Question about U.S. Robotics MAXg USR5461 (738168036790) Wireless Router
USB Wireless Network Setup Values
Am trying to set up my US Robotics MAXg wireless USB adapter. Using the SureStart Installer I get to a screen that says my selected router or access point has security enabled. Enter the appropriate values. (WPA2, WPA,WEP Open, WEP Shared, or other). I have a Westfall Model 327W Gateway from Verizon. Which value do I select?
After this screen it asks to enter the passphrase or encryption key for the router. Is this the password for the gateway unit?
  • 67 Answers
The value it s asking for is the password you'll need to enter on all your authorized machines to use when asked.
Most common is WEP-Open. It's a 10 character password you can use. You can use the numbers 0-9 and the letters A-F. For example 39cca8f1a4 could be your 'key' or passphrase.
Again, any key you "make up" will have to be known to other computers trying to use that point to access the network and the Internet.
Posted on Dec 02, 2008
  • 76 Answers
During setup it should asked you to create password but anyways those letters are security protocals for your router to prevent peeps from accessing your network...wep is easiest
Can't find wireless router in windows xp
Please do the below steps.
1. Check the status of the wireless router . is it power ON and working ?
2. Check the wireless adapter status on the PC
3. Check for the proper drivers for the wireless adapter. If possible reinstall the drivers
Oct 31, 2010 | U.S. Robotics Wireless MAXg USB Adapter...
Unable to get USR Maxg 5425 driver for Windows 7, Can i please get any help? Thanks Raj
Use the XP or VISTA one and just ignore the message about it not being win 7 certified
Aug 20, 2010 | U.S. Robotics MAXg USR5421 802.11g/b...
Us robotics
u must check if the coverage is rhight or not when face this problem
Jun 20, 2009 | U.S. Robotics MAXg USR5421 802.11g/b...
How do i find my network key or create one for security?
Login to your router and check to see if wireless security is setup:
Use Internet Explorer and type 192.168.2.1 in the address bar.
Login using the password you created when you setup the router.
You can view the wireless security settings and retrieve the key.
If security is not setup you can enable it....directions here:
http://www.usr.com/support/5461/5461-ug/wireless.html
Mar 11, 2009 | U.S. Robotics MAXg USR5461 (738168036790)...
How to connect maxg with a my netgear broadband router
Try to turn off the DHCP server in the secound router, that way it'll be a swich technically, and set the secound router's fix ip address to something different, because I'm quite sure that both routers have the same 192.168.0.1 IP address and that's nogood.
Set it to anyting from 192.168.0.2 to 192.168.0.254
Nov 26, 2008 | U.S. Robotics MAXg USR5421 802.11g/b...
Wireless security to xbox
assuming you mean xbox360, there should be a seperate menu for wireless connections in the network settings, as when it finds the signal it then asks for the keycode security number, but as far as i know the old xbox doesnt support wireless.
Sep 09, 2007 | U.S. Robotics MAXg USR5421 802.11g/b...
Unable to open internet page
let you router allocate the ip addresses manually by enabling DHCP and restart the router,and remove the usb adapter from the usb port and reconnect it, but when you right click on the taskbar on the little pc icons for your connection click enable WZC windows wireless Zero configuration as this will dissable the software you got with the usb adapter and hopefully make the connection more stable, but ensure you have a strong signal.
Jun 01, 2007 | U.S. Robotics MAXg USR5421 802.11g/b...
Error code 10 Device cannot restart
Generally a code 10 refers to a dead component unfortunately.Although the card will be recognised.
Aug 29, 2006 | U.S. Robotics MAXg USR5417 802.11g/b...
Open Questions:
U.S. Robotics MAXg USR5461 (738168036790) Wireless Router Logo
237 people viewed this question
Top U.S. Robotics Computers & Internet Experts
Michael Galve
Michael Galve
Aris C.
Aris C.
Are you an U.S. Robotics Computer and Internet Expert? Answer questions, earn points and help others
