Question about Western Digital 500GB My Book World Edition 500 GB Hard Drive
Slow WD World Edition HD
I own the WD My Book World edition (it happens that I have the 1TB version).
I hate it. It cannot be connected directly to a computer, rather only through a network.
My thought was to take apart the WD drive, take out the HD and connect it to a regular HD enclosure. Would there be any reason that this would not work?
Do you know what type of connection the hard drive is so I can buy the proper enclosure?
Thanks,
Michael
  • yschlussel Feb 08, 2009
    Thanks... I ended up pulling it, formatting it, and sticking it in a 2-bay RAID enclosure with another 1TB drive... works great and fast!
    Problem Solver:
  • 5 Answers
I understand your pain. Mine was always slow, but it's by design. I am sure the limitation is the amount of RAM it has, because everytime it needs to access data, the RAM is so small that it will have to go back to the drive just to re-read an index. When mine died after 1.5 yrs, I took it apart and found a WD5000AAKS SATA 7200rpm drive. Performance of the drive should be excellent, but in that little plastic box that is acting like a stand-alone NT server, performance is s-l-o-w. As a MyBook, it's best used as a backup unit, but be sure you have a backup of that, since it is highly unlikely it will live much more than 12 months, if that, because it has no forced cooling. See other issues on this site with regard to other MyBooks.
Posted on Dec 09, 2008
Indeed you can pull it out and put it in another case, i have done just that with one of mine. though you have to format the drive in the new case because of the os of the mybook, it has its own proprietary formatting or something or other that nothing else likes. but once you stick it in a usb enclosure and format it it runs beautifuly and quite a bit quicker on a usb 2.0 as compared to the 100Mbit cat five alternative. now the my book world is Gbit cappable so if you stick a Gbit card in your computer and run your cable to it in the case it comes in it is insanely fast for some reason, but only when you plug it strait in and not into a hub or network. 1000Mbit is retarded fast so thats your best option. you are probably for some reason or other running on a 10 Mbit and that sucks. Good luck!
Posted on Feb 08, 2009
  • 32,281 Answers
These drives are network drives, I would recommend that if you don't have a network, then you should get a 10/100 Mbit network card and connect a cross over CAT 5e cable, connect to your network card and the 1Tb drive running at 100Mbit. You need configure the network as per the manual.
If you want to use a hub instead of a cross over cable, get a 100Mbit hub.
You can put this drive in a USB enclosure but it will be slower that over the network. The drive could be ATA (IDE connector) or most likely a SATA connection (it might be SCSI, most likely not), you have to remove it to identify the connection on the drive.
Posted on Dec 02, 2008
I have an WDG1NC10000N (Western Digital My Book World Edition 1TB) that was connected fine to my network. Not sure when it stopped being connected, don't access it all the time, but it became complete...
check the 'entire network' sidebar in My Network Places. I installed a new version of Mionet a little while back and it decided to rename my WorldBook and change it to a different network Workgroup without asking me. I freaked out for two days until I saw the other workgroup listed and checked it out. Viola, there was my NAS just waiting for me to find it.
Aug 18, 2010 | Western Digital My Book World Edition 1TB...
Cannot access WD NAS - need help - please ?
I would say that you should re-install the Western Digital My Book.
Hope this helps!
Feb 04, 2010 | Western Digital My Book World Edition 1TB...
WD mybook 1TB is gone from the network
Have you tried different cables or a different port on your router. Is there any way to get into the Hard Drive by connecting it directly to a PC and checking the network settings or anything..? If not, then you may have to connect it directly to a PC and share it to your other PC's.
Sep 15, 2009 | Western Digital My Book World Edition 1TB...
Western Digital World Book 1TB - Lights don't light, HDD vibrates
I would try to connect the drive directly into an ide or a sata cable on the motherboard. Maybe using the western digital tools from their website you'll be able to access the data and copy it. I hope this helps you.
Aug 23, 2009 | Western Digital My Book World Edition 1TB...
Can't map network drive WD Blue ring edition
The Failed Mount issue is usually caused by Internet Security settings. The most common way to resolve it is to add the following files/ports to the exceptions list of your firewall(s) -- in some cases you will need to add it to the Windows Firewall, even if you have another Firewall installed as well:
MioNet.exe (C:\Program Files\MioNet\jvm\bin\MioNet.exe)
MioNetManager.exe (C:\Program Files\MioNet\MioNetManager.exe)
ServiceStatusGui.exe (C:\Program Files\MioNet\ServiceStatusGui.exe)
These ports are also required for MioNet to create a drive-letter for remote drives:
TCP In/Out 443
TCP In/Out 445
Aug 21, 2009 | Western Digital My Book World Edition 1TB...
Cant connect my 1TB WD world edition to my linksys router
Your My Book World should not be formatted or you will lose all ability to access it through the Network -- it will simply become a hard-drive at that point. There is software installed on the hard-drives that communicate with your Router in order to obtain an IP and be available as a Network Drive. If the drive and the Router are communicating, you should see an IP in the DHCP list of your Router. It is possible that the My Book World is not setup for DHCP, so if it is placed in an alternate environment with incompatible static IPs, it won't be able to access the Internet or be available locally. You can try a hardware reset on the drive and see if it pops up in your Router's DHCP/Client list, at which point it should also appear locally and over MioNet (MioNet will need to register the device to an account before it will appear in MioNet, but it must detect the drive locally in order to attach).
1. Turn off My Book World
2. Identify the reset button on the back of My Book World
3. Depress the reset button while restarting My Book World
4. Keep the reset button depressed for about 10 seconds after you see blue lights on My Book World
Jul 02, 2009 | Western Digital 500GB My Book World...
Wd my book world 1tb will not power up
check usb interface. problem in usb terminal. try to press round button switch.
Jun 01, 2009 | Western Digital My Book World Edition 1TB...
Replacing HDD's on WD MyBook World II won't format
I was attempting something similiar -- replacing my World Edition II 500GB drives with 1TB drives. My research unearthed two things... These units will only work with Western Digital Caviar Green drives. The blue ring won't light if other drives are installed. I also read (in a couple spots) that the unit's O/S is stored on the hard drive (as opposed to be stored in Flash memory). If this is true, you would need to image the old drive to the new (using a tool like Ghost or True Image), and increase the partition size as part of the imaging process. I don't know if this would work, as I opted to not proceed with the upgrade. For me, the new version of the World Edition II (WDH2NC20000 and WDH2NC40000) turned out to be a better option than upgrading. These units provdide the extra space and are MUCH faster than the old ones.
Apr 16, 2009 | Western Digital 500GB My Book World...
Problems with Western Digital My Book World Edition
I have the same drive. It works great with windows XP but with Windows vista has difficulty seeing this type of drive and keeping the connection once it is established. Take it back if you have windows vista and then search for which 1TB drives work well with windows vista. It really has problems with windows vista 64bit. I was able to finally see the drive when I was using photoshop file/browse/network... then I dragged the shortcut Icon to my desktop and access the drive that way from that point on. Mine stopped completely tonight... I think the power cord went bad or something.
Jan 04, 2009 | Western Digital My Book World Edition 1TB...
Western Digital 500GB My Book World Edition 500 GB Hard Drive Logo
923 people viewed this question
Top Western Digital Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
