Please offer advice if you can.my job is seriously on the line. My Lacie D2 external hard drive power failed today while in use on a Mac using pro-tools music software I foolishly had not backed up some very important recordings before it died on me. The power cable has a Green LED on constantly when its not plugged into the drive, however when i plug it back in it dims in brightness and flashes on and off so i dont think it is the power supply. The drive will not switch back on.Is this easily and cheaply repaired or can I sowehow swap the drive into another identical model.Please please has anyone any expierrince with this.
  • 67 Answers
You don't mention if there is any clicking coming from the drive - so I'll suggest this...
Crack open the enclosure and remove the drive (this will void your warranty,) find matching I/O and PWR cables and just connect the drive to your Mac. If you hear clicking - then your dive is mucked up. If you can READ from the drive, the enclosure has an issue and should be addressed to the manufacturer for replacement.
Posted on Dec 02, 2008
Lacie d2 Quadra Ejects Itself
I've had issues with the lacie mini power supply before. I can cause some wierd issues. Unfortunately, it isn't the cheapest thing to replace but that's probably the best place to look first.
Oct 16, 2012 | LaCie 1TB D2 Quadra eSATA/USB 2.0/FireWire...
LaCie d2 200GB on my Pc (windows xp) via USB 2.0 doesn't show
the situation here is ahppening to all external sata or Esata drives what happens is the external closure has a usb controller when this dies the drive doesn ot spin up or does not reconise simple solution buy a external drive encloser and transfer the drive to it and that will work. thanks and please rate.
Nov 24, 2009 | LaCie d2 (300769) 200 GB Hard Drive
Lacie 500gb quadra external drive won't boot using USB cables.
Microsoft has had some issues in regard to external devices (especially after running some updates). There is a registry patch for this situation. Click below to install the patch. It should fix your external drive problem. All the best!
Greg
http://support.microsoft.com/kb/925196#fixit4me
May 19, 2009 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
Vista (32) will not recognize my lacie d2 external harddisk
solved: after referring to the userguide, I found that I formated my drive with a OS format, which can not be recognized by VISTA >> formated to FAT32 and now it works...
Jan 03, 2009 | LaCie d2 Extreme 250GB External with...
Computer external hard drive problem
If the hard drive still spins, then the data can be saved. If there is a near by computer store, explain your problem, and they can take apart the drive and probably but the data on a new drive for you. If you want to try this yourself, you will need to take apart the outer enclosure of the Lacie drive. Then unplug the hard drive, and either put it in another similar enclosure (requires taking that one apart too) or buying a new enclosure.
Regards,
Sam
Was this information helpful? Please rate it!
Dec 02, 2008 | Computers & Internet
External hard drive
500Gb Lacie D2 Quadra with the same problem of flashing led and not mounting on the desktop (Mac G4 Mirror), traced to the power supply (57w) going down on power, both 12v and 5v supplies are available but the main power to run the drive drops to below an adequate output, hence the clicking and whirring evident from the drive with simultaneous flashing led.
Testing with another Lacie power supply (250Gb D2) this time a 34w unit got the drive up and running, however, and this is the reason for this post, this lower power PSU failed a week later whilst waiting for a warranty replacement from Lacie (5 weeks and still waiting for the new PSU from them. they have no stock)
Message for all Lacie D2 users, check the power supplies first, test with another Lacie PSU, do not run the drive on a lower rating (34w) PSU it will fry it and leave you with another failed power supply.
If you are in a tight spot use the temporary power supply to move your data to another drive and get the correct 57w power supply before running the drive again.
Don't do as I did assume any Lacie power supply will run any Lacie hard drive, they won't, fortunately I had a second back up, but am 2 drives down and no new PSU's available to buy anywhere.
Try and purchase another spare 57w power supply, something all D2 users should do for long term security, as these do not seem to be very reliable and getting warranty support from Lacie on these is currently impossible.
The lack of 57w power supplies from Lacie and its distributors across the world is surely a warning to be noted!!!!!!
Buyers beware!
Aug 08, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
Lacie d2 external drive
you may need to get a new driver for that lacie from their website..
support downloads, model o/s
Mar 01, 2008 | Computers & Internet
LaCie d2 Quadra drive... not showing up on PC after working on a MAC
You need to make sure the drive is formatted for the PC. The Mac will read and write to a FAT32 partition, but the PC cannot see a Mac formatted drive as you have seen.
The only problem is that there is a 32Gb limit per partition for FAT32 drives.
It's not ideal but it's the best you can do easily.
Jan 13, 2008 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
Help please -LaCie D2 Quadra
Take a look at this link and see if it helps -
http://homepage.ntlworld.com/allcam/pc2mac.html
Jan 07, 2008 | LaCie D2 Extreme 300 GB Hard Drive
I support the comments of (fire sine) I have the d2 120gb Lacie and it was down for two years.  I took it to my apple guys and they said that I needed to go to a data recovery service which would cost a gang of money.  Come to find out, when I decided to update my internal hard drive on my Mac Pro, I had to buy a SATA, IDE, USB 2.0 adapter to back up the internal and transfer to the new internal. Long story short, something said, Hey try and open the Lacie and bypass the board in the enclosure and connect directly to the Western Digital drive inside.  AND WHALA! I got my info, so all I need is a new enclosure.
Sep 24, 2007 | LaCie d2 (300769) 200 GB Hard Drive
Computers & Internet Logo
David Payne
David Payne
