Question about GE Spacemaker Washer and Dryer Electric Laundry Center
A gasket between the front blower housing and air duct?
In repairing something with the washer unit of my ge spacemaker laundry system (wsm2780wawww) i noticed what appeared to be a lint build-up between the front blower housing and the air duct.  upon further inspection it appeared to be a foam gasket of sorts that is worn out, allowing lint to fall into the unit.  so, 2 questions:  is there supposed to be a foam gasket there?  and, if so, is there a way to replace it without having to replace either the front blower housing or the air duct?  thank you in advance!
  • 115 Answers
The foam gasket is suppose to be there but as far as ordering by itself I am not sure if you can but can some foam from your local hardware and put on there
Posted on Dec 30, 2008
Dryer not getting hot / washer won't run unless dryer on.
If these are separate units, you might have an electrical wiring problem in your house or apartment. If one unit (washer with dryer above), check to make sure the power cord is firmly attached to the terminals. Many other possible causes, too.
Apr 02, 2016 | GE Spacemaker GTUN275EMWW 27" Electric...
I have a GE spave maker Laundry that fills up with water than stops!
GE Washer Not Agitating Repair Guide
www.appliance-repair-it.com/GE-washer.html
If your washer will not agitate or spin take a look at this page GE Washer Not ... If the washer fills up with water then doesn't do anything at all and you do not hear ... if this were the problem, the water would not stop running, over-filling the tub.
GE washer spin cycle not working - ApplianceBlog
www.applianceblog.com/.../217-GE-washer-spin-cycle-not-working
Mar 12, 2005 - 10 posts - ‎3 authors
I have a GE "Spacemaker Laundry" (Stackable) model number ... Today it filled withwater initially then stopped working all together when it ... Bad motor, something jammed/seized up holding the motor back from running?
Jan 10, 2016 | GE Spacemaker Washer and Dryer Electric...
My GE Spacemaker dryer will run but the washer will not start in any cycle (stacked unit)
It looks serious problem. You should go to your nearest repairer to solve the problems if you don't want to stay without your washer.
Mar 13, 2014 | GE Spacemaker Washer and Dryer Electric...
1989 (?) GE Spacemaker washer in a park model trailer has a cracked plastic air pressure tank. No model # on washer, how do i get parts.
You do need the model number to order parts...typically on a stacked unit the model number is inside the dryer door
Sep 08, 2011 | GE Spacemaker Washer and Dryer Electric...
I have a GE stackable unit and I recently broke the belt on the washer- I think. Can I fix it? How do I get the unit open? Thank you for any assistance you can give.
Two screws on the very bottom, remove them and take something flat and insert it in the crack where the washer top is and the front panel. The front panel will slide down and out towards you...if no water is in the unit then push the tub back towards the rear and the motor will lift enough to work on it, replace the belt around the main pulley and then push the spring loaded pulley towds the left towards the main pulley and slide the belt onto the motor pulley...
Apr 10, 2011 | GE Spacemaker Washer and Dryer Electric...
Getting a lot of condensation at wall where the dryer vent attaches, we have moved and the new house has a smaller laundry room. The first time we used the dryer I noticed a puddle of water, checked washer...
My suspicion is that the damper on the dryer vent is not completely closing, allowing the cold air to pass into the house. Also check to see if the vent hose is sealed to the vent with duct tape or steel tape.
Feb 22, 2010 | GE WSXH208A Front Load Washer
RE GE spacemaker Mfg ID 3394721, SN CF2817278. How do I remove the 3 support suspension absorbers (also must remove tub) Is there any schmetic diagrams or drawings to explain the removal/replacement of...
big job.remove front panel.disconnect all hoses and wires,two bolts bottom l/r corners will allow you to slide whole unit out of cabinet.disconnect motor,transmission and tub.you will probably need suspension plate where shocks attach .holes are probably reamed out.$$$Hope this helps. please rate my response :)
Dec 09, 2009 | GE Spacemaker Washer and Dryer Electric...
My GE spacemaker dryer has heat but very little air flow. We cleaned the air vent but it didn't help, what else might be wrong? Thanks so much.
Make sure it is clean from the blower wheel to the vent exit. Make sure the blower isn't slipping on the motor shaft. Eric
Sep 18, 2009 | GE Spacemaker Washer and Dryer Electric...
My space saver dryer will not get hot ,everything else works fine
If everything else works, but not heating, than the problem is either:
Clogged air ducts
or
Heating element needs to be replaced.
Jun 05, 2009 | GE Spacemaker Washer and Dryer Electric...
Washer will not drain
I just repaired one that had a needle stuck in the pump. Take the front cover off and the pump is in the lower left corner. Remove hoses and pull pump out then dis assemble pump and clean out.
If that does not do it you have to replace the pump.
Jul 23, 2008 | GE WSM2700W Unitized Spacemaker Washer and...
GE Spacemaker Washer and Dryer Electric Laundry Center Logo
106 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
