Question about Canon Elura 65 Mini DV Digital Camcorder
Zoom by itsown
How do you fixed? I could not figure out where the twisty-tie is? Could you please describe a little bit details. thanks.
  • 4 Answers
I had the same probem. I read on another forum that if you smack the bottom of the camera with the palm of your hand it will unstick the zoom. Worked like a charm for me!
Posted on Feb 19, 2009
Mother board driver
Could you give a little bit more detail?
Here is a link to common Operating System Problems.
http://www.washington.edu/lst/help/computing_fundamentals/troubleshootingxp/common_os
If this does not fix your problem, please leave a comment here describing your problem or re-post your problem again.
Thank you; I hope this helps,
-Levi_xx
Jan 09, 2011 | Computers & Internet
Ok I've had this picture problem described yesterday
Hi jmscoccia i will gladly help you..
first of all i need to know your TV brand? and do you see spots in your tv or some tipe of noise wen is on?
please let me now and then we can figure out what is your problem and hopefully we can fix it
it can be the tv lamp or color wheel. i need to know a little bit more.
Nov 05, 2009 | Samsung HL-S5087W DLP TV
Buttons don't work and can't zoom
hi
Some of those buttons work in combination with the two dials (i.e., setting ISO and white balance, etc.). Hold a buttin down and user the knobs simoultaneously.
If this is not the issue, please describe specifically which buttons are not workin...
thank u
rate me!!
Jul 26, 2009 | Panasonic Lumix DMC-FX01 Digital Camera
Mann
please describe ur problem a bit more..... the details u ve provided are not sufficient
thank you....
Jun 09, 2009 | Sony PlayStation 2 (PS2) Console
Lawnmower starts when primed only then stops
You take the air filter off from carberator (three bolts). There is a bowl with a nut underneath. With socket wrench take bolt off and remove bowl. there are some small holes on the bolt and carberator. Take a twisty tie, like to tie up garbage bags, and run the wire in and out of the small holes. Spray a bit of carb cleaner for good measure.
Put it all back together but don't forget the gasket between the carb and the filter assembly.
Apr 15, 2009 | Garden
Washer wont drain
Go to sears web site and enter model number of machine and look for lid switch. The cabinet of the machine needs to be removed to replace this switch. Go to Appliance Guru for details of removing the cabinet
Jan 04, 2009 | Kenmore 24032\24036 Top Load Washer
I have a fuji finepix s7500 and zoom error. I dont have warranty so I tried to fix myself. I actually found the problem with the zoom. now I am trying to put it back together and I cant figure out where...
The trick is remembering how you dis-assembled so you can re-assemble.
Purchase or borrow another camera and photograph each step.
Buy a plastic tray with little compartments in and start at 1 end and then work back when assembling.
service manuals from "Flying Dutchmen Plaza" on ebay will show you how to fix
Dec 29, 2008 | Fuji FinePix S700 Digital Camera
My zoom acts wierd
Banging the camera solved the problem on my elura 60! I have whack the camcorder three times again the other hand. It worked.
I had this trouble for two years!
Mar 28, 2007 | Canon Elura 70 Mini DV Digital Camcorder
Zoom malfunctioning
This sounds like there is debris lodged in the zoom gears. Been to the beach lately? The gears in the zoom mechanism are very small, and even a tiny spec of sand or other debris can jam them up. Alternatively the sensor inside the lens that feeds back the position of the lens to the control circuit may be failing - so the camera thinks the lens has retracted all the way and stops. If the stoppage of the zoom action is abrupt then it is probably debris, if it is a smooth stoppage like the camera is stopping on purpose it is probably a position sensor. Either way the camera will require repair. David Millier Advance Camera Repair
Feb 20, 2007 | Olympus SP-350 Digital Camera
Canon Elura 65 Mini DV Digital Camcorder Logo
179 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
