SOURCE: Haier air conditioner
On the Compressor? - Theres a run (R) that gets the red wire from the run capacitor or line side voltage, theres a start (S) that gets the yellow wire from start capacitor and theres a common (C) that gets the black wire which connects to neutral or common. If you ohm it out to identify the terminals the highest resistance is between (S) and (R) second is between (S) and (C) and least resistances is between (R) and (C). Hope this helped. GL!
SOURCE: pulled was pulled from my unit
actually 3prong plugs consist of ground, live and neutral.look for the label at the terminal of the plug.the GND means ground.
SOURCE: My portable air conditioner Haier started linking
Hi. Check the drain hose and look for kinks and partial blockage. Even algae can often block these tubes. J.
Testimonial: "There was dust covering the entrance of a tube where the water used to flow and evaporate, it was right beneath where the air filter is located. Removed the dust and is working fine again. Thank you"
SOURCE: Need service manual or parts diagram for Haier HPRD12XH5 Air Cond
Here's its product manual
http://haier.afg-corp.com/1040ac7a68.pdf
SOURCE: I have a Haier 5,200 btu air conditioner that
E-1. Indoor room temp sensor defective. replace it.
