Question about Sony Grand WEGA KDF-60XS955 60" Rear Projection HDTV
No picture no sound
I turn on my kdf55xs955 sony and the green light blinks five times and then the red light blinks six times and continues red six times each. I had the ballest module replaced feb 4 2008 I think I should have got more then one year out of the repair.I am very disapointed with sony. I bought the set 2006 .
  • karnold754 Dec 12, 2008
    electronick, can you tell me where to find this 'thermal fuse' in a Sony 50WE610?
    Thanks
    Kevin
  • wreckyard86 Dec 20, 2008
    my sony fell off the 4 foot tv stand and it no longer turns on. It turned on for about 5 sec. a week ago and cut right off. When I turn it on the green light goes on then cuts of and the red light blinks 3 times. its a 60 sony sxrd. any one out there have a solution to my problem? Please..... thanx
  • 505 Answers
6 blinks = power supply error
on this model, a thermal fuse under the lamp will blow for no reason causing this issue. it can be fixed with a new thermal fuse or just a wire will bypass the fuse. remember if you bypass then you've eliminated your fire safegard. the fuse is usually big and metal and will check open with an ohm meter. to get it out, you have to pull the engine and remove the tray piece its attached to. complicated procedure, let me know if you need it. the newer type fuse (non-defective)is like $15 from sony i believe. if you complain to sony they may cover the cost as this is happening to many tvs
Posted on Dec 09, 2008
MY SONY TV MODEL # KF42-WE610 IS SOUND IS COMING ON BUT NO PICTURE
If you turn it on and the, Power/Standby green light blinks slow 6 times; then it becomes a red fast blink 6 times, pause, then continues to blink red fast 6 times, again and again. this means when it's blinking 6 times is indication of electrical circuitry malfunction. The Television will need service.
Sep 30, 2014 | Sony Televison & Video
My KDF-55WF655 power led blinking red six times.
It looks like your power module is on the blink. Do you get any picture?
Jun 13, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
My sony trinitron kV ES 34M90 GIVES 6 ERROR BLINK CODES
Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206. To get more details, http://electronicshelponline.blogspot.com/
Nov 28, 2013 | Sony Televison & Video
Red flashing after tv turn on for KDS-R60XBR1
How many times does the red light flash before it pauses and then starts again? This is important info as it helps to diagnose your problem.
Mar 20, 2013 | Sony Grand WEGA KDF-55WF655 36" Rear...
I have a Sony KDS-R50XBR1 that has no picture. When I turn on the TV, the green Power/Standby LED light blinks for about 30 seconds, then turns red and blinks five times. The Power/Standby LED repeats...
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen A2 slightly.
Jan 19, 2011 | Sony KDSR50XBR1 50" Projection HDTV
MY wega 42inch wont turn on...the little green light flashes like five time as if it where to turn on but never does...and then it turns red and flash six times pauses and then again the red light flashes...
Six blinks indicates a faulty power supply. often caused by open thermistor located at under lamp assembly or beside it. Or a defective regulator on power supply section.. Check the thermistor and replace if found defective.. Or contact the nearest Sony service center at your area.
Oct 01, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sony LCD television will not power on.
I get 5 blinking red lights for about a minute or so before it powers back down. The Sony TV has a specific light that i presume is supposed to light up when the bulb is out. I'm unsure if this is what it is.
no picture, no sound. tries to boot with green light blinking a few times. then goes to red blinking light, six in all, then waits a few moments, then another 6 blinking red light.
Bulb was already replaced several months ago but we do have the TV on for long periods of time.
Jan 15, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
No picture or sound - Error code with Six blinks
SIX Blinks---No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206
Sep 24, 2006 | Sony KP-57WV600 57" Rear Projection...
Sony Grand WEGA KDF-60XS955 60" Rear Projection HDTV Logo
196 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
