Kenmore 64002 Microwave Oven Logo
erica fisher Posted on Jun 16, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I hane a Galaxy over the range microwave model # 721.80002401. The problem is the fan randomly turns on and will not go off unless I unplug it.
Anonymous
Level 3:
Top Expert:
  • Master 14,553 Answers
  • Posted on Jun 17, 2012
Anonymous
Master
Level 3:
Top Expert:
Answers
14553
Questions
Helped
2718573
Points
48227
May be a defective fan switch or the unit is detecting some heat there--not likely to be a do it yourself repair--consider having a shop look at it for you---
My microwave oven model 721.85033111 vent fan stays on
You probably have a bad fan thermostat. This thermostat is supposed to turn on the vent fan if the microwave oven gets too hot (caused by cooking too much or having too many burners turned on on the range beneath the microwave oven). It should shut off in about 15 minutes after your turn off the range burners. But if it comes on for no reason, or won't turn off, then You probably have a bad fan thermostat.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
What causes a Samsung Microwave exhaust fan to turn on by itself?
mine turned exhaust fan on automatically... i couldnt shut it off... had to unplug it.... no buttons worked.
GE Over range microwave model JVM1443LK01 This started a couple days ago. After removeing something from the microwave and we shut the door, the fan started up. The fan will run as long as the door is...
I would check the door switches for a faulty switch. If it were condensation on the control panel. I would think it would have dried out by now unless it has damaged the control board.
I have a GE Profile Spacemaker model JVM1660SB005, maufactured in November 2000. I attempted to change a burned out bulb on the left side. I did not check the manual to see how to remove the bulb, nor...
I regularly see (and repair) this light and / or fan failure on model JVM1660SB005 and most any model of over the range microwave.
The problem is on the controller assembly, which I regularly repair very affordably.
At my Web site, you can get details, plus I have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
For more free DIY and other help & advice, feel free to contact me via my site.
Please include FULL model number*, FCC ID number*, + detailed symptom information. ( * on the tag in cooking cavity or around door frame or control frame or on back)
William E. Miller, AS-EET
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
I have a ge spacemaker over the range microwave oven model number jvm1631bj02 and it blows fuse after fuse and seems to blow right before the fan would engage within the first couple of seconds
Sounds like you have a shorted fan motor. Disconnect the power going to the fan and then try turning the microwave on again. Do not run the microwave for more than 5 or 6 seconds without the fan operating. If this does not cure your problem then the next most likely problem is either the AC Capacitor (silver can), or the Magnatron (4 inch square silver unit with cooling fins and thick wires. The voltage present on these two units can hold a charge in excess of 5000 volts, even after a time it is unpluged. Don't go near these unless you know what you are doing.
Best of luck.
1helpful
5helpful
FAN WONT SHUT OFF
My Kenmore microwave oven fan has been turning on and off, almost every hour. Sometimes 3 or 4 times in one hour. It's very random. Model No. 721-80593401 Serial No.503TA03208
Please help!!!
Over the Range Microwave Oven
my microwave oven have inside a a metal papel i remove becouse sparks when turn on .this pece of paper is necesari
thanks
alexas
Top Kenmore Microwave Ovens Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
