing.
  • 67 Answers
Try these:
1. Check the BIOS, make sure the hard drive is being recognized and that boot order includes the hard drive, preferably before the LAN/PXE boot item. You may also want to test the memory in the laptop: http://www.memtest.org/
2. (ONLY if your tech savy), I'd check all the connection between the hard drive and the motherboard, usually there's some kind of adapter or ribbon that connects between the two but not always. You may want to look for a CMOS reset or pull the CMOS battery.
3. Take it in for service.
Posted on Dec 02, 2008
  • Anthony Perez
    Anthony Perez Dec 02, 2008
    You're very welcome! :) Happy Holidays to you and yours.
Acer aspire d257 pxe-e61: media test failure, check cable error
Your computer tries to "boot" (start-up) from several devices:
* floppy-disk (if installed)
* disk-drive (if not "dead"),
* CD/DVD optical device (if "bootable" media has been loaded)
* PXE --> Pre-Execution Environment -- checks if there is a connection between the network-adapter on your computer to a "boot-server" on your local network -- it can load Windows from that "boot-server".
The "media-test failure" indicates that there is no network-cable attached to your computer *AND* the other-end of the network-cable is *NOT* connected to the "boot-server". So, you can that "error" message.
Is your disk-drive "dead" ????
Jan 24, 2013 | Compaq Presario-Notebook 700 Series, 2500...
Error Message: PXE-E61 Media Test Failure Check Cable
Try resetting the BIOS to the default settings and reboot
Nov 28, 2009 | Compaq Armada E500 Notebook
Wile I am trying to boot it up it goes in to a loop
Hello.
That error message usually refers to a hard disk failure. Your hard disk cable could be loose or faulty. Or, your hard drive would need to be replaced.
I'd suggest to check the cable and run your system's hardware diagnostics (often F2 or F12) when your system boots.
Hope this helps.
Nov 26, 2009 | Compaq Presario M2000 Notebook
PXE-E61 Media Test Failure Check Cable on compaq presario 2100
A PXE-61 error message is most likely a faulty hard disk.
Try reseating the hard drive first and if you still get this error message again then you need to replace the hard disk.
To boot up with the CD you maybe able to press the F12 function key when you power up the laptop, this will bring up the a menu option to select an alternate boot device. If this option is not available then go into the BIOS configuration and change the bootup order and make the CD as the first boot device and the hard disk as the second device. You can can it back later.
Sep 14, 2009 | Compaq Armada E500 Notebook
When I try to boot up my Compaq Presario 2500 laptop I get the following error message: PXE-E61: Media test failure, check cable Operating System not Found. I have tried changing the boot sequence in the...
Boot sequence isn't enough. You have to turn OFF (disable) the boot from network. The error your seeing is result of the network boot rom not finding PXE server to boot from. Again, be sure to disable boot from network.
Jun 06, 2009 | Compaq Computers & Internet
Argon PXE Boot Agent v2.01 2002 - PXE - E61
Your computer tries to "boot" from several devices:
* floppy-disk
* disk-drive
* CD-ROM
* USB memory-stick
* over a network, via PXE (Pre eXecution Environment)
If you have a network-cable connected to the Ethernet port on the computer, with the other end connected to a "boot-server", then the Operating System can be loaded over this network-connection.
But, if you get "media test failure" and "check cable", then the network-cable for PXE is either non-working or not-present.
Any disk-drive that shows "ZERO" blocks is very probably a DEAD disk-drive. Replace it.
Jun 03, 2009 | Compaq Presario 2100 Series: 1170B01-90...
PXE-E61
Your disk-drive has failed.
So, your computer tried to boot itself over the Ethernet network,
by "broadcasting" a request for booting. When either the network-cable was _NOT_ connected, or when _NO_ computer responded to the "broadcast" message, you get "PXE: media failure".
Take your computer to a qualified technician,
to remove the "dead" disk-drive,
to replace the disk-drive,
and to reinstall Windows.
May 26, 2009 | Compaq Presario-Notebook 700 Series, 2500...
PXE-E61: media test failure check cable
"PXE-E61 Media Test Failure, System won't boot"
1.Go to Bios Settings
2.Remove LAN booting from booting options...For laptop ,type "X" on the LAN booting option.
3.Save The configuration(F10)
This Will Solve this problem
May 25, 2009 | Compaq Presario-Notebook 700 Series, 2500...
Not always the Hard drive, boot into the bios setup utility and de-select network bootfrom the boot options. If it tries to network boot first you will always get that failure.
Apr 12, 2008 | Compaq Armada E500 Notebook
Computers & Internet Logo
56 people viewed this question
David Payne
David Payne
