Question about Toshiba 62HMX84 62" Rear Projection HDTV
The picture on my 2 yr old Toshiba 42hm66 DLP tv starts flickering and with alot of rainbow looking distortion after an hour of veiwing. I replaced the lamp, but it sill has the probelm. Any idea what may be the problem? TV flickers after about an hour of viewing and sometimes shows a colored xray affect at times. Images flicker and dark scenes show heavy distortion.
  • 1 more comment
  • Anonymous Apr 01, 2009
    I also have a problem with the color flickering after the television has bben on for a while. The problem gets worse as the tv stays on. I do not believe that it is the lamp, due to not led light signals.
  • Anonymous Apr 08, 2009
    my picture in my 62inch toshobia is dark, only can see it at night.
  • Anonymous Mar 25, 2014
    my tv is showing in green and flickering
I hope this helps you but you might wanna look into some other posts too cause it goes farther then the lamps and color wheels. Basically it's a bad product and the consumer should be fixing it. But your problem seems to be the color wheel. Or just a good cleaning. We replaced the lamb in ours and still had a color problem. We're gonna do an exstensive cleaning and dusting of our unit and if it don't work. We're going straight to the manufactor. This is enough with this product! It's costly to repair and still don't have the quality picture it should. It's more then a simple fix and too costly for ppl to just fix and move on. For how old these products are this all should not be happening.
Posted on Dec 09, 2008
We have a roughly 10 yr old tv that was given to us from friends (therefore we dont have waranty), and it has just started flickering red lines horizontally across the screen. It is a large non-flat rear...
Ur convergence is dead.These problems are colors misalines,3D pictures,colors distorted.U know how to solders?Must replaced 2 convergence ICS,and some or all it resistors.Buy a convergence kit at Tv repair World.com,Tvrepairkits.com to repair it ur self.The shop will cost U $300 for parts and labors.
Feb 16, 2010 | Televison & Video
My picture is begining to flicker and there is
Have you replaced the lamp recently? If not the lamp is the first suspect on a picture that flickers...
Nov 11, 2009 | Toshiba 42HM66 42" Projection HDTV
TV worksfine for one hour, colors fade in and out, flickers
Color Wheel, Go website Encmpass Parts Distr Look up the part # if they do not have it in stock then go to E-Bay look under Electronic 1-800-638-3328
Oct 07, 2009 | RCA HD50LPW175 50" HDTV
Panasonic PT-61G53W projection picture flickers and distorts
You said it is Distorting, If the distortion looks "3d" or separate red or green or blue images. You may have a bad solder connection on the convergence ic's they are located on a large heat sink the part number on the ic will begin with STK392- ??? there will be two of them and the pins will need re-soldered, or the part will have to be replaced. If you even just solder the pins it is a good idea to check and see if the heat sink compound has hardened it is a white grease between the heat sink and the component, if this has turned hard it needs replaced. If soldering does not fix the problem these ic's could still be bad, and need changed, but before i would do this i would tap on the chassis with the but of my screwdriver to see if the picture flickers. This being done with the set on and many dangerous voltages present. Soldering the chassis of course with the set unplugged.
I don't recommend doing this repair yourself because of the dangers involved with electrical shock even with the tv unplugged.
If you called a serviceman the repair might run around $300.00.
Sep 05, 2009 | Panasonic PT-61G53 61 in. Rear Projection...
Picture often flickers and image distorts every few minutes
The trouble is most likely in the Video processor. If the trouble looks like its tearing the video only from side to side it may be the line doubler circuit. Some of these boards are no longer available but a good TV tech may be able to componnent level repair it for you.
Apr 15, 2009 | Toshiba TP50H95 50" Rear Projection...
Toshiba dlp 42in. keeps shutting off . replaced lamp 5 months ago
it sounds like your lamp could be failing. check your lamp it should be clear with no frost.. here is your lamp part number 72620067
Mar 15, 2009 | Toshiba 42HM66 42" Projection HDTV
DLP TV starts to loose picture after 1 - 1/2 hours of use
This tv has a 3 board video path. Analog main pcb --->Digital main pcb --->DMD pcb. see which inputs have the problem to narrow it down. if only some inputs, suspect analog board. if everything flickers(all inputs and menu), suspect the dmd or engine. you can see the lamp shine out the back. if the lamp is flickering, suspect lamp or ballast.
Nov 22, 2008 | Samsung HLN5065W 50" Rear Projection...
Dlp picture problems
dear,
if you have checked it by changing the lamp then there you will see a thin peice of coloured plastic (colour wheel). Vacuum that plastic and all around it but dear plz dont touch that one.
regards,
Aug 16, 2008 | Toshiba 46HM95 46" HDTV
Toshiba 62HMX84 62" Rear Projection HDTV Logo
257 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
