Not storing the water
My machine is not storing water ,once program start
whirlpool machine Fp65
  • Washing Mach... Master
  • 3,463 Answers
Sounds like the water is syphoning away while it is filling. Check the drain outlet hose is not to low, if necesary lift the hose up higher, this should solve the problem
Posted on Dec 02, 2008
When i am switch on my whirlpool fuzzy logicits not working why?
Possible failure of the memory to the processor or there are problems in the customer panel or board. Check for moisture , use a dryer to dry and reset
Mar 23, 2013 | Whirlpool Washing Machines
My whirlpool Model wtw4850xq is not working. The spin light keeps flashing and it won't do anything when I push start other than lock the lid.
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows though the inlet then the flow pressure should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Test a pressure switch: Click on : http://www.youtube.com/watch?v=HZZ2bDMspj8
Check this link to replace the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Jan 24, 2013 | Whirlpool WTW4850XQ Washing Machines
Whirlpool washer wow 4820 xq
Jan 18, 2013 | Whirlpool Washing Machines
Whirlpool, model du915qwdb5, serie fg390915, water not coming
Jan 15, 2013 | Whirlpool Washing Machines
Whirlpool AWM 336 won't spin
Jan 14, 2013 | Washing Machines
How to check mcu on whirlpool duet
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Oct 15, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Washing machine won't spin out. It is a Whirlpool Ultimate Care 2
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Thank you for using fixya.
Sep 09, 2011 | Whirlpool Washing Machines
Whirlpool WW1206
WW1206 Whirlpool Washing Machine CONTINUOUS WATER PROBLEM.
Water is continuous once the system says it to open, thus the program stops there and no more spinning. Water level setting is not functioning. Water inflow stops only when pressing the pause position. Even if the water supply is cut off, no spinning is experienced. The program still continues and waits for the automatic water supply cut off as programmed, but the water level indicator does not work. rince and spin programs work because there is no supply of water in the program.
PLEASE KINDLY ADVISE
Jan 17, 2011 | Whirlpool Washing Machines
Washing Machines Logo
61 people viewed this question
Top Washing Machines Experts
