Screen flickers in 1680x1050 - samsung 2232BW plus
I recently purchased the samsung 2232BW Plus as a monitor to use with my laptop. I'm using the vga cable and NOT the dvi cable. The laptop is an old dell inspiron 1100.
I thought for sure I was having interference on the monitor from my power supply that sits on my desk so I removed the power supply, my cell phone, my speakers and anything that could possibly emit any current away from the monitor... but the problem persists.
The problem with his huge monitor is that everything is distorted at other screen resolutions. 1680x1050 gives the most clear picture and ability to maximize viewing space.
I updated the driver from the samsung website and still no luck. I thought it may have been my video card but the screen works fine for a period of time then begins to flicker. Sometimes, after extended periods of flickering, I can hit the auto-adjust button on the monitor itself and it will correct itself.... sometimes it will not correct itself.
I checked the refresh rates and the max refresh rate on this resolution is only 60Hz... I thought updated the driver would allow a higher refresh rate but no luck on that either.
Is this a hardware issue with the monitor or a problem with my setup? Should I return the monitor for another one?
Many thanks in advance for your assistance.
-dave
  • 1 more comment
  • spam270 Dec 03, 2008
    Well, if you read my full post you would see that I stated it does work in that resolution. Sometimes for hours and sometimes for only minutes and then starts to flicker.
    Is it the refresh rate? the video card? the driver or is it a monitor problem? I think I pretty clearly laid out the situation.
    The laptop is a dell inspiron 1100 - how can I find out if it contains a video card powerful enough to feed this monitor? Or can this even be the root cause of this issue?
  • Brad549 Feb 20, 2009
    I have a SyncMaster 920NW that does the same thing in its native resolution, also using the VGA cable rather than the DVI. I'm using a relatively new Lenovo workstation with Vista.
    I think this may be a video card/monitor combination problem, because the monitor worked fine its native resolution on my other computer for months while plugged into a VGA cable. By the same token, my current workstation can drive any other monitor on that VGA cable with no flicker.
  • grvyspaceman Mar 24, 2009
    I get this problem at any resolution above 1024x800 when attached to my HP (with Intel 965 chipset).
    However,when plugged into my Sony Vaio I do not get this problem.
    Did you sort it out?
  • 67 Answers
Can your monitor AND PC put out that resolution??
I don't think your Dell and put that out, if it's an "old" machine.
Posted on Dec 02, 2008
My acer aspire 9810 video died, can I use the vga port? so far no video out
You can switch to an external monitor or data projector by two methods. 1. Connect the external monitor to the laptop's video port, power up the external monitor first and the laptop. The video information will automatically switch to the external monitor. 2. If you power up the laptop first then you can switch the video output to the external monitor by pressing the Fn key and one of the Function keys, depending upon your make and model laptop. You can also toggle between the external monitor or both LCD screen plus the external monitor or back to LCD screen only by pressing the Fn key plus one of the function key a few times. Here is a list of key combinations for some of the laptops :- IBM ThinkPad = Fn + F7 HP and Compaq = Fn + F4 Toshiba = Fn + F5 Dell = Fn + F8
Mar 02, 2013 | Acer Aspire 9810-6829 Notebook
My samsung q320 will not detect my projector
Connecting an External Monitor or Data Projector
Jan 12, 2013 | Samsung Q32032P PC Notebook
My samsung np-n150 plus had a broken screen, how do i get it connected to a desktop monitor?
Use a VGA cable from the vga port on the right side of the laptop and plug into your monitor.
Aug 13, 2011 | Samsung Computers & Internet
I have a Samsung SensR470 laptop and i have linked up the VGA, audio, and power cables but the monitor is not showing anything. when i turn it on, it just goes into sleep mode or otherwise shows the...
its because you failed to read the Samsung manual on your PC
go there and read, it has HOT key , all laptops have a hot key
Fn key that turns on the external display VGA jack.
on rear of this SAMSUNG.
SLEEP MEANS THE PC IS NOT SENDING THE HORZ AND VERTICAL, SYNC SIGNALS. AT ALL.
THAT MEANS WHAT>?
It means the PC, VGA jack is turned off.
bad cable
bad monitor.
The PC can also be bad VGA chips, or worse,.
your first failing here is not saying why you are using VGA jack
is the Laptop screen dead too> (my other shoe falls off)
dang that be nice to know , no?
or like we do run that VGA to a projector? for say doing power point presentations, (done many before retired)
RTM, the manual is free to read any time of day, 24/7
each PC maker uses there own rules here, its there call
there design and their rules.
my HP its, Fn+F4, (toggle:, internal, external ,both or auto)
but yours is Samsung, ask them. or learn to use google?
Jun 10, 2017 | HP w1907 LCD Monitor
Monitor not wrking
Sounds like you may have had a power surge.??
Disconnect power and signal input.
Turn the unit off for 20 minutes or so. Check the outlet against another device. ( Light )
Turn unit on without connection to PC video.
If you get a no signal, you good to go . Reconnect. If you continue to get a flashing light on power button,
Check warranty, get it back to Samsung for repair.
Hope this has helped
Sep 02, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
What component failed in my 17"CRT 753s model samsung moniter?
Your vertical deflector circuit is going out. This is really not economical to repair, the chip alone is $12-15 plus if you have any other parts in the circuit going out plus labor. You can pickup 17" CRT monitors for less than $15 from goodwill or craigslist.
Sorry to say but I think its time to retire your 753s
Buddy
Corporate Computer
Jul 14, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
1440x900 Monitor seems to think it is a 1680x1050 screen @ >19"?
Try reinstalling the video driver (Control Panel - System - Device Drivers - Video ... ) Good luck
Jun 13, 2009 | ViewSonic VA1930WM LCD Monitor
Any suggestions ?
hello,
firstly you check this monitor to another pc. it the same problem accure then
i thinks this problem due to falure of power supply or dead of flurocent tube. or any the vga cable is faulty.
ok
bye
Oct 29, 2008 | Samsung SyncMaster 920N 19" LCD Monitor
Samsung 2232bw monitor
this shows the internal circut problem, need to consult a technician
Oct 28, 2008 | Samsung 226BW Monitor
Computers & Internet Logo
2,916 people viewed this question
David Payne
David Payne
