Question about Samsung Computers & Internet
My old monitor says "frequency out of range" on my new desktop.
How do i configure this??
  • devdot Nov 14, 2009
    i have windows vista and my computer screen is saying frequency out of range and when i try to go into safe mode and change if it will let me do that and when i start the computer over back in normal mode its still saying frequency out of range
  • Anthony Perez
    Anthony Perez May 11, 2010
    What monitor are you using?
  • 1,498 Answers
No Worries,
What you are experiencing is a frequent occurrence when monitors are upgraded, switched, whatever. Computers don't always recognize monitors as 'Plug n Play' devices. When you switch them out, the change may not be noticed.
What you are looking for is the 'Refresh Rate'.
Put the old (or new, which ever worked last) monitor back on and reboot. The screen should come up normally
  • Right Click the Desktop
  • Click Properties
  • Click Settings
  • Click Advanced
  • Click Monitor
  • Lower the refresh rate or set at optimal
  • Check the box 'Hide refresh rates this monitor can't display'
Shutdown, Switch back and try it now.
If it gives you any problems at all, comment me back. I'll walk through it with you.
Good luck
Mike
Posted on Dec 06, 2008
  • 849 Answers
Keep the system in low resolution.
Posted on Dec 02, 2008
Can't get anything on my monitor but 'out of frequency range' But I can't get anything on the monitor to be able to get into the computer to reset the frequency. Help
Restart the computer. As soon as the bios start screen displays, start hitting F8, about once a second. You will eventually get the windows start menu. Use "Last known good..." or VGA mode. Last known good should do it. If not, VGA mode will allow you to get into windows and change your resolution settings, then reboot and get back to work.
Jul 06, 2011 | Gateway GT5220 PC Desktop
Please help.. my monitor has no display and my don't even beep. the LED in the monitor turns back to orange after few seconds. cpu, disk drives and ram are working..
This is one of the serious problem that arises because if you set your monitor with a high resolution with high frequency, then the monitor doesn't display anything as it's frequency is out of the rang or limit of the monitor's actual resolution capacity. Each monitor will have a limit of max frequency that is said to be the Refresh rate (for each and every resolution setting the display is refreshed.) When high resolution is set with high frequency that is not supported by the monitor, it then display a message like "frequency out of range". If you press ESC key within the few seconds of this setting, it will revert back to its initial resolution. But if you continued with the setting of same High resolution with High frequency, the monitor is not going to display anything because its frequency is out of the range. Most of old monitors like CRT's etc doesn't support 1024×768 at a refresh rate greater than 60Hz.
Jun 20, 2011 | Asrock P4I45GV R5 Motherboard
Monitor displays frequency out of range.....need help . How can I solve this?
The frequency is out of range because the VGA graphics card is not compatible or set right for the monitor's set of frequencies that it can work with.
Try another VGA graphics card.
Or upgrade the card to one with DVI, and upgrade the monitor to one of those 24" DVI Samsung monitors. They're nice. I got one from Best Buy a few years ago, and never regretted the larger desktop.
Good luck on this one.
Jul 10, 2010 | E-Machines eMachines Monitor E15T4
My monitor says "out of range" H. frequency: 96.4 Khz V. frequency: 119.6 hz
You have to configure your monitor turn it down the frequency of your monitor range
Jan 07, 2010 | Office Equipment & Supplies
View sonic -E70fB monitor displaying H.V frequency out of range when ever i play a game on the monitor screen it is displaying h.v frequency out of range....how to solve this problem
view sonic -E70fB monitor displaying H.V frequency out of range
Jun 06, 2009 | ViewSonic G70F 17'' Monitor + Wyse Winterm...
Compaq presario 2127AD
Flickering may b due 2 ur Display configurations so u may also use some Display software or u may manually correct it.
Properties>Settings>
1. adjust ur screen resolution
Change the refresh frequency for your monitor To change the refresh frequency for your monitor
  1. Open shortcutcold.gifDisplay in Control Panel.
  2. On the Settings tab, click Advanced.
  3. On the Monitor tab, in the Refresh Frequency list, click a new refresh rate.
note.gif Notes
  • To open Display, click Start, point to Settings, click Control Panel, and then double-click Display.
  • The default refresh frequency setting is 100 Hertz, although your monitor may support a higher setting. Check your manufacturer's documentation for information regarding the settings your monitor supports.
  • A higher refresh frequency reduces any flicker on your screen, but choosing a setting that is too high for your monitor can make your display unusable and cause damage to your hardware.
  • Changes to the refresh frequency affect all users that log on to the computer.
Jun 03, 2009 | HP Compaq Presario V3000T Notebook
I have a hp desktop model a1268c computer. after an update my computer srcreen says ''input not supported'' and the screen is blank. When the computer boots the F1 button ''setup'' works but the F10 button...
> You needs to configure your scree resolutions and other parameters.
> May be frequency rate doesn't supported by your old Monitor.
> Just attach your desktop with different monitor and change parameter to lowest frequency range. (60 HZ or lowest with 640*480 resolution)
May 15, 2009 | Computers & Internet
Out of frequency range set lower resolution
reboot the system by pressing F8 if your using windows OS and select last good configuration.
you can try also selecting Enable VGA mode (press F8 while rebooting and select ENABLE VGA mode).
hope this helps, please rate.
Feb 06, 2009 | Compaq Computers & Internet
Relisys Monitor model TL528A - Plug it in, screen is blank panel light is yellow. push ON button and I get a 5 second message stating: OUT OF RANGE HS: 53.5 KHz VS: 84.8 HZ WORK RANGE ...
It normally means that you have connected the monitor to a computer whose resolution and frequency are beyond the range that this monitor are capable of.
To fix this, you can do one of two things: reconnect the old monitor and reduce the resolution to 800 by 600, which every monitor can handle and then reconnect the new monitor and change the resolution settings again. by default, Windows will restrict you to only settings that the monitor can handle. The second option would be to start your computer in safe mode (F8, just before you get the windows screen during boot). and change you monitor settings that way, rebooting afterwards.
Jul 10, 2008 | Computers & Internet
Wyse 1200LE - error - out of frequency
The display settings are not valid with the monitor. Either you are using a new monitor or you have changed the settings. If you are using a new monitor, swap with the old monitor and configure the appropriate refresh rate for the new monitor.
If you have changed the settings you may need to either reset all default settings, or setup a parallel unit and use the same key strokes to change the display settings on the problem unit.
Cheers..
Apr 02, 2008 | WYSE Winterm S30 Network Terminal
Computers & Internet Logo
392 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
