Question about Apple iPhone Smartphone
Iphone 2g unlocked,cannot connect w/ edge. wifi is working
I Got my ihone 2g unlocked again and this time jailbreak w/ 2.2 firmware. Now I cannot connect online w/ edge, cannot find edge on network selection. However my wifi works. Please help!
  • Anonymous Mar 27, 2014
    I unlockd my phone with a code online, but now the wifi wont stay connected. It drops every 2 minutes and before unlocking I never had this issue.
  • 67 Answers
Jailbreaking your iPhone to 2.2 is going to mess up your phone. I've got a jailbroken 2.2 iPod Touch and it's ok - a friend of mine also tried to jailbreak his iPhone to 2.2 and lost connections as well.
Downgrade back to 2.1 and you should be ok.
Posted on Dec 02, 2008
I just restore my iphone 2g with itunes.. i can call,, but i can not open menu.. help plz
You have to jailbreak the phone so you can activate it.
It's a long process but you need to download redsnow 0.9.4, firmware 3.1.3 and 3.1.2 plus the bootloaders.
Since you're done with the restore, run redsnow now.
Select 3.1.2 firmware then follow onscreen instructions.
Check Install Cydia and Unlock when prompted and browse for the bootloaders.
If you followed all the instructions carefully, your phone will be unlocked and activated in no time.
here's a tutorial -> http://www.redmondpie.com/jailbreak-iphone-os-3.1.3-firmware-with-redsn0w-0.9.4/
May 14, 2011 | Apple iPhone Smartphone
Jailbreak iPhone edge os3.1.2
I have a perfect solution for that!
You just need to install Push Fix from Cydia. Click here to see the step by step instruction on how to do that.
For more iPhone / iPod touch tips, click here.
Mar 07, 2010 | Apple iPhone Smartphone
UNlocked 3g iphone 16gb 3.0.1 WIFI NOT WORKING
You can try this site....
http://www.redmondpie.com/jailbreak-iphone-3.0.1-firmware-with-redsn0w/
Sep 20, 2009 | Apple iPhone 3G
No signal
Sir if your are using a 3G iphone with AT&T as a carrier than please contact them for support
If your iphone is jailbreaked ie it is unlocked and you use it with some other carrier or in another country then update your iphone to firmware 3.0 using this step by step detailed guide
for iphone 2g using windows
for iphone 3g using windows
for iphone 2g using mac
for iphone 3g using mac
for further information about jailbreaking please contact me
NOTE I DONT RECOMEND YOU TO JAILBREAK IT... its illegal
Thanx and i hope this helps
PLease rate this solution THanx
Jul 17, 2009 | Apple iPhone Smartphone
Iphone showing no service
If it was bought unlocked for under $700 then it was unlocked illegally after updgrading to 3.0 it is locked again. If you upgrade to any of appples unpdates your phone will be locked each time and you will have to wait for an unlock solution to be released each time. Currently there is no way to unlock the 3g under 3.0 firmware only the 2g is unlockable to the 3.0...I know case i have one. Jailbreaking and unlocking are different.You have to downgrade your firmware to unlock it. Restore your phone via iTunes using one of your old backups, you should be fine.
Jun 26, 2009 | Apple iPhone 3G
Unlock a cect p168
We provide iUnlock Solution : step-by-step tutorial with latest softwares in order to easily unlock/jailbreak your iPhone 2G/3G and iPod Touch 1G/2G.All you have to do is to access iUnlock, download given software and follow the instruction of tutorial. iUnlock is fully compatible with 2G/3G iPhone and iPod Touch 1G/2G with latest firmware 2.2.1.Win XP, Vista and Mac are totally supported.
May 18, 2009 | Dual Electronics CECT P168 Cellular Phone
Jailbreak iPhone
http://www.quickpwn.com/
Try browsing this site. Use the forums. Also, post more info on what exactly was done to your phone. Include version numbers.
Mar 19, 2009 | Apple iPhone Smartphone
IPhone 2G hangs at "slide to unlock" - restore not helping
2g solution
3g solution
if it still gives you problems then you have a hardware issue, apple won't touch a jailbroken iphone so hopfully you have the apple care protection. Restore it to factory settings and try to take it in for service.
Feb 04, 2009 | Apple iPhone Smartphone
its not a hardware problem brothe as i am also facing same problem...actually it all happen with jailbreaked iphone...ad i'hv checked its deep root directory there an application called "lockdown" is the main cause of that...nd still there is no crack of that.....
two days back i unlocked my iphone 2g it was working properly before that i was facing the same issue as you are facing....but now again it went to the same problem....
i hav a temp solution of that...
use blackra1n u can find it from blackra1n.com
nd for few seconds slide to unlock will work
or u can use it by connecting it with ur itunes ...connect usb wire nd slide it again nd again...u can unlock it..bue its just temp
Feb 04, 2009 | Computers & Internet
Not able to unlock and jailbreak my 2G phone and it is stuck in recovery mode
Put iphone into DFU mode. you can do it by iphone software or handy. then restore it by itune (NOTE. delete itune folder in your Mymusic forder (in the my document) itune will make a new one when you open it again )if you get error .open ibricker to get out of recovery mode.
Dec 27, 2008 | Apple iPhone Smartphone
Apple iPhone Smartphone Logo
376 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
