My furnace will not stay lit. It lights for about 5 seconds and then goes off. It does that about three times...Ita winter...haha burrrr
  • 76 Answers
Um auto pilot or u have to light the pilot i do not know what you are asking btw if it is just not running long enough time for new theremostat
Posted on Dec 02, 2008
Furnace goes out when blower should start
There is a sensor called a pressure switch that is attached to the area of the blower motor for the exhaust fan. It is bad or plugged.
Nov 16, 2015 | Heating & Cooling
LIght on box inside flashes 4 times on a new propane fill up
If the gas was empty for three days, the furnace may have attempted to start numerous times causing virtually ALL residual gas in the incoming line to be drawn out. You may consider purging the gas line at the clean out cap where the gas line enters the furnace. However, it should have restarted and stayed running after just a few times at the most because as long as the line was NOT disconnected from the main tank, there should be NO air inside the line to cause flame failure.
I'd suggest asking the service company to double check the furnace manifold pressure to ensure there is not a regulator related problem.
Three times this winter (on the coldest days no less) a tiny droplet of water froze internally of the regulator right on the orifice blocking gas flow.
Feb 16, 2015 | Intertherm Gas Furnaces - M1GB-056-AA
Furnace won't stay lit. Intertherm Model M2RC-080A-16BN. Ignightor glows, flame starts and after a few seconds the flame shuts off. Then it starts the cycle again. It goes thru this cycle a fe
It sounds like the flame sensor is bad. If thats not the case you may need to replace the control board. You should make sure the flame sensor is directly into the flame.
Nov 20, 2014 | Intertherm Heating & Cooling
Funace willnot stay lit
Sounds like you may have a dirty flame sensor. Try cleaning it with steel wool or Emory cloth.
Mar 16, 2014 | Amana GMH950453BX Gas Furnace
Janitrol GUPS075-3 Furnace burners will not stay lit
The first thing I would do is make sure the flame sensor is clean, this is a metal rod immersed in the burner flame on the opposite side of the igniter. If too much oxidation builds up on it, it will not allow the burner to stay lit. To clean, just turn off furnace and remove flame sensor and clean with steel wool and then reinstall. If this does not solve the problem there may be a problem with the gas valve.
Nov 08, 2012 | Heating & Cooling
I have a 11 year-old york diamond 80 furnace. The flame sensor lights up and ignite the flame for about 5-6 seconds. Soon the flame goes out once again. There's this clicking sound that is heard every
You need to clean the sensor with steel wool so its very clean check sensor connections . If it is still not working you could change sensor also check out the pressure switch .
Jun 20, 2017 | Heating & Cooling
I have a Model CGN250TE.The pilot light stays lit but when you turn control valve on it stays lit for 5 seconds and then shuts right down,even the pilot light goes out.I have tried venting the room and...
I would first check the gas pressure to your furnace. Then make sure that burners are clean and watch flames when burner first ignites. I have seen burners that were dirty cause delayed ignition that would create a suction when they came on and extingush pilot and burners.
The next thing I would do is change gas valve. Thank you
Dec 19, 2010 | Williams 2509612 Ceramic Mid-Size Heater
I have a goodman propane furnace, model # GMPN080-4 that lights for about five seconds and then cuts off. It does this three times and then stops all together. Tried lightly sanding the flame sensor and it...
The goodman furnace will try and light three time before it faults out for safety reasons. Adjust the flame sensor so that it is closer to the flame or actually in the pilot flame. If the flame sensor is inside the pilot flame and still does not stay lit, your flame sensor is probably defective and should be replaced. You can get one at Ferguson's counter sales.
Dec 12, 2010 | Heating & Cooling
Gas furnace wont stay lit
sounds like the thermocouple that senses when the burner ignites is faulty. when the burner is first lit it looks for a signal from the thermocouple telling it that it has ignition. i have had some luck removing the part (furnace off) and sanding it clean. this is located in front of one of the burners..Good luck
Jan 15, 2009 | Central Dual Temperature Heat Gun Kit...
Keeping Dyna-glo D-E37 lit
sound s like the pilot is blocked and the flame is too small or thermocouple needs replacing
Nov 24, 2008 | Dyna-Glo D-E37 Wall Mounted Panel Heater
Heating & Cooling Logo
18 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
