Question about Intel DG31PR Motherboard
I just put together a new computer, parts ordered over the internet. I have the dg31pr motherboard with a 2.2 GHz dual core processor and 2 GB of DDR2 RAM. I think everything is installed correctly, but when I turn the computer on, I get the motherboard light, the system light, and the fans start up, but I get no beep, and the monitor shows nothing whenever it is hooked up to the system. What could the problem be? And is there a way to fix it without replacing parts? Because I have no other parts, and I don't really have the money to get any...
  • michaelsimao Dec 02, 2008
    As far as I can see, all the cables are attached properly and all the devices are hooked up. I'm having trouble figuring out whether or not the power supply is enough for what I'm running, because this motherboard didn't come with a manual, and it's not coming up when I try to pull it up online. The RAM is all seated properly and is the right type. I didn't put thermal grease between the fan and CPU..where would I put it? On the CPU cover, between that and the heat sink? And would not having put the grease on cause the system to light up, fans running, but no beeps? Thanks for your help...
  • 67 Answers
Check for the following:
1. Are ALL the power cables attached to the motherboard? There should be 2, The "long" one and the 4-square one the connects to the motherboard away from the master socket.
2. Are ALL the devices hooked up? Powering up w/o a load will cause this problem.
3. Are you using a strong enough power supply for your rig?
4. Is the RAM properly seated, as is the video card (if not an integrated one)?
5. If you installed the CPU and fan - did you put thermal grease between the fan and the CPU?
6. Does the RAM match and are they in the right sockets, as well?
Posted on Dec 02, 2008
  • Anthony Perez
    Anthony Perez Dec 02, 2008
    Not putting thermal grease on top of the CPU (between the CPU and heatsink) will cause the machine to lockup/shut down because of the immense heat build-up.
    WARNING: Running it as-is (w/o thermal paste) can KILL the CPU.
Can i make a dual core run like a quad core, or add cores with out changing mother board?
You may be able to install a quad core processor on your motherboard, will need the model to check.
You can't make new cores out of nothing though.
Oct 22, 2012 | HP Compaq SR5702F PC Desktop
What type of dual core processor can I use for my dc7600?
The motherboard for the dc7600 has an Intel LGA775 processor socket. However, not all LGA775 processors are compatible with the motherboard. For the small form factor, the following CPUs are supported: Intel Celeron D Processors:
Intel Celeron D 331 Processor (2.66-GHz, 256K L2 cache, 533-MHz FSB) , Intel Celeron D 336 Processor (2.80-GHz, 256K L2 cache, 533-MHz FSB) , Intel Celeron D 346 Processor (3.06-GHz, 256K L2 cache, 533-MHz FSB)
Intel Pentium 4 Processors with HT Technology:
Intel Pentium 4 521 Processor (2.8-GHz, 1-MB L2 cache, 800-MHz FSB) , Intel Pentium 4 524 Processor (3.06-GHz, 1-MB L2 cache, 533-MHz FSB) , Intel Pentium 4 541 Processor (3.2-GHz, 1-MB L2 cache, 800-MHz FSB), Intel Pentium 4 620 Processor (2.8-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 630 Processor (3.0-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 631 Processor (3.0-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 640 Processor (3.2-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 641 Processor (3.2-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 650 Processor (3.4-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 651 Processor (3.4-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 661 Processor (3.6-GHz, 2-MB L2 cache, 800-MHz FSB) or
Intel Pentium D Dual Core Processors:
Intel Pentium D 805 Dual Core Processor (2.66-GHz, 2x1MB L2 cache, 533-MHz FSB), Intel Pentium D 820 Dual Core Processor (2.8-GHz, 2x1MB L2 cache, 800-MHz FSB), Intel Pentium D 915 Dual Core Processor (2.8-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 925 Dual Core Processor (3.0-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 930 Dual Core Processor (3.0-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 940 Dual Core Processor (3.2-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 945 Dual Core Processor (3.4-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 950 Dual Core Processor (3.4-GHz, 2x2MB L2 cache, 800 MHz FSB)
Unfortunately, these are old processors and I don't see any available new. Newegg.com lists a couple available as refurbished. You may be better off getting a new computer with either a Intel I3 or current AMD processor.
I wish that I had better news for you.
(do not attempt to use a CPU that your motherboard doesn't support. It probably won't boot.)
Mar 30, 2012 | HP Compaq dc7600 Small Form Factor PC...
What model of cpu is this motherboard (Intel DG31PR) designed to accept?
Hello Kbda,
Intel DG31PR Motherboard support the cpu of following types Intel® Core™2 Quad Processor, Intel® Core™2 Quad Desktop Processor, Intel® Core™2 Duo Desktop Processor, Intel® Pentium® Desktop Processor,Collapse to hide the details Intel® Celeron® Processor, Intel® Celeron® Desktop Processor, Intel® Celeron® Dual-Core Processor, Intel® Xeon® Processor.
Also visit the link provided below :
http://processormatch.intel.com/CompDB/SearchResult.aspx?Boardname=dg31pr
Jul 08, 2011 | Intel DG31PR Motherboard
Can i up grade my single core cpu pen4 550 3,4GHz to a Quad core or dual core either one would help
Depends on the socket type.. Socket 423 and 478 do not support core duo or quad core processor types. However, if you have LGA 775 (aka socket T) your motherboard will support the following:
Intel Pentium 4 (2.60 - 3.80 GHz)
Intel Celeron D (2.53 - 3.60 GHz )
Intel Pentium 4 Extreme Edition (3.20 - 3.73 GHz)
Intel Pentium D (2.66 - 3.60 GHz)
Pentium Extreme Edition (3.20 - 3.73 GHz)
Pentium Dual-Core (1.40 - 3.33 GHz)
Intel Core 2 Duo (1.60 - 3.33 GHz)
Intel Core 2 Extreme (2.66 - 3.20 GHz)
Intel Core 2 Quad (2.33 - 3.00 GHz)
Intel Xeon (1.86-3.40 GHz)
Intel Celeron (1.60 - 2.40 GHz)
Mar 22, 2011 | HP Pavilion a775c (A775CB) PC Desktop
I can't install AUTOCAD 2009 in my windows XP computer.It asks to install direct 3D
Most probably your hardware ie graphic card do not support software requirements.
Autocad 2009 system requirements for Win XP.
32-bit AutoCAD 2009
Running under Windows XP:
•Microsoft Windows XP SP2 operating system
•Intel® Pentium® 4 processor or AMD Athlon®, 2.2 GHz or greater
or
Intel or AMD Dual Core processor, 1.6 GHz or greater
•1 GB RAM
•750 MB free hard disk space for installation
•1024x768 VGA with true color
•Microsoft Internet Explorer 6.0 (SP1 or higher)
If you are using AutoCAD for 3D modeling, you should bump up your system as follows:
•Intel Pentium 4 processor or AMD Athlon, 3.0 GHz or greater
or
Intel or AMD Dual Core processor, 2.0 GHz or greater
•2 GB RAM or greater
•2 GB of additional free hard disk space
•1,280 x 1,024 32-bit color video display adapter (true color) 128 MB or greater, OpenGL or Direct3D capable workstation class graphics card.
Hope it helps.
Mar 22, 2011 | Computers & Internet
Pasos para instalacion de web camvx2000
Hola amigo primero que nada devemos saber que systema operativo usa tu computador Windows Xp Vista or Windows 7
Esta Web cam es configura automaticamente per piensa tambien en los requerimientos del su systema. aqui algunos tips.
Habla en espanol y solo pregunta ok
Techbelkin
System Requirements Operating System For Windows®-based PC
Requires a PC that meets the requirements for and has installed one of these operating systems
Processor Windows® 7
Mmimimum: Intel Pentium 4 (3 GhZ), 1 GB of RAM; recommended: Intel Pentium (Dual-Core 1.8 GHz), 2 GB of RAM, 1250 MB free Windows Vista®
Windows® XP with Service Pack 2 (SP2) or later
Other CD-ROM
USB 1.1 (2.0 recommended)
16-bit color depth or higher, 2 MB or higher video memory
Windows-compatible speakers or headphones Internet Broadband Internet access may be required for certain features. Local and/or long-distance telephone toll charges may apply.
Internet functions also require Internet Explorer® 6/7 for installation; 25 MB hard-drive space typically required.
Nov 03, 2010 | Microsoft LifeCam VX2000 Webcam
I want some information about Nvidia GeForce 9400 GT 1GB DDR 2
If you are using Dual Core the mother board you are using may have PCI Express Slot. So that you may install Graphics card. Only for particular lower end mother board doesn't have this feature. Any way tell me your motherboard make and model no. e.g., Intel DG31PR, 945GNT, DG41TY etc.,
Oct 04, 2009 | Computers & Internet
Problem with DG31PR board while loading windows 2003 server.
check HDD and RAM, make sure your HDD new formated
Sep 03, 2009 | Intel DG31PR Motherboard
Intel Dual Core 2.0 GHz Sytem hangs after boot
During your boot screen press the F8 key to boot into safe mode. If that gets you to the desktop run virus/spyware scans. Reply with any results.
Jan 12, 2009 | Bravo Intel Dual Core E2180-2.0GHz 2GB RAM...
Internet surfing
yes its true. computer specs gives a big factor on internet connection. even though you have a fast speed broadband but your computer is low ed. it will lead to a low opening page like when your browsing with a high definition web page but your processor, memory and graphics coudnt cooperate well to the connection. thats what we called frame per seconds or fps.
cheers
CHARCOIS
Sep 01, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Intel DG31PR Motherboard Logo
63 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
