Question about Hitachi 53UWX10B 53" Rear Projection Television
Double vision the red its out of the picture, magic focus could not fix it
  • caroleebrown Dec 03, 2008
    I have a double vision on my TV. Anyway that I can fix it?
  • 76 Answers
There is an option to adjust the primary colors adjust them
Posted on Dec 02, 2008
I have double visions of picture and words,but can't move the red square in magic picture mode.how do you adjust
If magic focus (which adjusts convergence at 18 points on the screen) will not correct it one of the two STK-392-150 CHIPS this set should use is bad.
Both chips need to be replaced at the same time; On EBAY total parts cost will be under 25 dollars.
Are you a do it yourself person or not?
Comment here and I will answer questions--If this told you something you did not know, rate this solution as very helpful as I do this here for free.
SD TECH
Sep 08, 2010 | Hitachi 53UWX10B 53" Rear Projection...
Double picture...not focusing right
maybe parts inside is worn out. causing the blurrines. just consult to your service center.
Jun 19, 2010 | Hitachi 43UWX10B 43" Rear Projection...
The picture is blurred (double vision) and the picture is also bowed. It appears the bulbs are out of focus. Is this fixable?
Try adjusting the convergence. If it won't move see below- (or hitting Magic Focus for some Hitachi’s)
This sounds like convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually charge between $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Oct 05, 2009 | Sony KP-53HS20 TV
Screen color problems
try the magic focus.maybe it will work.
Jan 31, 2009 | Hitachi 46W500 46 in. TV/DVD Combo
Hitachi 42 inch ultra vision has double image
it is just a convergence problem which makes the image look doubled.it can be repaired by any good local tv technician for approx 75 to 80 dollars.nothing much to worry.
Dec 01, 2008 | Hitachi 60V500 60" Rear Projection...
Yellow at the top, double vision, blurr
Good Day, turott1;
You need repair in the convergence circuit, purchase KIT 10. You can buy this at B&D ENTERPRISES, at 1-800-458-6053.
Good Luck, big IRISH.
Dec 30, 2007 | Hitachi 50UX26B/27K 50" Rear Projection...
53UDX10B 53 in. Rear Projection "3D vision"
the convergence IC`s and associated resistors have to be replaced, do not repeatedly push magic focus or the alignment after the parts change out will take longer which of course means higher repair bill, good luck
Nov 10, 2007 | Hitachi 53SDX01B 53" Rear Projection...
53fdx20b double vision?
KIT10 $29.50
Repair Kit for Hitachi convergence Chassis DP-14G
KIT10 Includes 2 pcs STK392-150 , 1 each of the following 1W axial lead fusible resistors:
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Oct 18, 2007 | Hitachi 53FDX20B 53" Rear Projection...
Open Questions:
See all Hitachi 53UWX10B 53" Rear Projection Television Questions
Hitachi 53UWX10B 53" Rear Projection Television Logo
48 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
