Question about Panasonic Office Equipment & Supplies
Replace lamp i need to know where the lamp is located in the tv because it needs to be replaced
SOURCE: Tv lamp replacement
I just did this myself. I'm a novice but it wasn't that hard. Your choices are to purchase a complete unit including the casing from a Sony repair shop for around $250, or just replace the lamp.
I just replaced the lamp and saved $130.
I just removed the screws from the side of the casing that protect the lamp. I disconnected the contact points and then popped open the housing.
Remove the screws and the nut that attach to the lamp. Wear gloves when you handle the new lamp so you don't shorten the lifespan of the bulb.
re-attach all the screws and slide it back in.
It took me the longest to have line up the contact points when sliding it back into the TV. Make sure all the connections are snug and keep at it. Don't give up! I'll admit I was tempted!
Posted on Dec 05, 2007
SOURCE: Lamp Replacement on Sony Wega TV
Please explain the location of the lamp for a sony kf-50we610 50 inch tv. Note same problem as above.
Posted on Sep 13, 2008
00Steven
  • 6 Answers
SOURCE: panasonic lamp
Brian, I just helped my buddy replace his Panasonic ty-la 1000 bulb this weekend. I have to tell you that I have a complete illiteracy when it comes to electronics but we got it done in about twenty minutes and were watching it again. Looks great. We ordered the bulb from dlp lamps.com and had it in about two days. They also had super easy instructions to follow. Try it before you replace the entire TV.
Posted on Sep 27, 2008
SOURCE: Zenith E44W46LCD Lamp Access Door Location
I found the location to get at the lamp. If you are loking at the front of the TV there is a small panel at the bottom of the right end. Two screws, remove panel, two screws inside and a small handle that lifts so you can slide the unit out. 4 screws on top of the cage that the lamp sits in, carefully slide up the silver bracket holding the bulb, be careful the edges are sharp. Remove the bulb from bracket and remove the 2 cables attached to the bulb. Now just do the same but in reverse. Make sure you wear plastic gloves that should be provided because if your fingers touch the lense you could be out the price of the lamp.
Posted on Oct 14, 2008
SOURCE: How to reset lamp timer
Have replaced lamp, need to know how to set lamp timer. I have replaced the bulb in my vivitek tv and need to also know how to re-set the timer. Can someone help with a vivitek tv ??
Posted on Jan 17, 2009
HAve a 42 Sony Wega rear projection TV. Need to replace Bulb but dont know were bulb is. Do I need to take off back panel?
the lamp is located in front below the screen. there is a plastic panel to remove(full width of t.v.) the lamp is in the center held by allen head screws(replacement lamp will supply an allen wrench) be carefull not to get fingerprints or dirt on front of lamp(premature lamp failure will happen) hope this helps.
Jan 16, 2010 | Sony Televison & Video
Where is ballast located
FOX has Lamp for $109.00 1-800-227-5369
Encompass Parts has Ballast $54.43 1-800-638-3328
Encompass wants $150.00 for lamp Your TV is a Samsung it will be on Right Hand Side of TV and I would Just Replace The Lamp First? What was your TV doing to begin with?
Dec 31, 2009 | Televison & Video
WON'T TURN ON 4 BLINKS,REPLACED IC 800,NO HELP.
If there is sound from the TV but no pictures and the indicator on the front of the TV is blinking four times then check if the projection lamp is okay.
Otherwise replace the projection lamp.
Nov 15, 2009 | Televison & Video
Need to replace bulb in lcd panasonic
After lamp replacement, make sure that lamp cover is properly fixed on its location and if TV still does not turn On then it is ballast power supply issue, qualified TV tech will fix it.
If you think you can repair ballast supply and have enough knowledge about TV repair, let me know to provide you technical info about that.
Oct 02, 2009 | Panasonic PT-50LC13 50" Rear Projection...
A warning pops up on the screen of my Panasonic PT50LC13 That my lamp needs replacing and I need to reset the lamp timer, how do I reset the lamp timer?
After replacement of lamp, turn on TV, press and hold Volume Down button on TV front and press and hold Split/ Play button on TV remote at same time for 6 seconds.
That will reset lamp timer and confirmation display will come at TV screen.
Above info are also available in original Panasonic replacement Lamp box.
Aug 19, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Ware is the bulb located in the 50inch magnavox
  • hello here is what you need to know .on the location of your lamp & the right way to replace it. first thing is to, Turn off and unplug the unit before you replace the lamp.
  • Take care that no screws or other metal objects fall into the display interior. Such items could cause fire or electrical shock.
  • Do not remove the lamp except to replace it. Careless handling can cause injury or fire.
  • Do not replace the lamp immediately after the display is turned off. The high temperature of the lamp could cause serious burns. Allow the lamp to cool down at least two hours after turning off the display. display. 051021165929_314.gifthank you for useing fixya.com .
Jul 24, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Lamp(lite bulb) is dead - need to buy replacement and install it
Click here to find the lamp for your TV. You will still need to use the existing cage assembly, once you remove the old lamp you will be able to see how it's assemble.
For the lamp replacement instructions, you will need to download the owner's manual and go to page 16 to 22 to know how is done.
Good Luck.
Jan 06, 2009 | Sony Grand WEGA KDF-60WF655 60" Rear...
Go to the menu and you'll find lamp timer section.
Aug 27, 2008 | Vivitek V37835 46 in. LCD Television
Apr 07, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Lamp replacement
on the front of your tv, remove the front black cover on bottom under this you will see the lamp cover. remove this then the lamp.
Nov 07, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
