Question about Baby Gear
Bugaboo adapters for maxi cosi got stuck to the maxicosi carseat
Hi, we connected the bugaboo adapters for maxi cosi mico to the maxi-cosi mico carseat. The relase button on the maxi cosi carseat is also stuck and the adapters will not release.
Can you please advise to release the stuck adapters from the car seat?
  • 1 more comment
  • Anonymous Jan 20, 2009
    I have the same problem and cannot figure out how to get the adaptors out of the car seat. I dont think it should be that hard but I've pulled with all my strength and cannot get them out at all. I hope it's not this hard everytime.
  • Anonymous Apr 26, 2009
    I guess this is a general problem. First time using them and the left side got stuck, the release button is also stuck and there is no way to get it out...I looked inside and the hook is holding it but i guess i put it on wrong..can anyone have a suggestion?
  • JPED May 22, 2009
    Adapters were stuck! And I mean Stuck! I did the same thing, I pulled them off, but I turned the car seat upside down and put a pillow on top and sat on it when I pulled and they FINALLY came off! Hooray!
We have just released the Bugaboo adapters by pressing buttons on the Maxi Cosi seat and gently pulling the adapters at the same time. These buttons can be found either side on the top of the seat, next to where the seat carry handles are attached. The adapters come away very easily, no force needed. (I dont know if this is true if the adapters are in the wrong way round!)
Posted on Dec 12, 2009
There's no need to place the seat upside down and pull.
Simply push the grey button on either side of the child seat that face upwards (in the bend of the chair), and then pull off the adaptors.
Posted on Jun 10, 2010
  • deb williams Oct 31, 2011
    that works unless the grey buttons are stuck too
If you pry the pegs a little bit away from the seat, you should be able to get a 1/8" or so gap which will let you stick a small dinner fork into the space. Using the tines of the fork, reach under the "pawl" (hook) that is engaged on the tab of the adapter, and displace the pawl toward the car seat. There should be enough give to have the pawl clear the tab.
Don't force it. If you do it right, it doesn't take too much force, and should only take a few minutes.
Posted on Mar 31, 2010
  • ikouznetsov Apr 03, 2011
    you are genious!
All right, I got them out by turning the car seat on its top and pulling the adapters. I also placed my foot on the bottom of the car seat to counter the pulling... that's one tough mo-fo for sure.
I realized that I put them on wrong (flipped sides) - the correct way is to have the L and R letters on the adapters face outward and make sure they correspond with the sides of baby's arms.
Have fun pulling ;-)
Posted on Jan 25, 2009
Same thing here, adapter got stuck. Release button was stuck fully depressed, tried to tug on it for about an hour. finally turned it over put one foot on the back and used both hands and pulled the ****** out. works fine now.
Posted on Nov 17, 2009
If you put the adapters in wrong, like I did, then I found the following helped. If you rotate the adapter toward the back while you pull it out, it serves to push the hook away from the catch, thus making it much easier to get out.
Posted on Apr 10, 2012
  • Yousuf A. Jul 12, 2012
    I had the same problem, I followed your way in getting them out, it is easy and worked fine with me. Thank you very much
There is a hook inside the slot of the maxicosi where the adapter is. After trying brute force for 10 min without success, I read this blog, and found the solution to lift the hook the simplest, which can be done without any force. Simply use a flashlight to look on the mechanism in between the car seat and adapter. there is a vertical hook starting from the base of the car seat and reaching the adapter. If you hold the car seat in front of you, looking in the little space between the adapter and car seat the hook will be vertical inside the adapter in the middle of it. Its orientation is sideways. Take a spiky kitchen knife and get the hook off using the sides as levers. You will easily see which piece can move. Once I did one, I did the other in 30 sec. Good luck!
Posted on Dec 27, 2013
I cannot remove the maxi car seat adopters for the bugaboo. Is there a release in the car seat?
Posted on Aug 01, 2009
Thanks so much after looking on the Internet for about 30 mins and looking to see if they had a video there was still nothing until this post and I got it off finally... Dumb junk is so difficult >:-(
Posted on Aug 03, 2013
Hi
You need to contact Bugaboo for assistance in removing them as Maxi-Cosi do not produce the adaptors to add this carseat to the chassis.
Bugaboo Official Site
Aug 11, 2014 | Bugaboo Cameleon Baby Gear
Can I use Maxi-Cosi Mico seat in a familyfix base? Tks
Hi Renata
The Maxi-Cosi FamilyFix base is a European product designed for use with European model carseats.
The Mico is a USA model carseat and is not suitable for use in this base. You should use a Mico base if you are in USA / Use a European carseat if you are in Europe.
Mar 16, 2014 | Baby Gear
How to install Carseat in car
Hi
The Maxi Cosi Mico is not available in the UK so we're unable to assist with this enquiry.
Please contact Maxi Cosi USA for assistance:
crelations@djgusa.com
Jul 09, 2012 | Maxi-Cosi Mico Infant Car Seat
Hi, I would like to ask a few questions: 1. Does the Maxi Cosi Cabrio car seat fits only to the isofix base, or can it be installed to the mico base as well ? If it does, the only difference is that the...
Good Morning
The Maxi Cosi CabrioFix can be fitted without any base, using the 3 point seatbelt: With the EasyFix base, using IsoFix points or 3 point seatbelt: With the EasyBase and EasyBase 2 using the 3 point seatbelt. It cannot be used with the Mico carseat base as they are not designed to be used together. The Mico is available in US and does not meet UK standards: Likewise the CabrioFix does not meet US standards so they should never be used together.
If you don't know how to fit the carseat into your vehicle using the 3 point seatbelt please check your user manual, or download a replacement copy at www.maxi-cosi.com before use go to an authorised retailer to check it is correctly installed as this will affect the performance of the carseat.
Aug 05, 2011 | Maxi-Cosi CabrioFix (Black Reflection)...
Hi i have a maxi cosi mico car seat and the adapters for the bugaboo frog are stuck on the car seat. I might have put the adapters on backwards. how can i get them off! thank you
There are two gray buttons on the car seat pretty much above where the car seat attaches to the chassis. (These are different buttons than the ones you push to move the car seat handle forward/backward.) Push on these buttons and pull down on the adapters. Should come off.
I recently bought my maxi cosi adapters, and I had the same problem you're having. I did have them on backward. But, I'll be honest, even when they are put on correctly, it is still a pain in the you know what to put mine in, attach the car seat, and then take the car seat off of the chassis. Starting to regret my frog purchase...
Apr 03, 2011 | Bugaboo Car Seat Adapter For Maxi Cosi...
How to install Maxi Cosi Car Seat Adapter for Bugaboo strollers. I just bought the adapter but can't seem to know how to install it.
Hello - Maxi Cosi do not produce the adaptors to fit their brand carseats onto another brand stroller. For advice on how to fit your Maxi Cosi carseat to this stroller please contact the manufacturer of the stroller as they would be the company who produce the adaptors.
Feb 18, 2011 | Maxi-Cosi Mico Infant Car Seat
Is the maxi cosi cabriofix car seat compatible with the mico car seat bases?
I just called the Maxi Cosi customer service line to ask this question. No, the carseat base for mico will not work with a cabriofix carseat- different shape.
Oct 25, 2009 | Maxi-Cosi CabrioFix (Black Reflection)...
Maxi cosi mico car seat on bugaboo is not level with the ground!
you may have put the car seat brakets the wrong way round change them around and try again or go to www.buggypitstop.co.uk they are experts on bugaboos
Jul 14, 2009 | Maxi-Cosi Mico Infant Car Seat
Baby Gear Logo
8,397 people viewed this question
Top Baby Gear Experts
Dorel UK
Dorel UK
Are you a Baby Gear Expert? Answer questions, earn points and help others
